When I got my '53 Chev it already had been painted with some Flat Black Tremclad paint from the local hardware store. The thing is everytime i open the trunk lid I see the original color and I want it back!. My question is, is there a way to strip away the top layer of flat black but leave the factory color layer intact?. I was thinking if i could just do it for the roof i'd be satisfied. http://www.1953chevrolet.com/images/53_Colors_1.jpg it's the Regatta Blue. Any help is appreciated.
probally not,,with out ****in it up...try wet sandin..but i but you will go into the old paint...good luck
Try a little lacquer thinner on a rag and see if it removes the Tremclad. Do it on an incon****uous spot. It may remove it. It might also bite into the original underneath. If it works, you might be able to polish the original back up. Good luck
No problem Vinnie mack. Just please make sure you try it somewhere that won't matter if it screws up so you can spot the black back in and no one will see it.
