Projects 33 Terraplane
Discussion in 'Traditional Hot Rods' started by 33essex, Aug 24, 2015.
  1. 32 hudson
    32 hudson
    Your looking good !
    6inarow likes this.
  2. 33essex
    33essex
    Did some work on the the car today. Not a whole lot but some I put the transmission and engine together . I have for mocking up and set in car getting ready to do the front suspension. Yes that is the engine crane I robbed the flat stock from. IMG_20171217_162151.jpg IMG_20171217_162241.jpg IMG_20171217_162225.jpg IMG_20171217_162214.jpg IMG_20171217_162259.jpg View attachment 3748642 IMG_20171217_162126.jpg IMG_20171217_162259.jpg IMG_20171217_162214.jpg IMG_20171217_162241.jpg
  3. 32 hudson
    32 hudson
    Nice !!!!!!
  4. 33essex
    33essex
    Here we are another day of working on the car. This is what I got done today. I cut front frame horns off welded on new ones. I also finished boxing the frame rails. Tomorrow will be putting cross member in and motor mounts. IMG_20171223_103916.jpg IMG_20171223_105257.jpg IMG_20171223_105303.jpg IMG_20171223_105313.jpg IMG_20171223_192117.jpg IMG_20171223_192134.jpg IMG_20171223_192147.jpg IMG_20171223_192203.jpg
  5. You have more light in your garage than Howard T has. your doing a marvelous job. Looks good.
  6. 33essex
    33essex
    Well got the cross member in and motor mounts in just got to box them. I still got to build a transmission cross member. Then it's on to putting the front end together. I did get the front end just sitting there. I wanted to see how things were going to look. IMG_20171224_145812.jpg IMG_20171224_145833.jpg IMG_20171224_145848.jpg IMG_20171224_145910.jpg IMG_20171224_145934.jpg
  7. 33essex
    33essex
    Today I built the transmission cross member. I got it all built and started thinking about the wood sawhorses.:eek: That everything is sitting on and the fact. I keep adding more and more weight. So I fixed the sawhorse situation by putting the casters on the frame rack. Tomorrow will be cleaning up the huge mess I made.:rolleyes: IMG_20171230_142942.jpg IMG_20171230_142951.jpg IMG_20171230_154633.jpg IMG_20171230_154821.jpg IMG_20171230_154723.jpg IMG_20171230_154909.jpg IMG_20171230_212549.jpg IMG_20171230_212642.jpg IMG_20171230_212604.jpg IMG_20171230_212627.jpg
  8. alanp561
    alanp561
    I have the opportunity to buy an Es*** frame like yours and I want to do what you did with the front cross member. What do you think of using semi-elliptical springs in the rear? There is that great stock kick in the frame and it just seems to me that would be a simple thing to do.
  9. alanp561
    alanp561
    Where did you get the replacement frame horns? Where I found the frame I'm looking at has several whole Es*** coupes and sedans but I don't want to buy a whole car and destroy another frame to repair this one.
  10. 33essex
    33essex
    Yes you are right the frame dose have a really good kick up in the rear. As far as semi-elliptical springs. I don't see any reason you can't. I like 4 links and have had good luck with them. That's why I built the 4 link. The frame horns I lucked on to them at a swap meet. I was told they were cut off a aftermarket frame.
  11. 33essex
    33essex
    Today I got the shop clean and started putting the front suspension together. IMG_20171231_181332.jpg IMG_20171231_181319.jpg IMG_20171231_181307.jpg IMG_20171231_181242.jpg
    bigblockfordman likes this.
  12. Runnin shine
    Runnin shine
    Without me going back through the complete thread again do you mind replying to... do you have the corresponding grill shell to the body or do you have other plans?
    I can’t remember if this was discussed already.
    Wyatt
  13. 33essex
    33essex
    Sure I do have a grill shell. I have the correct grill shell,but no grill. I have been trying to find one. If not I will just make a grill. terraplane65.jpg terraplane64.jpg
    brEad, kidcampbell71 and Runnin shine like this.
  14. alanp561
    alanp561
    What's your wheelbase going to be?
