My Fiat Topolino is a Flip Top now
Discussion in 'The Hokey Ass Message Board' started by fiat gasser, Nov 26, 2009.
  1. TFoch
    TFoch
    Everything seem to be working well? It's cool to see you driving it. It's come a long way!
    Tom
    WDobos, loudbang and fiat gasser like this.
  2. fiat gasser
    fiat gasser
    [​IMG] A little elbow grease and a little ingenuity to put a nice shine on the old Indy Mags.[emoji1]
    Sent from my SM-G900V using The H.A.M.B. mobile app
    WDobos, swade41, mad mikey and 2 others like this.
  3. fiat gasser
    fiat gasser
    WDobos, mad mikey and TFoch like this.
  4. loudbang
  5. TFoch
    TFoch
    Almost time to put it away for the season. Any plans for over the winter?
    fiat gasser likes this.
  6. mad mikey
    mad mikey
    I can not express how fantastic the car looks and sounds. You have got to be very proud of her. This has been a lot of fun watching this build. Thanks for taking us along for the ride. Mike.
    fiat gasser, loudbang and TFoch like this.
  7. fiat gasser
    fiat gasser
    I have a few things planned. One is to finish wiring lights and directional's, try and address some carb issues and add a triangulated locator bar of the bottom of the rear end housing out to each side of the frame so the rear doesn't move from side to side under the car.
    WDobos, TFoch and loudbang like this.
  8. fiat gasser
    fiat gasser
    Thanks Mike. I am very proud of it. Driving it up and down the street was a blast. When things slow down with work this winter I will be diving in to finish it up.
  9. loudbang
    So maybe NEXT year we will get to see some runs :rolleyes:
    TFoch, fiat gasser and mad mikey like this.
  10. fiat gasser
    fiat gasser
    Absolutely [emoji1]
    mad mikey, TFoch and loudbang like this.
  11. fiat gasser
    fiat gasser
    After many years of wanting to, I finally finished the trim and emblem on the nose of the Fiat.[emoji1] [​IMG][​IMG][​IMG][​IMG]
    WDobos, mad mikey, swade41 and 3 others like this.
  12. loudbang
    Needs a FORD blue oval :rolleyes:
    mad mikey, TFoch and fiat gasser like this.
  13. TFoch
    TFoch
  14. WDobos
    WDobos
    Looks great buddy
  15. fiat gasser
    fiat gasser
    [​IMG][​IMG]what a great year it has been and what a difference a year makes. Merry Christmas to all my Fiat friends.[emoji1]
    1927graham, WDobos, mad mikey and 2 others like this.
  16. afaulk
    afaulk
    Looks great!!
    fiat gasser and loudbang like this.
  17. fiat gasser
    fiat gasser
    [​IMG]not much going on with the Fiat lately. But, here is a top shot just to p*** the time.
    WDobos, loudbang and mad mikey like this.
  18. fiat gasser
    fiat gasser
    I have been chasing carb problems for months. Recently the fuel pressure at the regulator was ******* the guage at 15 pounds. Regularly run it at 6 lbs. So the spike in pressure was very concerning. First I installed a new regulator and pressure guage. Turned on the electric pump and right to 15 pounds. So next, change the fuel pump. Still high pressure. Next, I empty the fuel cell and notice particles floating in the can. Thought it was junk that was in the can prior. A closer look I noticed it was foam particles from the fuel cell foam breaking down. Pulled the filter and pump out and they where filled with very fine foam silt. Took out the fuel cell, took out all the foam, and the tank had a tremendous amount of foam paticles. The fuel lines packed with foam, regulator foam, carb also. Entire fuel system. Took the carb apart tonight and did a thorough cleaning. A real pain in the but. Now, but another electric pump, filter, regulator and guage. If you run foam in your tank, make sure you check the foam on a regular basis. I used ethanol free 91 octane pump gas. It is amazing the mess, cost and time invested to get this mess straightened out.
  19. loudbang
    Well that really ****s glad you got it sorted. Snows going to be gone at Lebanon Valley soon. :rolleyes:
  20. mad mikey
    mad mikey
    I stopped using the foam years ago, you are not the only one that has had that occur . Glad you got it figured out. That foam can make a hell of a mess to a fuel system.
  21. fiat gasser
    fiat gasser
    Here is what foam does in your fuel cell after less than a year with gas in it. Imagine all this **** through your entire system. Really makes a mess.[​IMG][​IMG]
  22. TFoch
    TFoch
    Wow what a mess! Glad you figured it out!
  23. fiat gasser
    fiat gasser
    Called JAZ racing products and voiced my concerns about the foam mess in my car. They told me they don't recommend fuel sitting in the foam for no more than 3 months at a time. Winter time drain fuel. So pretty much drain gas after every use. Why sell a product like that?
    swade41, loudbang and mad mikey like this.
  24. mad mikey
    mad mikey
    Yea! Having to drain fuel is a pain. That foam is nothing but ****. I agree completely, why sell the garbage at all?
  25. TFoch
    TFoch
    Getting any miles on it now that the good weather is here?
  26. fiat gasser
    fiat gasser
    Still plugging away at trying to ****on up loose ends. Door lexan is in. Used original trim and sliding mechanism. Fabricating door releases inside car and picking away at lighting. IMG_20180515_233602_896.jpg 20180501_230737.jpg 20180421_225019.jpg
  27. fiat gasser
    fiat gasser
    TFoch, swade41, OahuEli and 1 other person like this.
  28. loudbang
    YAY the long journey is over. :)
  29. fiat gasser
    fiat gasser
    Just beginning[emoji1]
  30. FinnishFireball
    FinnishFireball
    How was the ride with this beauty?
