Hot Rods Cutting Compound Angles
Discussion in 'The Hokey Ass Message Board' started by Bonehead II, Dec 15, 2017.
  1. Bonehead II
    Bonehead II
    Hi Guys
    I need to cut some compound angles in 2x4 boxed tubing, and I don't want to buy a big cold cut saw. does anyone have some tips or tricks to help me out on this.....Thanks in advance.
    Mike
  2. Bonehead II
    Bonehead II
    Ray....I wanting to build a frame for my '38 plymouth and there will be some compound angles involved, Don't want to run my wood saw with cold cut blade, so looking for another way to cut compound angles.
    Mike
  3. 29moonshine
    29moonshine
    a cut off wheel and a speed square for the angle
    loudbang and Hnstray like this.
  4. Hnstray
    Hnstray
    from Quincy, IL
    I agree with above comment. A cut off wheel and/or a plasma cutter would work. But unless you can borrow a plasma cutter, that would be costly. Cut wheels and tool is relatively inexpensive and useful to have in general.
    Ray
  5. big duece
    big duece
    from kansas
    Can you simulate the compound cut on an wood 2x4, or wood of the size of your 2x4 tube and then transfer the lines with silver pencil to your steel? Then cut your steel with 4" cut of wheel.
    vtx1800, lewk, loudbang and 4 others like this.
  6. jaw22w
    jaw22w
    from Indiana
    I use a Portaband for these kinds of cuts.
    vtx1800, chevy57dude, H380 and 2 others like this.
  7. mr.chevrolet
    mr.chevrolet
    look around locally for a master carpenter, he can show you how to figure out compound cuts.
  8. flt-blk
    flt-blk
    from IL
    If you are looking for how to make the cut, a band saw or cut off wheel is easy
    If you are looking for how to mark the angles, a template in paper wrapped around the stock for mock up is how I do it, you can also buy tools to do the same thing.
  9. Terrible80
    Terrible80
    Wait , compound angles.! Skilsaw with metal cutting blade.
    flatford39 likes this.
  10. choppednslammed
    choppednslammed
    Layout the angle on all 4 sides of the rectangle tubbing and use a cutoff wheel
    1964countrysedan likes this.
  11. Over the years...with care and planning...a Sawzall with a good blade has proven its worth for cutting steel tube in a variety of shapes and angles.
  12. as already said....lay it out on all four sides. then cut it a bit proud with a cutoff wheel , sweeten it up with a grinder
    blowby and Morrisman like this.
  13. Petejoe
    Petejoe
    from Zoar, Ohio
  14. flatheadpete, Petejoe and pitman like this.
  15. tb33anda3rd
    tb33anda3rd
    with good lay out lines [filed or scribed] you can cut the tube "proud" with a torch using a s**** piece for a guide, then grind to the line. just be careful to tilt the torch, on back cuts at the corner.
    31Vicky with a hemi and pitman like this.
  16. nochop
    nochop
    from norcal
    Yup, if you can
  17. Flathead Dave
    Flathead Dave
    from So. Cal.
    Angle and a hack saw. Kidding...
  18. sunbeam
    sunbeam
    Stick the tube in a can of old paint at the angle you want use the paint line as your mark and use a 4" cut off wheel
    '51 Norm, nochop, lewk and 1 other person like this.
  19. Jummimey christmas :p
  20. 49ratfink
    49ratfink
    what was the question?
  21. jaw22w
    jaw22w
    from Indiana
    Neat trick. I have been doing it the hard way all these years. You CAN teach an old dog new tricks!
  22. Bonehead II
    Bonehead II
    Wow I like that Youtube.
  23. pat59
    pat59
    cool beans!
  24. Mr48chev
    A couple of cheap 2x4s would be an inexpensive sacrifice to know you were getting the angles right on the first try. cut the wood and make sure your angles are right and then transfer the angles to the metal and go.
  25. Flathead Dave
    Flathead Dave
    from So. Cal.
    The OP wants to know what tools to use to cut a mitered joint instead of buying a compound miter saw.
    Sent from my SM-G930T using The H.A.M.B. mobile app
  26. Kerrynzl
    Kerrynzl
    He wants to know how to cut a "Compound cut" not a mitre cut without buying a compound miter saw.
    A compound cut is cut at an angle on 2 different planes.
  27. clem
    clem
    Yes that’s what I thought also.
    Angle grinder and guess work is how I would do it on tubing.
  28. I've done it this way, you've really got to want it done.o_O Speed square or good framing square will get it laid out, 4" grinder with cutoff wheels will get the job done.
    Flathead Dave likes this.
  29. Kerrynzl
    Kerrynzl
    I use maths ,a bevel and a scriber to mark everything.
    You need to think in 2 dimensions ,there is 4 x right angle triangles.
    And if maths is not your forte click onto this site.
    http://www.csgnetwork.com/righttricalc.html
    After that , the good ol' 1mm cutoff wheel in a grinder.
