Hot Rods Roadster build.
Discussion in 'The Hokey Ass Message Board' started by bct, Oct 21, 2015.
  1. Nice work!
    poprivit and bct like this.
  2. dumprat
    dumprat
    from b.c.
    What year? Guy down the street has a nice pair of doors
  3. bct
    bct
  4. bct
    bct
    29 will do , thanks
  5. dumprat
    dumprat
    from b.c.
    Ok I will ask. He was trying to sell a whole bunch of stuff for one price but most of was luggage racks and ****. Send me an email. Dumprat1@icloud.com
    bct likes this.
  6. Speedy Canuck
    Speedy Canuck
    I've been casually keeping an eye out for a folding rear luggage rack for a 28/29 if you don't mind asking as well :)
    dumprat likes this.
  7. bct
    bct
    Been working hard. Just not on my car. My patience has paid off with this steering wheel though. Very excited about its condition and local to boot. Need a horn ***embly if there is a source let me know.
    chop job, Dog_Patch, Stogy and 3 others like this.
  8. chop job
    chop job
    from Wisconsin
    This is truly one nice hot rod . Great work!
    bct likes this.
  9. bct
    bct
    Anyone tell me what years the steering shaft was a tapered key . Is model A the same? Going to cut a taper and keyway in my f100 and need a patten to copy. I' hoping moder A work cuz I could borrow one . Let me know thanks.
  10. kidcampbell71
    kidcampbell71
    Dang' it. I lost this sum' b#tch for a bit. Didja' change the ***le or something BCT ? Hmmm, eh' well ... leaving my crumb trail now. Hot diggety' dog !
    117harv likes this.
  11. dumprat
    dumprat
    from b.c.
    Garrett. Carefully chuck the wheel up in the lathe if you can and dial the taper in on the compound. You get a better copy of the taper that way. A little bluing and some lapping will get it exact!
  12. bct
    bct
    Thanks for the advice my 9" lathe wouldn't handle that . I was thinking worst case scenario cram it full of playdoh and copy the plug?
  13. dumprat
    dumprat
    from b.c.
    Plydoh dries like cement! Which should work great.
  14. bct
    bct
    Yes I changed the ***le. Tongue in cheek stab at some of the people who forgot why we are here. Thanks for the comment and the likes.
    Bondo Slinger likes this.
  15. bct
    bct
    Even if it shrinks a bit the angle/taper would be the same.
    dumprat likes this.
  16. RICH B
    RICH B
    Taper is the same from '28-'48; so a model A shaft should be a good pattern. You could always check the fit in your wheel to confirm this.
  17. bct
    bct
    For sure. my model A source is a long drive so I know its worth it. thanks.
  18. bct
    bct
    Not an update per say but I'm happy to say I found a p***enger door after several years of searching. 20180109_182334.jpg 20180109_182403.jpg
    200 bucks is a bit better than going rate. Close to home too.
    Stogy likes this.
  19. The37Kid
    The37Kid
    Nice door, looks like there may be a bottom as well.:) Bob
  20. bct
    bct
    Ya . It' a beauty. Splash aprons, 2quarter panels and the back of cab and I will have a full fendered RPU. I hope to give it to my father. It would be a valued vehicle on the vinyard.
  21. louisb
    louisb
    Cool build!
    Thanks,
    —louis
    bct likes this.
  22. Chavezk21
    Chavezk21
    Wow, just discovered your thread. cool stuff going on.
    bct likes this.
  23. trollst
    trollst
    Looking real good garrett, nice work. Gonna have to make it up your way this year, LeRoy.
    bct likes this.
  24. bct
    bct
    thanks for the good words guys. having a hard time getting to the work on the car . huge amounts of snow at the shop . the wet heavy stuff that breaks your equipment and leads to endless work. done my regular job today tho so after I fix my plow I can get on the roadster.
    trollst, Bondo Slinger and dumprat like this.
  25. bct
    bct
    Machined bushing for the big eye sprung. Determined to make it happen. Had a close size of dom just had machine off .125 the od and add .125 to the I'd which I did with bronze 20180201_174757.jpg
    Press fit
    Made longer do dads for my spring spreader
    Works nice
    Stogy and louisb like this.
  26. bct
    bct
    winter fun. There is an rpu and a T roadster with turtle deck under the peak at the rear. Just to the left of the shovel. Sad.
  27. dumprat
    dumprat
    from b.c.
    Wow that ****s! You need stacked Sea cans or something solid to stash all that stuff in.
  28. bct
    bct
    The model A shaft I got is too big. Is there more than one size? AA?
  29. bct
    bct
    Small update . Started to experiment bending hat channel for the sub frame. It distorted a fair amount but seems to work out because the inner bend balances the outer. Just had to straighten the flanges a little and tweak the width. Went better than I thought.
    Took a s**** and tested my joinery.
    Also found this cool merc truck column. I think I will use the jacket as it has signal lights. 20180507_200640.jpg
    Made by Ingersoll Machine. Same as any f100 box internally is what I'm told. 20180507_200720.jpg
    Stogy likes this.
  30. dumprat
    dumprat
    from b.c.
    What does the base of the steering wheel look like? I have a mast like that in old chrome but I need to figure a steering wheel adapter
