Projects 1964 Falcon B/FX Build Thread
Discussion in 'The Hokey Ass Message Board' started by fiveoh108, Nov 29, 2011.
  1. saltflats
    saltflats
    from Missouri
    Hell Yeah!!!!
    loudbang and fiveoh108 like this.
  2. Gammz
    Gammz
    from Lincoln Ne
    Dear lord!!!!!
  3. Gray Ford
    Gray Ford
    from Illinois
  4. Johnboy34
    Johnboy34
    from Seattle,Wa
    BAD A$$ !!! Your excitement level must be over the moon by now! Thanks for throwing this up!
  5. Nailhead Jason
    Nailhead Jason
    Just read the CK Deluxe article. That thing looks killer man. That steering wheel looks dam good in there too!!
  6. lothiandon1940
    lothiandon1940
  7. loudbang
    Hell yeah awesome FORD FE POWER.
    1947knuck and fiveoh108 like this.
  8. Jimbo17
    Jimbo17
  9. lothiandon1940
    lothiandon1940
  10. fiveoh108
    fiveoh108
  11. fiveoh108
    fiveoh108
    My Dad and I got the motor and transmission in today. Still a lot to do, but a step in the right direction[​IMG][​IMG][​IMG][​IMG]
  12. cowboyinachair
    cowboyinachair
    from colorado
    why are the carbs on backwards
  13. The earlier ones were backwards. These are correct for High Riser..Take a look at some Thunderbolts. ;)
  14. fiveoh108
    fiveoh108
    There's a couple different reasons.. 1) if you mount them backwards, the primary throttle bores are over the center holes on a dual quad. 2) for figment, forwards they hit the distributor more than they do backwards. I need a small carb spacer or crab cap to clear it.
    loudbang and Gammz like this.
  15. porkshop
    porkshop
    from Clovis Ca
    Looking awesome Mike......
  16. Gammz
    Gammz
    from Lincoln Ne
    The removable rad support looks like it made the install go pretty slick.
    Nice job man!
  17. BadgeZ28
    BadgeZ28
    from Oregon
    Got a question. It looks like there are vacuum ports on top of the secondary vacuum housing. What are these ports for? I thought they got vacuum from the carb body?
  18. fiveoh108
    fiveoh108
    Removable bolt in core support support makes it easy! I highly recommend this modification. (Thank you Dale Snoke)[​IMG][​IMG]
    OahuEli, mgtstumpy, saltflats and 2 others like this.
  19. fiveoh108
    fiveoh108
    A single piece of vacuum hose will connect the two ports, it's just to hopefully balance the vacuum signal between both carbs.
    saltflats and loudbang like this.
  20. loudbang
    Looking good Roy would approve it. :)
  21. fiveoh108
    fiveoh108
    Looks like the hood will fit with an inch of clearance[​IMG][​IMG][​IMG][​IMG]
  22. loudbang
    Better watch out those move so much air it may **** that hood right down on them LOL. :eek:
    1947knuck, Tickety Boo and porkshop like this.
  23. fiveoh108
    fiveoh108
    Trying to figure out the pulley situation. The ATI balancer is only drilled for a BBC crank pulley, so I have to try and find a BBC pulley and match it to a Ford waterpump pulley. Then to an alternator pulley!
  24. saltflats
    saltflats
    from Missouri
    Braze a bbc pulley flange to your ford pulley.
  25. deathrowdave
    deathrowdave
    from NKy
    Great job ! Keep the old Fords alive !
  26. fiveoh108
    fiveoh108
    I am either going to oval out the holes on a Ford pulley , they are like an 1/8" off or just try BBC pulley. I think I can make it work. I got a lot of wiring to do, I am excited to get that new Aeromotive fuel tank hooked up.
    Anyone have experience with pushlock hoses vs the steal braid?
  27. Johnboy34
    Johnboy34
    from Seattle,Wa
    A giant step for...... oh heck, looks awesome! Is that sanding dust inside the hood? Wouldn't want it to eat that. ;)
  28. fiveoh108
    fiveoh108
    Lots of mocking up to do still before everything is on for final fit. I will definitely blow all that junk out before it gets fired!
  29. fiveoh108
    fiveoh108
    Been working on getting the right amount of end play between the torque converter and flywheel. It was about an 1/8" out of spec so I had to get some washers to take up some space. Also working on the starter engagement spec to make sure it will mesh with the flywheel correctly. A P.A bellhousing, ATI flywheel, Ford block and RobbMc starter, what could go wrong lol
    Went back and forth, but decided to paint the radiator black, looks cleaner[​IMG]
    Also got a new clockable starter from RobbMc, should get the job done[​IMG]
  30. loudbang
    Black does look better. :)
    1947knuck, fiveoh108 and Finn Jensen like this.