  15. 33essex
    33essex
    Did some more work on the car today. I had to notch the frame in the front. Spring was going to hit. I also made a spreader bar. Then I got side tracked and built a paper towel holder.:rolleyes: IMG_20180106_163535.jpg IMG_20180106_164759.jpg IMG_20180106_203141.jpg IMG_20180106_203154.jpg IMG_20180106_194807.jpg IMG_20180106_194758.jpg IMG_20180106_194923.jpg
  16. Having helped my father build a 35 Terraplane ( a.k.a terrible pain) for my uncle. I can honestly say I commend you sir. Great work.
    tb33anda3rd likes this.
  17. Crazybillybob
    Crazybillybob
    from Ohio
    I have a buddy that has a 37 terraplane Grill and shell he's looking to sell. I'm not sure if it is the same on the 33 or if/when they changed. I know they're not cheap if you can find them... like hen's teeth. Let me know if your interested. I can PM some photos.
    Love the work your doing.
    CBB
  18. Peanut 1959
    Peanut 1959
    1933 vs 1937 Terraplane grilles:
    [​IMG][​IMG]
    mcnally351 and kidcampbell71 like this.
  19. Crazybillybob
    Crazybillybob
    from Ohio
    Thanks Peanut for the comparison. The one my buddy's got isn't going to work. But if anyone's looking for a 37 Grill let me know ;) I will shut up and return to the back of the cl*** and watch the magic happen on this 33!
    CBB
    brEad and Peanut 1959 like this.
  20. Peanut 1959
    Peanut 1959
    No problem! I wasn't sure how much they'd changed until I searched. :)
  21. 33essex
    33essex
    I figured it would sort it self out. I do have a grill shell just no grill insert. There are pics in post 133 and further back in thread.:)
  22. Crazybillybob
    Crazybillybob
    from Ohio
    Depending on the size you might be able to get away with modifying a 32 ford Grill to fit your shell. They look similar. But it might be less work to just make your own. Based on the other work in thread 33es*** has the skills for that.
  23. Runnin shine
    Runnin shine
    I think it’s closer to a 33-34 ford. Good luck with either as they’re both not cheap.
    Probably better of to start tig welding some stainless strips together yourself.
    I flattened small stainless tube on the flat part of my bead roller dies. You maybe could calculate how big of tube(maybe 1/2”) to partially flatten(think oval track) and cut down the middle “straightaways” and get 2 grill bars from each piece. Do you have a band saw? Not that stainless is fun to cut. If you wanted to paint the grill bars just use mild steel right.
    brEad likes this.
  24. Peanut 1959
    Peanut 1959
    Maybe there's a local vocational school with a welding cl***? One of the students would surely take that on as a cl*** project.
  25. 33essex
    33essex
    When it comes time. I'm going to buy some stainless round stock and make one.
    Peanut 1959 and tb33anda3rd like this.
  26. 392
    392
    33es*** I made one years ago using stainless filler rod. It was ok but it just didn't have the look like a wider bar. More of a waste of time but had fun.
  27. Another build thread I stumbled across
    glad I did!....Excellent work!...just love seeing all the creativity and hands on
    building....as opposed to "those" that have there work done by somebody else
    I'm also very partial to all the "oddball"
    makes and daring to be different!
    I'll bet your glad to have your shop now too!....looks good from your pics!
    I think your idea to put a nailhead in was spot on....too many rods with the usual sbc....but I also understand about what one can afford, to!....subscribed for sure!.....keep up the fantastic work!!
    Sent from my LGMS210 using The H.A.M.B. mobile app
  28. 33essex
    33essex
    It will be around 110 inch wheel base. Give or take a little.
  29. alanp561
    alanp561
  30. 33essex
    33essex
    Finally got around to doing some more work on the car. I started building the floor. I got the tunnel built and left and right front floor boards done. IMG_20180408_181029.jpg IMG_20180408_180910.jpg IMG_20180408_181011.jpg IMG_20180408_181451.jpg IMG_20180408_181059.jpg IMG_20180408_181420.jpg
