Hot Rods 16 inch steelies in Australia
Discussion in 'The Hokey Ass Message Board' started by Nick Cummins, Dec 28, 2017.
  1. Nick Cummins
    Nick Cummins
    Hi this is my first post as I'm just begining my build jouney.I'm looking to buy some 16 inch traditional style steel rims for a 28 RHD roadster I'm building. . Im going to run 5 x 5.5 stud patern.Can anyone recomend a good place to buy them. I live in Sydney Australia. thanks Nick
  2. Antique Tyre Supplies in Vic
  3. Borderline Imports at Tweed Heads
  4. Leary
    Leary
  5. BLACKNRED
    BLACKNRED
    contact your local Early Ford V8 Club an see if someone has some original 40 to 48 stock rims, there is a variation in width, but you should be able to get 4 good ones all the same width.
  6. RoddyB34
    RoddyB34
    Get on Aussie Hambers on Fbook put an ad on ,,they are often on there for sale ,,
  7. swifty
    swifty
    Maybe check your rego requirements first as I've heard that some engineers require safety rims so original wheels are not allowed.
  8. Nick, i am looking for a pair of 15 x 5 with the 5.5 bolt pattern if you happen upon any.........for my Model A roadster pickup project
  9. 19highboy32
    19highboy32
    Welcome aboard Nick, how about a build thread?
    Regards Tim
  10. Nick Cummins
    Nick Cummins
    thanks Tim I'll get on to a build thread. Cheers Nick
  11. Nick Cummins
    Nick Cummins
    will do
  12. Nick Cummins
    Nick Cummins
    will do thanks
  13. Nick Cummins
    Nick Cummins
    cheers
  14. Nick Cummins
    Nick Cummins
    thanks for that
  15. acme30
    acme30
    from Australia
    This is good advice - not sure about New South Wales but if you are building a hot rod in Western Australia you must use safety rims - no original wheels on hot rods (note restored car with original rims are ok - just not pre 48 hot rods).
    As swifty says it would be usefull to check with your TAC or engineer before shelling out any cash or more time on this until you know for sure. If you do need safety rims one option is to replace the outer hoops and use the original centres.
  16. How about Willys or early Jeep wheels. They are 16" with 5 x 5.5" bolt pattern.
    Should be easier to find than 40-48 Ford wheels (at least in Europe)
    Hennie
