Projects De ratting a model a
Discussion in 'The Hokey Ass Message Board' started by JOYFLEA, Oct 9, 2017.
  1. JOYFLEA
    JOYFLEA
    Thanks Fabber , I’m kinda like Tim the toolman Taylor . Never met a tool I didn’t like . I use TO have a metal fabrication and ac co. Wish I still had all the tools and equipment I had then , but I would need a shop that was so big I could not afford the electric bill . LOL Now I have enough to get by on . Building a 10 ton press for doing louvres , dimpled dies and such . Building the frame work now . But I promised this would be the last .
    chryslerfan55, enloe and Stogy like this.
  2. JOYFLEA
    JOYFLEA
    So this is the third cold day . We had 5” of snow yesterday and another 3 last night . Had to go out and work in the shop today . My wiring harness came in yesterday and started trying to figure out where to put it . Since there’s not a lot of room behind the dash and since I had an old 41-46 gmc dash and I’ve got a saw .........
    Started cutting and fitting it up to the trim piece I had . 60 in my work shop and 26 where the car is , I decided try to make a decent gauge holder and have enough room for my fuse box .
    Got it roughed in but need to do some planishing on the weld area and to curve the top edge up to match 29 trim . Then I will weld the two together.
    Photo of snow is my back yard this morn 8 degrees. Blue
    E6CCE71D-60D8-4B0D-A0B2-6ABF5F06ACD6.jpeg 6366C801-1A47-4F0C-B9BE-BAEB44D86598.jpeg 7B897F7B-23FA-4BD1-891C-258185FBB0F1.jpeg
  3. Mikel50
    Mikel50
    Crazy you Texans have snow before us up here in M***.
    Your car looks beautiful, fantastic work. !! I read your thread very early on.
    I’ve got some catching up to do !
    Mike
    JOYFLEA likes this.
  4. Fabber McGee
    Fabber McGee
    8 degrees is probably as hard on you hot country boys as 115 would be on me. I consider 65 about perfect shop temperature for working, bench racing however is better at 75 to 80, haha. Makes the cold beer taste better.
    BTW, 33 degrees in Fairbanks, Alaska this morning (that's above zero, haha).
  5. JOYFLEA
    JOYFLEA
    I know you all think I fell off the world . Finished up the dash . Had to pie cut the ends . I need to mount it to the A dash but waiting on dash insert to get here to make sure I don’t have some warping I don’t know about .
    Been cold in the shop so I just got the seam sealer down in rear and some soundproofing installed. My wiring system came in so I will start laying out to the rear . All this has got to be done before I can mount the fuel tank .
    Was out of town last week but did get my tubes cut for my press . 4x4 3/8 . Going to be cold on Friday and Saturday, so I will weld it up on those two days . In the mean time I will get the wiring partway done and when my e brake comes in I will finish out the floor and start the interior. Blue
    AD27E4B9-CDB4-4A07-B52E-DAFC35226BDD.jpeg A7D3E4AC-5CCE-46E2-BFC5-C993A14364B4.jpeg 4FA76550-7598-44D0-A490-00CBB77A5F26.jpeg 78A46016-B6B7-4165-BDD8-17531622ABB3.jpeg 01677BF4-CC35-47AE-9ABC-AC0260A54D47.jpeg
  6. Fabber McGee
    Fabber McGee
    Hard to view your drawing, but 4 x4 x3/8 otter limit deflection pretty well I would think.
    golferforpar and JOYFLEA like this.
  7. JOYFLEA
    JOYFLEA
    Got started on my wiring Thursday and got the new fuse panel in place after ripping out the old stuff . Started trying out different ways to run it . Really needed my work bench that was covered in steel so I roughed in my press frame today . Had to build it in place because I didn’t figure I could lift it an d put it where it goes . All tacked in and started welding it in when I started getting some pros. In the weld . Couldn’t figure out why sine I cleaned the area well ? Found a big old ****** in cup , wasn’t getting the gas I needed . Will get the parts I need Tuesday. Will make my angle braces on Christmas Day . Fabber hope this gives you a better idea.
    Working on wiring tomorrow. Merry Christmas everyone!
