home made tools and equipment...
Discussion in 'The Hokey Ass Message Board' started by kustombuilder, Jan 16, 2008.
  1. gatz
    gatz
    Good idea
    tb33anda3rd and pat59 like this.
  2. 56don
    56don
    I love these simple but useful tips.
  3. toreadorxlt
    toreadorxlt
    from Nashua, NH
    got my machine running
    toprodz, brEad, whtbaron and 16 others like this.
  4. jackalope
    jackalope
    Hell yeah!!! That is an awesome job you did there!! Great work!
    toreadorxlt likes this.
  5. Jethro
    Jethro
    We are not worthy!..I bow to you!
  6. JOYFLEA
    JOYFLEA
    When you going to start mine ? Did a great job . Blue
  7. MrMike
    MrMike
    Nice job on the homemade pullmax, I didn't see what you were using for an on/off switch, might look at a foot switch ,very nice for when you need two hands for the stock.
    loudbang and toreadorxlt like this.
  8. Inked Monkey
    Inked Monkey
    Nothing fancy but very useful. Bolt with two flathead nuts welded together. Used to install head studs.
    blowby, loudbang and JOYFLEA like this.
  9. 1953naegle
    1953naegle
    Excellent job on the pullmax!
  10. Koz
    Koz
    Finally finished my English wheel. Using the Ebay off shore wheel and anvils until I can get the Hosier Profiles, hopefully in January. Works extremely well. Panels are absolutely track free and there is less than .002 deflection with 500lbs. applied to the throat. It weighs in at a tad over 900lbs. and has ports to fill the frame with sand when I build a power hammer off the right side. The gibs are bronze lined and can be set to zero tolerance. I've been using friends wheels for the last five years or so since I sold my last one to Homemadehardtop57. Nice to be able to just step over and shape what I need.
  11. jackalope
    jackalope
    Very nice EWheel!! I can see your casters bending the plate they’re welded to upwards over time but super nice build. Great job!
  12. 1946caddy
    1946caddy
    from washington
    Saw the thread about HF engine levelers and I though I would show one I build about ten years ago. They locked the other thread down so I'm putting it here. The patina was gotten by laying it in the corner of the garage after it got wet I think.
    WP_20171123_18_36_58_Pro.jpg WP_20171123_18_37_27_Pro.jpg WP_20171123_18_37_45_Pro.jpg WP_20171123_18_37_56_Pro.jpg
  13. biggeorge
    biggeorge
    That does it!! Now we all want one.
    Nice work
  14. HarryT
    HarryT
  15. mikeyyeah
    mikeyyeah
    So much inspiration in this thread. iv e got a few home made things here but definitely nothing thats up to par with what some of you guys are up to.
  16. paint-boy
    paint-boy
    from Hector, MN
    I recently designed and built this fully adjustable body cart
    4C78302A-F18C-49FC-86E9-F0C894B05BA1.jpeg 9DCDF67B-DA01-4408-A07A-CCB88F9F7E2E.jpeg CF1BD571-04B8-485B-BCF0-EEDE504C5AB1.jpeg D943A9FA-F60F-4DF8-872C-6A0AAD258B27.jpeg
    55Deso, brEad, wackdaddy and 15 others like this.
  17. ROADSTER1927
    ROADSTER1927
    That looks Great! Gary
  18. Dyce
    Dyce
    I don't think I posted this here yet. It' a modified vice grip I made to spread. I used it today on my fender. 20171129_112039.jpg 20171129_112016.jpg I have a shorter one too.
    BradinNC, 18n57, brEad and 13 others like this.
  19. spurgeonforge
    spurgeonforge
    Great idea!
  20. Fortunateson
    Fortunateson
  21. jackalope
    jackalope
    loudbang, JOYFLEA and Dyce like this.
  22. wibble_1979
    wibble_1979
    [​IMG][​IMG]
    had to drill out exhaust studs on an aluminum head. tried welding nuts to what was left of the stud. was melting the flange surface. hokey drill jig did the trick.
    Sent from my SM-G930V using The H.A.M.B. mobile app
  23. paint-boy
    paint-boy
    from Hector, MN
    It was just a random green out of my color deck. I went back and looked up wat it was.
    Electric Green Met.
    Ford color: code SW (useage was like 1999-2003?)
    PPG code: 5492
  24. whtbaron
    whtbaron
    from manitoba
    Oh please... I posted a couple broken bolts with a hole drilled through them... surely your stuff can't be any more basic than that? Share your ideas, that's what sparks the ingenuity that creates even better ideas. Sometimes the simplest of simple tools can be very useful and time saving. I built this ******* last Friday nite on a whim... by Monday morning I had a job sitting in the shop that needed it. At first I didn't like it, too stiff because it was made from a main leaf, but I did like the extra weight and shape of the spring eye (something the purchased versions don't have). Rusty chunk of leaf spring and a worn out shovel handle... not exactly rocket science...
    4 "too short" copper rivets countersunk into the handle that was sliced in the center make it work. Note I retained the rusty **** look....errrr..... "proper patina" for working on vintage iron... That eye is great for working the back of vintage fenders or f'd up trailer fenders that got too close to a front end loader...I call it the super *******. When I ran into Gene Winfield at World of Wheels, he was raving about a shiny version from Eastwood.
    loudbang, bct, tb33anda3rd and 4 others like this.
  25. WZ JUNK
    WZ JUNK
    from Neosho, MO
    I have not looked through all of this thread, but most of it. If I am duplicating I apologize in advance.
    Here is something I built in the past but I modified last week. It is an attachment for my pressure washer that enables the operator to stand beside the vehicle and wash the underside. It solves two problems for me, having a clean vehicle to work on, and standing instead of bending over or laying down. It originally had a skid plate but last week I added the wheels. This is an important feature as it keeps the device from turning sideways from the intended direction. Trying to hold on to a pressure washer wand that is turned at 90 degrees is like something from a 3 Stooges film.
    John
    Dyce, jeffd1988, brEad and 17 others like this.
  26. The 39 guy
    The 39 guy
    Great idea WZJUNK! I think that would be a great idea for those Bonneville guys to use when they get their Hot Rod home for the Salt flats.
    loudbang, tb33anda3rd and RMR&C like this.
  27. Jethro
    Jethro
    We made something like that at the fire station to clean under the trucks in the winter. Gets the salt and mud off without crawling underneath. Keeps the pump clean for the mechanics.
    J53, 62hotcat and loudbang like this.
  28. jaygryph
    jaygryph
    Hey neat, I have that same craftsman vice.
    Usually most of my home made tools have been things to work on Corvairs. Somewhere around here is dads bent up wrench that's just perfect for adjusting the alternator and whatnot on a Corvair engine.
  29. Bandit Billy
    Bandit Billy
    You should sell these at Bonneville. :cool:
    jackalope and loudbang like this.
  30. Picture1227171847_1.jpg Picture1227171846_1.jpg Picture1227171846_1.2.jpg
    Made this to go on my brake. Bends the radius on the top of race car door panels
