Technical 32 3 window . Chop chop chop .
Discussion in 'Traditional Hot Rods' started by Flop, Sep 17, 2017.
  1. bsa_bob
    bsa_bob
    from lower mich
    Against the law in Mich --by looks of the W/S. 6 .5" MINIMUM SIZE W/S GL***. btw save your drop pieces i did to in case someone else needs them to go back up with the top not likely but its happened before bob s
    I built mine--- completely accept for the trans - wanted to show you a picture over 30 years ago. I see you saved all 3 hinges, Smartest thing you could do. Steel doors begin to sag over time on 2 hinges,BTW thats one sweet 3-window , for the great shape its in bob s
  2. Flop
    Flop
  3. trey32
    trey32
    How do you fill the front slice above the door??
  4. luckythirteenagogo
    luckythirteenagogo
    from Selma, NC
    Flop, truly amazing work once again. Forget metal shaping workshops, I'll pay to hangout, get the coffee and hand you tools.
    Flop likes this.
  5. Flop
    Flop
    I have to make a die for the pull max to reshape the reveal to make it flow a little nicer . Then just weld it all back up .
    spurgeonforge and brEad like this.
  6. trey32
    trey32
    I wanna see!!
  7. The37Kid
    The37Kid
    Pullmax! That never got any camera time, guess that is were the great body beads that match the factory ones come from. Have a Happy New Year! :) Bob
    Outback and Flop like this.
  8. Flop
    Flop
    Well it’s not actually a pull max it’s a Japanese knock off from the early 60s called a vibroshear
  9. Flop
    Flop
  10. Outback
    Outback
    from NE Vic
    Wow love your work, this coupe has a great profile!
  11. kidcampbell71
    kidcampbell71
    Vibro-shear. Sounds like a fun man-scaping device. < cough > < cough > :) Sorry Flop.
    Bring on the Bondo ! ( not. ) I'm ready.
  12. 40ragtopdown
    40ragtopdown
    Great chop thanks for sharing.
    brando1956 likes this.
  13. Flop
    Flop
  14. big duece
    big duece
    from kansas
    That box should be in the Peterson museum as an exhibit.
    Flop and SquintBoy like this.
  15. bsa_bob
    bsa_bob
    from lower mich
    I chopped mine the same way.Only thing i see is great metal work.....but i know this for a factFirst are you running 3 stock hinges?If yoy are you can't eliminate the top hinge The door because of the way the door opens- once chopped it tends to drop the door ...if they are steel also. Been there! done that! on 2- 32 3-windows.but kept the top hinge intact no sag after 33 years ago.on this yellow deuce. I had under a quart ---of mud with 3 other coats- and "allmetal," Chevette roof turned sideways is perfect fit should use chevete 4-dr. sorry I got carried away abit-but I have a love for the Deuce I've done 3 of them completely accept for the transmisions
  16. bsa_bob
    bsa_bob
    from lower mich
  17. bsa_bob
    bsa_bob
    from lower mich
    Looks like the same box i have in my backroom.Something happens to me they will get thrown out i'm sure. Heard of an older a guy who raised the top back up!. ONLY one i ever heard of bob s looks good flop
  18. Flop
    Flop
    The middle hinge is what was removed in the last one I did .
    chryslerfan55, Blues4U and mgtstumpy like this.
  19. trey32
    trey32
    Do you keep all three in place now??
    chryslerfan55 and Flop like this.
  20. movingviolation
    movingviolation
    That folks is how it is done! Beautiful craftsmanship on one bada$$ 32!
  21. Flop
    Flop
    Back seam welded up where the side of the car meets the center window section .
  22. Krash
    Krash
    from Cleveland
    Wicked chop! That's some great craftsmanship!
    chryslerfan55, Flop and chop job like this.
  23. Flop
    Flop
  24. brady1929
    brady1929
    You are very talented.
    Flop likes this.
  25. Flop
    Flop
    Solid pillars all the way around for piece of mind . Safety first .
    Body lines washed out for some reason
    Stock 3w
    Gonna use the piece I cut out for the body line .
  26. Flop
    Flop
    Filled in a lot of blanks .
    Totally reshaped reveals so they flow into themselves better
    Last weld on the pillar tying the roof and header back into the pillar .
  27. Cyclone Kevin
    Cyclone Kevin
    Alliance Vendor
    I totally know who to call if I ever want to “raise the roof” as you my friend have nearly enough pieces to breed a whole other body ;).
  28. Flop
    Flop
    Other door top on . Gaps need work as this side was a bit screwy when I got the car
    A pillars are now both solid .
  29. A Boner
    A Boner
    Flop, just wondering......do you have some sort of waiting list? Doesn't see like there are many craftsmen with you skill level. Keep up the great work, and keep posting!
    mgtstumpy and Flop like this.
  30. Flop
    Flop
    chryslerfan55, brEad, ls1yj and 2 others like this.