    Blue
    5B04F9C4-4C83-4687-A6EB-1E1C8020EA55.jpeg 46933DD4-077F-4F48-9C7E-D8EFBC6DC092.jpeg 130B1CA7-2CFD-4E64-8F48-2CC5C368992A.jpeg 9DF0F8E5-AB8E-4252-B1C4-F2A7D79BF1C7.jpeg 523AD474-A4C2-4818-9ED5-916846EDC244.jpeg C2F6BCA2-91A0-462E-891F-738152975077.jpeg 074506DF-0A39-4716-80D5-B01B74D72C55.jpeg A84D023B-64E9-45FE-8698-31EB8CF5E373.jpeg C0ECF215-2961-4FC0-989C-98656CF6726E.jpeg 5B4F9559-B4D4-4B01-A0D8-63621F46D7CE.jpeg
  8. enloe
    enloe
    from east , tn.
    Merry Christmas Blue
    JOYFLEA likes this.
  9. JOYFLEA
    JOYFLEA
    Merry Christmas to you and yours , Enloe .
    enloe and chryslerfan55 like this.
  10. Fabber McGee
    Fabber McGee
    Nice job, you're gonna keep messing around til you need more floor space, haha. Hope you have a great Christmas, I think I'll take the day off. Spent the past couple days building a Grinch nearly 7 feet tall. Hope to have his skin on before midnight.
    JOYFLEA and chryslerfan55 like this.
  11. JOYFLEA
    JOYFLEA
    Spent 4 hours in front of the blast cabinet this morning , boring . Rode my 49 HD to town for lunch . When I got back it was 80 degrees so sprayed some epoxy primer on dash and other interior parts . Will do a little filler work in morn . and wiring in afternoon. Thursday may be warm enough to paint dash . May have her running again by end of next week . Blue
    chryslerfan55 and brEad like this.
  12. JOYFLEA
    JOYFLEA
    Nice and warm last two days . Put 4 coats of filler primer on dash yesterday without any body filler . Did a good sanding on it today and I thought it looked fine for a hot rod . I had done some metal finishing on the welded areas . So mixed up some PPG black and shot the dash and some trim out in front yard . Wind is coming up so I moved the parts into shop . Would have liked to let it dry out in the solar paint both . Photos not to good because of the black on top of the boards which are now black also . Should look great when mounted and trimmed . Will blast my headers then paint tomorrow , going to be in 70s tomorrow also . Latter Blue .
    D72A5D97-C714-42FB-838F-2BF50D698D5E.jpeg 2303B01A-BDAD-4A49-96CB-720D6EFFFA5B.jpeg FBC4C57D-D0A7-4147-A013-6F9EC1D6997C.jpeg DBCA2CA9-1E97-405C-9CDE-D1F8AF4FC4BD.jpeg
    Tim_with_a_T, loudbang, enloe and 4 others like this.
  13. brEad
    brEad
    Dash looks good! I'm jealous of your temps! Been cold here. Happy New Years!
    JOYFLEA likes this.
  14. Patrick46
    Patrick46
    Great build! Got me motivated to get out into the shop and get some work done to my truck project!
    need to see a pick of your COE & '49 FL
    JOYFLEA likes this.
  15. shopdawg
    shopdawg
    from alberta
    Looking great Blue! I too have been sanding and like you hate it. No hurry here so planning a trip to the GNRS at the end of Jan. Will have to meet up somewhere with the c.o.e.'s in 2018.
    chryslerfan55 and JOYFLEA like this.
  16. JOYFLEA
    JOYFLEA
    Patrick , you can see the COE on my build tread below , a couple of our pans on there also . Here’s one down in the park for lunch in the past and the wife’s 57 on the front porch . Blue
    28787592-4C56-41F8-BDDF-68C5F795DA86.jpeg 35E37C29-6847-4E26-8CAF-73855F5357FA.jpeg
  17. Patrick46
    Patrick46
    Nice!!!
    I'm an old knuckle rider myself
    (I was a bit younger back then)
    Now I ride an EVO chopper and bagger
  18. JOYFLEA
    JOYFLEA
    1C933D56-3EFB-4062-91D1-B1E8CEB80395.jpeg Had a few knuckles myself . Down to 6 MCs .
    Slow down, enloe, Patrick46 and 3 others like this.
