rebuilding after the crash
Discussion in 'Off Topic Hot Rods & Customs' started by racer-x, Sep 19, 2015.
  1. im thinking car guy ****.
  2. Dick Stevens
    Dick Stevens
    I'm thinking the price is kind of like buying jewelry too! :eek:
  3. loudbang
    Why does the small end have small holes drilled in it. Oil retention?
    chryslerfan55, mad mikey and Stogy like this.
  4. Im not sure why the pic turned out that way. Holding the rod in my hand i dont see the dots or feel them. Maybe it was a reflection of some sort due to the flash.
    chryslerfan55, Stogy and loudbang like this.
  5. squirrel
    Probably an interference artifact, from the pixels in the camera, and the hone marks on the pin bore.
  6. mcmopar
    mcmopar
    from Strum, wi
    Them sure are pretty, cant wait to get my set. I almost want to buy a extra for wall art.
    Tony
  7. saltflats
    saltflats
    from Missouri
    You going to be able to run that much side clearance on the street?
  8. yes. I have been doing it with the 354 for the last 5 years. I use really good oil pumps.
    loudbang and wrenchbender like this.
  9. save your money tony. I just happen to know a guy who could get you one for your wall.
  10. saltflats
    saltflats
    from Missouri
    A few of the Hemi racers I know seem to have a bunch of wall hangers. :D
  11. and a big trophy case. they seem to go well together with a hemi. ha ha
    Stogy, mountainman2, loudbang and 2 others like this.
  12. A 354 p***enger car block has been located and purchased. Its stock bore. We are full speed ahead now working on both early and late model hemis. Thanks go out to everyone that sent private messages on leads for a block.
  13. 55Belairretrorod
    55Belairretrorod
    from Australia
    Will the early hemi be essentially a copy of the previous one, or are there any changes/upgrades planned?
  14. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    You just knew that was going to happen, didn't you?
    chryslerfan55, loudbang and Stogy like this.
  15. bostonhemi
    bostonhemi
  16. The new 354 engine will not be running nitro. It will be a blown gas engine only. The cam will be installed at 107 instead of 112 to create cylinder pressure. It will only have one distributor. The dual drive will be on the 426. I never maxed out the hp on gas so it will be interesting to see what we can do. Im sure the truck can get into the 8s when we are done. A trip is planned to iowa this weekend to work on the stage five heads. The guides need to be set up for larger stem valves. A higher level or durability will be achieved with bigger stems. Only the highest quality severe duty valves will live in the new engine. We are waiting for the sleeves to show up then we will put it together. We will show how to put a big nitro engine together.
  17. mcmopar
    mcmopar
    from Strum, wi
    Well that sounds like a hell of a truck, cant wait to see it run. I talked to my uncle in waterloo Iowa, and he said roger, aka, radar (just found that out) was the best engine builder in the country and you are in good hands with him. Cant wait to see you car run this summer.
    Tony
  18. I cant wait to see your truck next summer. For those that have not figured it out mcmopar aka tony will have the 354 in his truck. Roger and i are helping him out with the engine program. We have put countless hours into this program and feel we have some unfinished buisiness to take care of. We both want to see how much hp the engine make on gas. Im predicting over 800.
  19. rawcjw19
    rawcjw19
    Thanks for taking the time to post Brian. This is a very interesting thread!
    racer-x and loudbang like this.
  20. 20180105_153210.jpg Another trip to iowa is in the books. I dropped off the 354 for tony and worked on some of my things. The stage five heads i have were set up with 5/16ths stem valves. This wont work with nitro. We wanted to use 3/8ths stem valves but that would have created a big mess due to the guides becoming too thin. So we went with 11/32 nd stems on the intake and exhaust. All the liners were drilled out then the guides were reamed. Each hole needed to be indicated first. After that new liners need to be installed. View attachment 3766048 It takes all day to do a set of heads but its worth it in the end. After that the installed heights were checked out and all of the valve train components were ordered. Going to rogers place is always alot of fun. There is always alot to learn. The place is a serious no b.s. machine shop. View attachment 3766048
  21. mcmopar
    mcmopar
    from Strum, wi
    I ***ume you mean 11/32nds, not 11/16ths for the valve stem, its way closer to 3/8ths. What angle are you reaming them out at? It looks like you tip the mill head to do this. Thanks for dropping the block off.
  22. That was a typo. Just seeing if you are paying attention. I edited it. Im not sure what it was set at. Roger had it set up he did the first one before i got there. Each guide was set up so perfect a valve job wasnt needed. The seats were just lightly touched with a stone to make sure.
  23. 402BOSSMAN
    402BOSSMAN
    Why not use the cones to center off the seat and bore the other direction? No K-Line Tooling for liners? Keeps more concentric to the seat and can do a full set of liners in about 30 minutes. Good choice with 11/32 stems more valve selection.
    chryslerfan55, racer-x and loudbang like this.
  24. I will p*** that along to roger. He just said he wants to do it in the mill. It would have been nice to get it done quicker.
  25. Runnin shine
    Runnin shine
    Maybe he only wanted to spend more time with a brother in arms “mad scientists united”
    loudbang, jackalope and racer-x like this.
  26. woodbutcher
    woodbutcher
    :D Quicker ain`t always better.UNLESS,it`s from the start line to the finish line:rolleyes::p.
    Good luck.Have fun.Be safe.
    Leo
  27. This morning it was another trip. This time to jims shop. He needed the fly wheel and starter. The mid plate is being made. He needed to figure out the starter placement. Kb engines have more bolts on the back of the block. We are using them all. 20180106_095707.jpg
    Stogy, mgtstumpy, bobwop and 4 others like this.
  28. rottenleonard
    rottenleonard
    Will this be pretty much a bolt in deal when you put it in the ch***is or are you going to have to modify the car quite a bit for this new setup?
  29. It will need new engine mounts front and rear. New headers. The coolant lines will need some attention. New spark plug wires for both ignition systems are needed. A new larger fuel tank will be needed due to the added cubes. It shouldnt be that bad getting it all done by spring.
    Stogy, bobwop, chryslerfan55 and 3 others like this.
  30. 402BOSSMAN
    402BOSSMAN
    Here is how I do it. It goes really quick if you have their kit. I use three different broaches to help seat it against the walls really well, ream with a AV&V Carbide Reamer, and do a light hone with a diamond hone to dial in my clearance.
    hipster, mgtstumpy, bobwop and 6 others like this.
