Projects 51 hudson Hornet project
Discussion in 'The Hokey Ass Message Board' started by triman62, Sep 22, 2016.
  1. triman62
    triman62
    Pulled the head off today, engine has no rust in the cylinders whatsoever. Pistons are extremely clean, only a slight trace of carbon buildup. May have been overhauled shortly before being parked? The rear end had new brakes and hardware installed, and the receipt for the tires showed only around 8oo miles since new. Looks like the old car may have been maintained regularly. Picture1227171857_1.jpg Picture1227171856_1.jpg Picture1227171855_1.jpg Picture1227171854_1.jpg Picture1227171853_1.jpg Picture1227171850_1.jpg
    brEad and loudbang like this.
  2. Racer29
    Racer29
    I bought my first 51 in 2005. It was a Pacemaker with the flathead 232. It had set in a barn sometime since the mid-seventies. I poured Marvel Mystery Oil down the spark plug holes turned it over a quite a few times by hand then turned it over with the starter then put the fire to it and it lit right off and ran perfect for the next 10 years and is still running today for the guy I sold it to.
    Sent from my A521L using The H.A.M.B. mobile app
    loudbang and triman62 like this.
  3. triman62
    triman62
    They really are some tough engines. I'm going to replace gaskets and seals in mine while its out, I just have to look and see what makes it tick. Picture1229171605_1.jpg
  4. triman62
    triman62
    Cleaning and inspecting engine this week, debating how far I want to dis***emble it. I will know a lot more about the condition when I inspect rod and main bearings later this week. Picture0103181736_1 (2).jpg Picture0103181736_1 (3).jpg
    Cosmo49, brEad and loudbang like this.
  5. triman62
    triman62
    Working on the engine today, trying to get the camshaft out. I made a fixture to hold the valves and springs, puts just enough pressure on the springs to keep it together. I can release the valve spring by hand for cleaning. It is a bit overkill but just using what I got to hand. Picture0115181559_1.jpg Picture0115181558_1.jpg
    quickrack-alan and loudbang like this.
  6. triman62
    triman62
    Looked at the rods and mains, appears to be a low mileage engine. I went ahead and pulled the pistons, and the rings are stuck, no big surprise there. Cylinder bores look good, guess its time to start cleaning parts. Picture0119181535_1.jpg Picture0119181533_1 (1).jpg Picture0119181533_1.jpg Picture0119181532_1.jpg
  7. triman62
    triman62
    Been awhile since I last posted. I got into a holding pattern for an engine gasket set that never showed up. I do have another source for gaskets, so I'll be going that route instead. While I was waiting I started the new shop project at home, but it is time to get this project out of cold storage and get back to work on it. Picture0115181706_1.jpg
    loudbang and Hnstray like this.
  8. wuga
    wuga
  9. SS327
    SS327
    What ever happened? Did you get it running? Did the gl*** fit? Is the pickup done and running? We’re you able to get bearings, rings and gaskets? Inquiring minds want to know!
  10. rusty1
    rusty1
    this is one of my favorite HAMB threads, glad you're doing it :eek:ld school "..great job.
  11. triman62
    triman62
    I have been working on the projects when I could find the time. I started building a new shop when my wife decided she wanted a new house, so I built her one, just got done last fall and went back to work on the shop. I did get gaskets and rings, the bearings were new. The engine had been overhauled just before it was parked. I bought a Hudson bed for the truck and got it put on. It seems that I get to work on my projects more these days, so I will be getting more done now.
  12. leon bee
    leon bee
    Looking real good. I spotted this thread about 3 minutes after ordering a driveshaft carrier bearing for a 53 Hornet.
    triman62 likes this.
  13. SS327
    SS327
    Well just keep us up to date so I don’t have a crisis. :oops:
  14. UNSHINED 2
    UNSHINED 2
    It will be great to see some more progress on this car.
  15. spudshaft
    spudshaft
    Bump for updates
  16. jfreakofkorn
    jfreakofkorn
    Has anything been done with the vehicle(s) . . .
