Technical 460 rear main cap
Discussion in 'The Hokey Ass Message Board' started by 66FL, Jan 2, 2018.
  1. 66FL
    66FL
    I’ve been dealing with a nasty oil leak on my 460. Originally thinking I️t was the rear main seal, after tons of reading. So I️ pulled the oil pan and behold! An 1/8” chip on the rear main bearing cap. With a glob of silicone right on the outer edge. (Previous owner) Now the chip sits on the outside edge of where the pan and gasket set. And I️ cannot find a replacement on the internet anywhere! So my question is,
    1. Where can I️ find a suitable replacement?
    2. Machine shop around Orange County N.Y.?
    3. Spot weld myself? Seeing as that it’s on the outside edge of the gasket lip.
  2. saltflats
    saltflats
    from Missouri
    A picture sure would help us keyboard techs.
    squirrel likes this.
  3. simpsonrl
    simpsonrl
    My thoughts: 1) the rear main cap probably has to be matched / machined to the block to
    Properly hold the bearing shell round and precise. So I don't think you can just replace the bearing cap.
    2) I would probably try Tig welding a little silicon bronze to fill the missing piece. It is basically brazing so temp is low so should not cause distortion. Also the cap is a cast of some kind. The bronze won't be effected by the high carbon content. The bronze is soft enough that you should be able to work the shape back with hand tools and files.
    Welding is an option, but the likely high carbon content will create a hard weld that will be difficult to work with. You would need to use nickel.
    I have repaired many items with Tig bronze and it works superbly.
    Hnstray likes this.
  4. squirrel
    Usually if there's a problem with a main cap, you find a replacement cap from a junk block. Then get the block align honed with it's new cap in place.
    Truckdoctor Andy likes this.
  5. Drew Link
    Drew Link
    Squirrel is correct. The caps are mated to each block, but get the cap from a block and align it. You will be back on the road in no time!
    Sent from my Pixel 2 XL using The H.A.M.B. mobile app
  6. BJR
    BJR
    Since it's on the edge of the cap with no stress, I would try cleaning it well with brake clean and use JB weld. Then file it to shape. After all, all it has to do is seal to the oil pan.
  7. 66FL
    66FL
  8. saltflats
    saltflats
    from Missouri
    Not sure that would cause a problem.
    egads, seb fontana and Engine man like this.
  9. Mr T body
    Mr T body
    Alliance Vendor
    from BHC AZ
    That chip is from a part of the cap that shouldn't see any oil. The pan gasket should seal it from getting to that point. Unless there's some other damage/deformation ***ociated with that chip, that's not the source of your leak.
    egads, weps, Engine man and 1 other person like this.
  10. 66FL
    66FL
    The more I️ think about I️t. You guys should be correct. really shouldn’t affect I️t. And looking at the old pan gasket. I️t is deformed where that chip is. So possible too much silicone mishaped the gasket? Or over tightening has done it
  11. saltflats
    saltflats
    from Missouri
    That looks like the sealer was put on there after it was ***embled.
    I would have to take a look at the rear seal.
  12. warhorseracing
    warhorseracing
    from cameron wv
    From the appearance of the crankshaft throw it appears that the crank has been seriously reworked then re-balanced. Do you know any of the specifics of this engine, stroker, etc.? Was the engine stroked then rebalanced or just some serious machine work done on the crankshaft to lighten it? There could be more issues than this one cap which as Squirrel stated will require line boring if replaced.
  13. 66FL
    66FL
    I️ have zero history on the motor.
  14. warhorseracing
    warhorseracing
    from cameron wv
    Is the oil leak isolated to just the rear of the engine in that specific area? If so the cap could be cracked, highly unlikely but it could be and should be investigated before slapping a Band-Aid on it with just a new gasket. Is this a stroker?
    Does the engine vibrate when tached up high in the RPM range?
  15. CNC-Dude
    CNC-Dude
    Not trying to point fingers at the engine builder, but while you have the pan off, pull the cap to confirm the rear main seal isn't installed backwards. I've seen this hiccup many times, especially to non-Ford specific engine builders.
  16. RmK57
    RmK57
    Maybe the seal was put in backwards. Or if the maincaps have been machined and the new seal may lost its crush and is distorting the seal. The seals are also offset when there placed in the block and maincap.
  17. 66FL
    66FL
    There was a small amazing of sea page from the front of the pan. And Engine runs smooth at high RPM.
  18. Engine man
    Engine man
    from Wisconsin
    Have you pulled the cap and looked at the crankshaft seal? As others have said, that really shouldn't allow a leak. I liked to clean the surface of the cap and seal with thinner and use 3M weatherstrip adhesive to glue it in place.
  19. 66FL
    66FL
    attempted to pull the rear main cap, but with the motor still in. Might be impossible. Caps in there pretty good. I️ don’t want to damage trying to remove
  20. saltflats
    saltflats
    from Missouri
    Take a soft face hammer and give it a tap on the side it should give it up.
  21. warhorseracing
    warhorseracing
    from cameron wv
    As stated above in saltflats post, loosen the bolts and tap it with a hard rubber faced hammer is what I use and examine the bearing cap. Check the seal as engineman suggests and possibly get the cap magnafluxed while you have it off just to eliminate any cracks. If you even have to just replace the one rear cap you will have to get the entire block and all other mains align bored. So rule out a cracked cap before proceeding any further, have the cap magnafluxed..
  22. 66FL
    66FL
    Ok, going to go at this again. Thursday. It’s down to 6 degrees To be continued...
    saltflats likes this.
  23. Joe H
    Joe H
    If you pull the cap, brake clean it and let it set, if it's cracked, oil will migrate back out of the crack and should show up pretty easy. The main cap and rear pan gasket, should be completely free of oils and grease, a little dab of sealer in the corners is all thats needed for leak free installs. Also, be sure the pan sets flat all the way around.
  24. I highly recommend changing the rear main seal while your so close. While doing so, offset the seal approx 1/4" so that the parting line of seal is not at the same parting line as the main cap. Also a very little dab of silicone on the ends of the seal before you bolt the cap back in place. Don' forget to oil the seal and bearing. Also another thong I've found....we used to use a one piece pan gasket (I believe it was actually for a 330 or 390?). I would use 3m spray adhesive to spray the block surface then I could stick the gasket up to it perfectly and easily bolt oil pan in place. The gasket we used had to have very end holes cut out for larger bolts....youll understand if you see it.
  25. 66FL
    66FL
    Update to where this stands.
    As recommended, pulled the cap. Looked to be in good shape. (Other than the chip)Pulled the seal, also looked to be in good shape. I️t was in the correct way. Replaced rear main seal. Offsetting the install in block to cap. Dab of silicone, new pan gasket. But as soon as I️ reach operating temp. Steady drip occurs. going to attempt a different rear seal, and pan gasket. I️ also checked crush depth, and was at
    .05 on both sides of gasket. Possibly not enough from manufacturers?
  26. saltflats
    saltflats
    from Missouri
    Maybe the leak is coming from somewhere else.
  27. RmK57
    RmK57
    Crush depth should be set @ 0.015-0.020. If the engine has been line honed it can throw things off.
    Had to give my rear seal a touch up to bring it to spec.
  28. 66FL
    66FL
    Can you explain “touch up”?
  29. RmK57
    RmK57
    File or grind one end of the seal to bring it into spec.
  30. 66FL
    66FL
    One end of both seals? Or just one part
