Projects 34 ford 3 window built from 2 door sedan
Discussion in 'Traditional Hot Rods' started by blindowl, Dec 31, 2017.
  1. blindowl
    blindowl
    from MASS
    Heres my 500$ 1934 ford sedan that will be converted into a radically chopped 3 window .....thanks Mr Gene. I just started to learn gas welding so this will be the perfect project to learn on. Feel free to give advice or tips
  2. blindowl
    blindowl
    from MASS
    A little progress
    brEad, Squablow, Ric Dean and 7 others like this.
  3. blindowl
    blindowl
    from MASS
    Tough part will be the belt line that wraps around to the panel above the deck lid
  4. blindowl
    blindowl
    from MASS
    P***enger side
  5. Neat!
  6. dumprat
    dumprat
    from b.c.
    Now this I wanna see! (Becaus I have half a 2dr sedan sitting in my shop destined to be a chopped 3window!)
    Stogy likes this.
  7. sloppy jalopies
    sloppy jalopies
    go blindowl go !
    townie uses '35-'37 truck stuff to build door tops... HIH...
  8. Pretty rad!
  9. blindowl
    blindowl
    from MASS
    Yes , i herd that they work
  10. Roadsir
    Roadsir
    I'll be following along on this. Looks like a great start
  11. sloppy jalopies
    sloppy jalopies
    '35 trucks doors used a garnish moulding, '36 -'37 trucks had the garnish stamped into the door's inner skin...
    Stogy likes this.
  12. Hot Rods Ta Hell
    Hot Rods Ta Hell
    Cool! I'll be following. You got a great deal for 5 bills!
    A lot of your work will be making the turret of the roof look Coupe like-leaning it and taking the "bubble but" out of the Sedan shape, but you know this from your 5/w conversion.
    Door frame shape and Sedan rear window shape won't be such an issue with a severe chop.
  13. rod1
    rod1
    Right on.Been saving parts for this same project..The right man for the Job!
  14. spurgeonforge
    spurgeonforge
    Love these builds. Thanks for the posts.
  15. DOCTOR SATAN
    DOCTOR SATAN
    from okc
    Looking' good...
  16. ROADSTER1927
    ROADSTER1927
  17. 383deuce
    383deuce
    Signed up for the ride and am popping the corn. So let the show start..
    MR CLEAN and spurgeonforge like this.
  18. manyolcars
    manyolcars
    These are the best threads on the HAMB
  19. Max Gearhead
    Max Gearhead
    from Wisconsin
  20. trey32
    trey32
    Steve's auto sells an love the deck lid panel.
    Watcha doin for quarters and door tops??
    Stogy likes this.
  21. sloppy jalopies
    sloppy jalopies
    If needed the beadwork between the rear window panel and the panel above the deck is the same for '33 - '34 coupes and '35-'36 trunkbacks... Is a little short but you can add length to the flat section... it converts the vertical window to the horizontal trunk panel...
    also a '35 - '36 truck's roof above the w/s from hinge to hinge will patch a '33 - '34 sedan / coupe... HIH... go blindowl go !
    29EHV8, rust, Squablow and 4 others like this.
  22. trey32
    trey32
    Sloppy jalopies, I find your knowledge of early Ford's seemingly limitless.
    I wish I could hang out in your garage...
  23. The37Kid
    The37Kid
    Looks like a good build to follow, clean all the to be welded areas before you fire up the torch. There was no MIG or TIG in the old days.;)Bob
    loudbang and Stogy like this.
  24. Cyclone Kevin
    Cyclone Kevin
    Alliance Vendor
    Digging this build as well :). !!!
    Looking forward to seeing its progress
    as the transformation takes place.
    Hey Dennis, p*** that popcorn on over. ;).
    kidcampbell71 likes this.
  25. MAD 034
    MAD 034
    from Washington
    Very exciting!
  26. MR CLEAN
    MR CLEAN
    I am Impressed with Your Vision.....Build it blindowl
  27. blindowl
    blindowl
    from MASS
    This quarter panel should help out big time. Now i have to find the p***enger side.
  28. blindowl
    blindowl
    from MASS
    This is great stuff to know. Thank you
    Nailhead A-V8, loudbang and Stogy like this.
  29. sloppy jalopies
    sloppy jalopies
    Stogy likes this.
