Projects Bellflowers or Nope!
Discussion in 'Traditional Customs' started by Dirty Olds, Jan 2, 2018.
  1. Dirty Olds
    Dirty Olds
    I’m looking for options. I want to put bellflowers on but I want to keep the car the way it is! I don’t want to put supremes and pinstrip white walls. I really like the rim and white wall setup as it is with with rings and caps. I know everybody like the bellflower setup with the supremes but I’m looking to be a bit different. Don’t hold back what’s on your mind!!?? Thanks guys much appreciated![​IMG]
  2. Rice n Beans Garage
    Rice n Beans Garage
    It's Bad *** level it and cruize
    Dirty Olds likes this.
  3. oldrelics
    oldrelics
    from Calgary
    Love it, looks low, might drag with bell flowers on ramps?
  4. Sancho
    Sancho
    I don't think Supremes with narrow whitewalls are a prerequisite for Bellflower pipes.
  5. 49ratfink
    49ratfink
    I'd just put full hubcaps on it and call it a day.
  6. 30tudor
    30tudor
    Bellflower tips and flashy full wheel covers. I'm sure Oldsmobile made some good ones.
    These from '50-'53 I think.
  7. Dirty Olds
    Dirty Olds
  8. Sancho
    Sancho
    I don't think chrome wheels are required either. I think bellflowers would look pretty good on your car. A lot of the GM cars of that era have rear quarter shapes that are just begging for them....
  9. Dirty Olds
    Dirty Olds
    I was thinking that route also!!
  10. Dirty Olds
    Dirty Olds
  11. Just Gary
    Just Gary
    x3.
    Spend less $ on trinkets and more on gas.:cool:
    lothiandon1940 likes this.
  12. timwhit
    timwhit
    Here's a couple of good looking stock caps. '60 buick and '58 olds spinner s-l1600.jpg 58ols.jpg
  13. 'Mo
    'Mo
    Bellflowers, yes! Regardless.
    Personally, I think these cars look great in two-tone. Painting beneath the trim in either silver/charcoal
    or deep maroon would make your wheels pop!
    How about having the Photoshop wizards give you an example?
    dan31, Dirty Olds and Sancho like this.
  14. Dirty Olds
    Dirty Olds
    I actually have the original hub caps for the car and there in real good condition! I took me some elbow grease and a 12 pack but I got them cleaned up real good!
  15. straykatkustoms
    straykatkustoms
    Like your Olds. I'd say no to the Bellflower pipes. (I'm not a fan.) They look good on some cars but not on all of them. If you look at the pictures that Sancho posted, they look good on the Caddy but to me the pipes take away from the Ford. I think that the car has to have a body line to compliment the Bellflowers.
    I found these pics of an Olds with Bellflower pipes. I might change my mind looks kind a kool.....
    34575957373_1e738c1223_b.jpg 30814027996_423ee26790_b.jpg 33616872950_f32796a8ac_b.jpg
  16. Dirty Olds
    Dirty Olds
    I totally agree with what your saying!! I’m just stuck in between!
  17. Dirty Olds
    Dirty Olds
    straykatkustoms and low budget like this.
  18. oldrelics
    oldrelics
    from Calgary
    I like the spider caps and rings better...,
    Elcohaulic and Dirty Olds like this.
  19. Dirty Olds
    Dirty Olds
    Thank you!! I usually don’t get that a lot!
  20. Spider caps and rings for sure! I prefer to see Bellflowers with fender skirts as the lines just seem to flow better on a tail dragger to me.
  21. sawbuck
    sawbuck
    from 06492 ct
    x2
  22. Squablow
    Squablow
    I used to have a '64 Olds lowrider with bellflowers and Rader wheels/gold line tires and I thought the pipes worked really well on it because of the long, flat quarter panel overhang, I think they would work equally well on your Olds since they could run parallel to that quarter panel molding. I'd probably get short ones and have them exit the quarters right where that molding changes direction instead of coming out from inside the wheelwell.
    I must say, I prefer the look of your car with the Supremes. The wide whites are fine, but to me, those spider caps on painted steel wheels say stripped down street machine to me, which doesn't really apply to the car. If it was a '55 Chevy 2 door sedan or something I think they'd work better. But that's only my opinion. They might work better if you had a set of the little inner trim rings to go with the outer rings.
  23. Jalopy Joker
    Jalopy Joker
    no to Bellflowers, since they seem to disappear in the pic of same year Olds shared. how about Lake Pipes? look good with full caps.
  24. belair
    belair
  25. fordflambe
    fordflambe
    Quoting GaryB from a thread back in 2010, "dropped on the ground w/ supremes,pinner whites and some pretty kick *** panel&lace paint" was the way it was done back in the 50's and 60's so that is kind of what i expect to see when i see a car with bellflowers. I like the looks of them but they seem to make a statement that makes me want to see more in a car. Your car is the correct era and stance for them, If you decide to go that way, i think you should go just a little further to complete the transformation..............
  26. low budget
    low budget
    from Central Ky
    I like this better but not my car, so.....
  27. jimmy six
    jimmy six
    Bellflowers.. car is perfect for them. :D
  28. Dirty Olds
    Dirty Olds
    Just looked it up with the inner rings and I like that look! Thanks for you honest opinion much appreciated!
  29. froghawk
    froghawk
    What he said! No need for Bellflower kickstands on any car unless you tuck them in like Larry did on his '59 Caddy.
  30. Elcohaulic
    Elcohaulic
    Nope.
    Skirts..