  19. deathrowdave
    deathrowdave
    from NKy
    I have done same “ crazy” stunts years ago . Today recovery time is multiplied by 20 fold . Just a simple ride on the hand jamer is near tops on the physical ability anymore . All my bros are on me daily “ you need a newer scooter “ . My answer is if I can’t ride my old tin I don’t need to ride anymore . That old stuff is part of America , I’m proud to keep the memories sharp in everyone’s mind .
    chryslerfan55, loudbang and JOYFLEA like this.
  20. trey32
    trey32
    Snow to 80 degrees in two weeks, damn...
  21. brg404
    brg404
    Temp swings like this just confirm the old saying "Theres nothing between Texas and Canada but barbed wire..." Looks like it will be down to the 20s next week in the hill country.
    I really like what you have done with your Model A, turned into a little bit more than just taking out the rebar and license plate floorboards :)
  22. JOYFLEA
    JOYFLEA
    Yep . I opened a can of worms . Can’t leave things alone . 82 today ,20 tomorrow night . Welcome to Texas .
  23. enloe
    enloe
    from east , tn.
    Man I still want one of those Pans. I still have my Shovelhead
  24. JOYFLEA
    JOYFLEA
    Thanks for all the feed back . It’s time to get off the motorcycles before we get shut down . Now back to our regular program .
    I insulated the back of the body today and will finish tomorrow so I can get all the wiring done so I can mount the gas tank , fuel pump , and battery . Hope to get it back running next week . Plans are to start the beadrolled interior then .
    Tune in then or as you use to hear : Same bat time , same bat station.
    Happy New Year to everyone !
    Blue
  25. Hey Blue, I've been following along since you started the "A" but got a little behind this month. I didn't see that you've committed to a p***enger seat solution so if that is true, have a peak at the p***enger seat mounts in a 1960-66 Suburban or 1947-64 Willys Wagon. They are similar to one another and provide reasonable back seat access. With your skills you could "adapt" the principal to your build.
    Happy New Year, and keep on truckin!
  26. JOYFLEA
    JOYFLEA
    Don’t have much head room so I cut the adjusters as low as possible and welded a nut up and down on the front , screwed a hemi joint on and will put a simple bracket down to floor . Think it will work fine . Thanks for info , will keep it mine .
    72 at 10:30 at 11 it was 38 with the wind screaming like a banshee. Good day to start a fire and drink a Jack this afternoon and watch football .
  27. JOYFLEA
    JOYFLEA
    Finished the press frame in the last two cold days . Warmer today so I painted it and will mount the press head and set up the dies in the morning and maybe knock out a louvre or two .
    Will be back on the A in the afternoon and try to finish up the wiring. Here a hint of what the dash will look like . Not real hot on the polished Al. but will keep it for a while . Can always paint it or scuff it up . Blue
    74090067-47ED-4B0E-9BE3-99A472611BE5.jpeg A06C2F1F-EBA8-4A1A-AD0A-6F5616AEBE56.jpeg 5161F4E9-626C-400B-84DE-2E18087E08F3.jpeg 41ADEFF7-FE0C-4042-9244-E7296139FC69.jpeg
  28. JOYFLEA
    JOYFLEA
    Finished my press and did some test louvres, worked great . Only took about 2 minuets to do . Can’t wait to try some of my other dies .
    Got back on the wiring and trying to figure out some location for things to mount on the A .
    Will be back on it in morning. Blue
    6F9E2D98-8BEE-4F90-90E0-46F32C15FD4A.jpeg 3E362F39-83CC-4DB5-92F9-141A6F890008.jpeg 8084BCF5-F293-43F2-8AE3-A4E6A3E54DAA.jpeg
  29. Fabber McGee
    Fabber McGee
    Aw Geez, I hope you haven't created a mad man. Let's see now, the sedan doesn't have air, so it will need at least 4 rows of louvers the full length of both sides.... no, no, no, you can't louver the gl***, or the gas tanks of them bikes.
    brEad, chryslerfan55 and JOYFLEA like this.
  30. Fabber McGee
    Fabber McGee
    Doesn't look like it distorts the panel much. How big are they, about 1 x 3, huh? What other dies did you get?
