Technical GM metric calipers on an I beam axle
Discussion in 'The Hokey Ass Message Board' started by Kevinsrodshop, Dec 16, 2017.
  1. Kevinsrodshop
    Kevinsrodshop
    I've got some metric calipers mounted on my ch***is engineering axle. I don't understand how the rubber brake line can connect to that caliper without hitting the axle. I've been trying to find another part number caliper that has the rubber line coming out a different direction. I've tried the search function and found some stuff but nothing that really answers my question.
  2. sawbuck
    sawbuck
    from 06492 ct
    i use drums...sorry cant help
    e z i likes this.
  3. Canuck
    Canuck
    Grind a new clearance notch in the caliper for the line about 90 degrees from original to keep the line in place.
    The notch it sits in is just to keep the line in place.
    Canuck
    trollst and RMR&C like this.
  4. lake_harley
    lake_harley
    I take it you don't wish to use AN lines and fittings? There are options of angled fittings and angled hose ends if you could live with braided, AN lines. Some have a black cover, something like shrink tubing, if that would help from a cosmetic perspective.
    Lynn
  5. Mr T body
    Mr T body
    Alliance Vendor
    from BHC AZ
    I used 45* banjo to AN fittings and they worked great. 90* banjo fittings just won't clear the housing.
  6. krylon32
    krylon32
    from Nebraska
    I just mounted a pair and ground the side edge off so the lines point toward the frame.
    RMR&C likes this.
  7. fordor41
    fordor41
    I used a banjo bolts and flex lines from speedway. they have different lengths and they cleared everything
  8. Kevinsrodshop
    Kevinsrodshop
    Thanks for the replies. I'll look into either grinding the caliper or going with the AN fittings.
