Technical Drop light/trouble light, any good ones?
Discussion in 'The Hokey Ass Message Board' started by Bird man, Dec 25, 2017.
  1. Bird man
    Bird man
    from Milwaukee
    It's been quite a streak of POS trouble lights recently & a drop cord with a 3 prong outlet would be ideal. Is it possible to find one NOT made in China? Something that will not fail in a mater of weeks? Best one I ever had lasted about 15 years. Maybe those days are gone.
    Maybe there is still a Christmas miracle out there...
    Thanks.
  2. ceege
    ceege
    from NW MT
    I don't know if one light is the answer but I use the **** out of my rechargeable dewalt with the swivel head.
    54EARL and Terrible80 like this.
  3. MrMike
    MrMike
    There out there, try industrial supply but whatever you find consider an LED bulb, I find they last longer.
  4. oldolds
    oldolds
    A friend has a cordless one that impresses me. Made by a company called Neico or Neiko. I have used it for a days worth of work and it was still shining brightly. About 18" long less then 2" in diameter. I looked them up about $60 if I recall. LED. I would guess it was made west of San Francisco.
  5. ceege
    ceege
    from NW MT
    Another thing I use is a 4 foot led shop light but like most leds , they dont like being dropped.
  6. '51 Norm
    '51 Norm
    from colorado
    I'm not much help because I can't find the manufacturer's name on mine. I bought it at the Rocky Mountain Street Rod Nationals a few years ago from a vendor there. When I walked by his booth he threw the light onto the floor and kicked it across the booth, sold. I've been using it about every day since.
  7. neatoldclassics
    neatoldclassics
    from Montana
  8. B.A.KING
    B.A.KING
    Don't buy harbor freight drop light........
  9. tommyd
    tommyd
    from South Indy
    spin_prod_888255012.jpg Like 51norm said. Bought my l.e.d. drop light at a swap meet after the guy slammed it around. Three years ago and still flawless and doesn't get warm. Similar to this only it fits inside the original metal hood.
  10. Rocky
    Rocky
    Classified Editor
    I've been through about 15 yellow plastic LED units and I always break 'em. Now I have an old traditional metal bulb-type [almost threw it away many times] but with a cool LED bulb. It's hooked to a retractable reel attached to the ceiling right in the middle of my little garage. Love it!
  11. HOTRODPRIMER
    HOTRODPRIMER
    The best one I have found is the Bayco Fluorescent work light,I have had it for about 8 years and it hasn't failed me yet,got it at Ace Hardware. HRP
    Roys40 likes this.
  12. Try to keep away from the old mains voltage type which used a normal bulb, when the bulb breaks, you have a lovely live (hot) terminal where filament was, ready to "bite" you.
    I chucked out all of mine, and replaced them with 12v transformer type LED type. Cheaper to run, and last a lot longer.
  13. evintho
    evintho
  14. Roys40
    Roys40
    This is what I use in the shop. However if your looking for a cordless I use the kobalt cordless tools and they are great! The saws and drills I use at work and have outlasted my dewalt tools. They are made in America. And the 24v batteries have great run time as well as being half the price of the top brands.the 18v and 20v tools/ batteries are cross compatible and if you have someone with access to a 3d printer they can make an adapter for the 24v to work in then as well. (The older tools have motors and switches rated to handle the voltage) point of that ramble was the great deal to be had on a warrantied tool that's American made and get tool line up. Lol git a little distracted there
  15. The design is a great concept, nearly perfect.
    However the one I have is/was junk. The plastic is thin and very brittle. The rotating sleeves shattered on 3rd use with no apparent trauma - I duct tapped it back together. No problems with the tape. The minimum grab range is too wide for a lot of under car places. Across a hood, door jambs and such it's fantastic. The amount of light is phenomenal but the battery is fast to fade and is slow to charge.
    It's a great idea, needs/deserves a revision. Even if it has to cost more to cover those revisions it could still be a great light.
    neatoldclassics likes this.
  16. joe.didio
    joe.didio
    I don't have a picture!!!!! MATCO tools (you can find it on there web site) sells a portable/rechargeable/magnetic base/two power brightness/tilting base tough little light. I use it when welding and everywhere else when needed. No cord and small enough in size. It ain't cheap, but based on you particular need/project $$$$$, its worth it weight in Gold.
  17. 283john
    283john
    Or to ignite something like that leaky fuel pump you're wedged under the car replacing.
    belair and ClayMart like this.
  18. slowmotion
    slowmotion
    Just got one. 25 ft, 12/3, sturdy metal case. Came from China via Rural King I think. I'll let you know if it's worth a **** or not.
  19. gatz
    gatz
    I bought one of these and made it into a work-light for a vertical band saw....works great.
  20. WZ JUNK
    WZ JUNK
    from Neosho, MO
    I bought the same one at Lowes https://www.lowes.com/pd/Voltec-Industries-LED-Portable-Work-Light/50433094 It works great. The old conventional drop lights would either burn me, or blind me. This one provides lots of light and it does not heat up.
    John
  21. BamaMav
    BamaMav
    from Berry, AL
    I've got a 6" fluorescent that came from Walmart several years ago, that thing has been through hell, dropped, kicked, left out in the rain, still going strong. I say that, next time I plug it in and it will blow.
    I've also got a LED about the same size, had it for 4-5 years, used it for hours, and it still has the same batteries in it that came with it!
    Also been using some small LED flashlights the wife picked up at Tractor Supply a while back. 3.5" long and 1" diameter running off of 3 AAA batteries, those little lights will light up the world! Just small enough to get into tight places yet light up a large area.
  22. squirrel
    kind of expensive, but search ebay for a McGill drop light, and have fun! The wooden handle will impress your traditional buddies.
    I've been using a foot long fluorescent Sears drop light for a long time, it's ok, but not the best by a long shot.
  23. Truck64
    Truck64
    from Ioway
    One thing I noticed was just how completely ****ty conventional lightbulbs have become. Spare me the Public Service Announcement about how light bulbs are old tech. I use LED where they make sense, but they have all the ambience of a ****ing arc welder, and in terms of heat output a conventional bulb is 100% efficient.
    Anyway, a "rough service" light bulb - designed for auto trouble lights - lasted at least 4 or 5 years (I'm not sure!) in constant use at a bedside table lamp. Typical bulbs sometimes last only 4 or 5 days.
  24. bct
    bct
    yep up here in Canada a hot bulb is your friend.
  25. sunbeam
    sunbeam
  26. saltflats likes this.
  27. 51504bat
    51504bat
    If you want to stay with the old school trouble light with a screw in bulb, WalMart still sells rough service bulbs for a reasonable price. I have several of the old type with rough service bulbs and they work fine for me.
  28. DDDenny
    Hell, I'd be happy to get the new POS bulbs to even work right out of the package.
  29. Jalopy Joker
    Jalopy Joker
    any bulb that puts out heat can easily cause a fire if gas, etc gets onto bulb - not likely to happen!? - friend could have been very injured if another friend did not help get him out from under a Hot Rod that caught fire due to gas hitting a drop light bulb
  30. Truck64
    Truck64
    from Ioway
    I suppose anything is possible. Ya pays yer money and takes yer chances.
