Projects Dodge This - 1939 Dodge Southeast Gasser Build
Discussion in 'Traditional Hot Rods' started by Dog_Patch, Aug 12, 2014.
  1. jim snow
    jim snow
    Well deserved. Congrats. Snowman
    Dog_Patch, loudbang and Higgy's Henry like this.
  2. chopnchaneled
    chopnchaneled
    from Buford Ga.
    My Hero !!!!
    and i knew him when he was just Tony :)
    Tudor, Floater03, Dog_Patch and 2 others like this.
  3. Tyresmoke
    Tyresmoke
    from Norfork
  4. dirty old man
    dirty old man
    Damn right it is well derved, Tonybusted his *** to getto the track several different times this season, and BTW Kim deserves some credit on this too. Gotta be wonderful to have a wife support you like she has supported Tony since the beginning on this car.
    Tudor, Hang'emHigh, Floater03 and 8 others like this.
  5. Dog_Patch
    Dog_Patch
    Now that the racing is done, I need to stop over more often! Josh sold that digger so he's on the hunt for another build ya know.
    Yeah she would see me sitting on the couch and say "Is you car ready? Why are you sitting around?" :eek:
    Check this shot from Brad Christ there's a lot going on here.
    mad mikey, Tudor, Hang'emHigh and 6 others like this.
  6. Dog_Patch
    Dog_Patch
    And the 2017 finals video is out:
  7. strokedstang331
    strokedstang331
    from Beloit WI
    You definitely deserved that you put in way more hrs than I would have that's for sure. Great work tony
    Sent from my SM-G930R4 using The H.A.M.B. mobile app
  8. Tony here is the valve spring tool i was talking about. I got it from wizzards warehouse. They also sell a tool that screws into the spark plug hole and attatches to a air line. It also works for leaking the engine. Our tool is modified in several ways. We lengthened the handle for more leverage. We also grind a flat on the ring that goes on top of the spring. This is for shaft clearance. The hooks sometimes need a little attention. Were the hook slides into the handle we make a notch for the roll pin to lock into. Wear safety gl***es. I have changed springs by myself but it works better with two people. No more needing to pull a head. 20171111_153533.jpg 20171111_153517.jpg 20171111_153510.jpg
  9. Dog_Patch
    Dog_Patch
    Man I like that! Does the rocker arm need to be slid over to the side first? It looks like it needs clear access to the valve retainer.
  10. i remove the pushrod and slide the rocker. i use missles and the tool fits. depending on the fit i have also used a small pry bar with the tool to center it over the spring. it takes a few times to get the hang of it.
  11. Dog_Patch
    Dog_Patch
    Looks like we lost some posts but in any case - @3dnsouth was working on his 2018 SEG car so I tried to lend a hand. He's building the tilt front end hardware in aluminum and using a TIG on aluminum. Then on the way home there was another money sink hole .....
  12. Hang'emHigh
    Hang'emHigh
    Lost a few posts?! A few large posts. Maybe you exceeded the memory usage for 1 thread with all the good stuff on here! Rock on and let us know what you buy from the sale.
  13. saltflats
    saltflats
    from Missouri
    What's the story on the red 63?
  14. dirty old man
    dirty old man
    Go online to site mentioned on the sign for details.
    Dog_Patch likes this.
  15. Dog_Patch
    Dog_Patch
    You can see the list of cars on here. I don't know anything about it, roped off. This place has always had a pile of cars in the yard - 10 years I've been driving by anyway.
    http://jeffdobson.com/upauctions/index.html
  16. chopnchaneled
    chopnchaneled
    from Buford Ga.
    I knew that guy " James Hyde" One mean son of a gun, was told the good stuff was already gone.
    Hang'emHigh, Dog_Patch and loudbang like this.
  17. Dog_Patch
    Dog_Patch
  18. Tudor
    Tudor
    from GA
    Wow - that guy had some stuff! Would be cool to go ride over and check out.
  19. dirty old man
    dirty old man
    What's the story on anything new since the last post of 12/07/17? I know Tony has been busy, what with Kim's surgery and recuperation, but did anyone go to that auction or anything else on this thread since Josh's post 12/7/17? Or is the post locked again?
  20. jim snow
    jim snow
    Paging Mr. Dog_Patch!
  21. dirty old man
    dirty old man
    I'm aware that Tony is very busy with his wife's surgery and recuperation, but I was beginning to think the thread had been locked again it has been so long since anyone posted!o_O
    And for some reason my screen didn't show my post as bringing the thread back to the top:confused:
  22. Mike Colemire
    Mike Colemire
    Hope his wife is doing OK.
  23. saltflats
    saltflats
    from Missouri
    Yes lets pray everything is okay.
  24. Brand Apart
    Brand Apart
    from Roswell GA
    X3
  25. dirty old man
    dirty old man
    I talked on phone to Tony and Kim a couple days ago. She's had some rather extensive surgery, and is definitely incapacitated for a good while yet, but she is recuperating. Tony just has his hands full trying to work, keep house, look after Kim and deal with about 6 or 7 dogs also.
    I'm sure he's as busy as a cat covering up **** on a tin roof.
  26. Hang'emHigh
    Hang'emHigh
    Ditto, hope all is well on the home front for Tony and Kim. Get well soon Crew Chief!
  27. Dog_Patch
    Dog_Patch
    Thanks for the thoughts and prayers for the crewchief! Its been exactly 30 days since the surgery and she can't lift a gallon of water yet, but its expected, she's getting better. Yeah I found out how much stuff she does around here LOL I'm doing it all now and working. But still find some time to get out :
    Tim's annual Sock ****er Compe***ion ....
    We didn't drink the Old Charter - that ended badly last time.
    Then the annual beard contest
    Got the new oil pump from Missile
    Uses a Small Block Mopar pump drive
    Jack still working on his go cart. I found a new 392 block - not new 1957 new -
    Jeffy and Josh helping to return Russ' borrowed 392
    Jeffy s****ing a baby doll
    Nick decorating his shop!
    And a party at Carl's
  28. saltflats
    saltflats
    from Missouri
  29. dirty old man
    dirty old man
    Looks like yall had some fun while I was in VA. Hated to miss it all but sometimes you gotta consider family. Had hoped to have that annual reunion at sister's house at Thanksgiving, but nephew in Army couldn't get away from desert training on Mojave Desert then, and he is being posted to Korea in Feb.
    Next time we all get together will have to tell yall about the trip and the visit to a friend's shop up there who is building a damn serious land speed racer for B'ville.
    On edit: It's an XO/PP cl*** '62 "unibody" Ford p'up w/ 262+cid I-6 in the 600 hp range, all sorts of goodies.
  30. jim snow
    jim snow
    Thanks for the update Tony. We hope the crew chief has an easy recovery. You gotta autograph my copy of Hot Rod. Snowman
