Technical 32 3 window . Chop chop chop .
Discussion in 'Traditional Hot Rods' started by Flop, Sep 17, 2017.
  1. Flop
    Flop
    Thanks guys !
    Fitting door tops today then a soak in vinegar to get the ******* galvanization off .
    Woogeroo, mgtstumpy, Stogy and 4 others like this.
  2. krylon32
    krylon32
    from Nebraska
    I've sold a couple of Brookville 3 windows, I didn't pay any attention to the fact that they were galvanized?
  3. K13
    K13
    Looks great Tom!
  4. Runnin shine
    Runnin shine
    Flop is this basically the same chop as Ben’s car? It definitely seems cut down into the cool zone.
  5. GeeRam
    GeeRam
    My Brookville 3w body/doors definately isn't galvanised......:confused:
  6. Flop
    Flop
    Numbers are different .
  7. Flop
    Flop
    Thanks folks !
    Nice and easy just like chopping a model a [emoji136][emoji136][emoji136]
    Stogy, jackalope, Woogeroo and 5 others like this.
  8. Ralph Moore
    Ralph Moore
    How low can you go?
    You make it look so easy, but we all know its
  9. pumpman
    pumpman
    Damn, there's a lot of stuff going on in that close up Flop.
    clem, jackalope and Flop like this.
  10. Emperor Chris
    Emperor Chris
    I love it
    Flop likes this.
  11. Flop
    Flop
    Did some things different this time around and very happy with it .
    chop job, Outback, Fern 54 and 8 others like this.
  12. brady1929
    brady1929
  13. spurgeonforge
    spurgeonforge
    Wow! Looks awesome!
  14. choptop40
    choptop40
    Chopped a 36 Buick 3 window..forced the b pillar roof section , when I cut out the bracing , I heard a bang.door gap was way off....recut the b pillar and relief cuts...etc...great job ..
  15. big duece
    big duece
    from kansas
    I have heard too, that the doors were galvanized. Even some pics show them to have a more silver like finish, compared to the bare metal body.
    Stogy, Flop and The37Kid like this.
  16. Flop
    Flop
    Last 3 I did had galvanized dooors and decklids . And one had the rear window panel galvanized .
  17. Flop
    Flop
    chop job, Outback, Fern 54 and 6 others like this.
  18. big duece
    big duece
    from kansas
    Have you noticed any of the welds more brittle on panels that have been galvanized? I know you strip the "to be welded" area first. That's a hazard in itself...
  19. Flop
    Flop
    Not that I’ve noticed .
  20. alchemy
    alchemy
    Could it maybe be aluminized like exhaust tubing is? Usually a thinner coating, and easier to weld. Plus welding on it won't kill you like welding on galvanized steel will.
    Flop likes this.
  21. Flop
    Flop
    No this is straight up white floaty things in the air and ruining gas lenses like it’s going out of style with all the **** popping back when you start an arc .
    brEad likes this.
  22. the only visual defect with 32 Ford coupes is the roof height
    nice correction
    deathrowdave likes this.
  23. 1-SHOT
    1-SHOT
    from Denton
    You could call Brookville to confirm?
    Flop likes this.
  24. Flop
    Flop
    For what reason ? If it welds like galv smells like galv puts white things in the air like galv it’s a good chance it’s galv . Wear your respirator remove as much as ya can and weld away .
  25. Happydaze
    Happydaze
    It's not galvanised fellas, it's zinc coated. Galvanising is a hot dip process. This stuff is I think a plating process. In the uk it's called Zintec, but that might be a brand. It has a uniform surface finish, unlike galvanising, and it is a very light coating which doesn't take much to remove for welding. It's the stuff that many / most modern cars are made of. My Brookville 3w has the 2 doors and the trunk lid made of it. Presumably they didn't make the whole body out of it for the problems in welding it? I dunno.
    Chris
  26. Last edited: Dec 28, 2017
  27. Double like
  28. trey32
    trey32
    This seems like it's skewing from the point.
    I don't give a **** what it's coated in.
    Flop keep on it, **** looks amazing.
    I hope you could chop my 34, galvanized or not...
  29. Sweet & Low
    Sweet & Low
    Oh Man!!! LOVE the chop as well as the quality. Looking at the two different pics of the chopped 3W 's. It went from a COOL Hot Rod to Double Down Bad *** Looking Hot Rod.
    Keep up the great work. Its' a ******** work of art on wheels.
    Flop likes this.
  30. Flop
    Flop
