Technical Poly 318 Stainless Valves
Discussion in 'The Hokey Ass Message Board' started by vintagetin88, Dec 10, 2017.
  1. vintagetin88
    vintagetin88
    Alright boys and girls.
    Does anyone know where I can find stainless steel exhaust and intake valves for a Chrysler A Poly 318 engine? I'm looking to have harden seats put in and the machine shop is recommending stainless valves. Will LA valves fit?
    Thanks!
  2. Deuces
    Deuces
    Someone here knows.....
  3. stillrunners
    stillrunners
    from dallas
  4. sunbeam
    sunbeam
    Ferrea but they won't be cheap.
  5. vintagetin88
    vintagetin88
    there seems to be a lot of interest in this, but no one has an answer! I guess they don't exist?
  6. squirrel
    from rock auto, exhaust valve dimensions, 1966 318 (poly)
    4 groove; 1.5630" Head Dia.; 0.3715" Stem Dia.; 4.5390" O.A.L.
    from rock auto, exhaust valve dimensions, 1967 318 (LA)
    4 groove; Chrome plated stem; 1.5000" Head Dia.; 0.3865" Stem Dia.; 5.0020" O.A.L
  7. vintagetin88
    vintagetin88
    That's too easy! I guess I can call them and see if they are stainless steel and can handle hardened seats.
  8. squirrel
    You can use normal exhaust valves with hardened seats, can't you?
    Are you working the engine hard enough/long enough to need hardened seats?
    Truckdoctor Andy and sunbeam like this.
  9. swifty
    swifty
    I'm running standard valves with hardened seats in my 318 Poly. Have done 29k miles so far with no problems. I must admit I don't punish it as about 70 is the speed limit here and the govt makes sure you don't exceed it with lots of cameras and highway patrol cops.
  10. Check with Richardson Auto Machine (RAM) in Lynchburg Va. He does a lot of Poly stuff. Gene.
  11. 35desoto
    35desoto
    The LA engine valves do not cross over to the poly ones - there is an overal lenght diference that stops that idea.
    Plus stainless steel valves are not really needed - the std type valves were very well made and once lapped in properly will last many miles. Ma Mopar produced good parts
