Technical Hot water heater installation and tips needed.....
Discussion in 'Traditional Hot Rods' started by Rick Hegdahl, Dec 27, 2017.
  1. Rick Hegdahl
    Rick Hegdahl
    I have only owned this since mid Nov. '17....
    I am adding hot water heat to my '40 Standard. I have a '41 unit on the way.....
    I need to add a shut off valve to the p***enger side head.
    It p***enger side head has two ports on top with the forward one being a heat gauge sending unit that is inline with the driver's side head sending unit.
    The rear sender controls the electric cooling fan at the radiator.
    Do I eliminate the p***enger side temp sending unit to add the shut-off or use a "T" to keep both the valve and the sending unit?
    LOU WELLS likes this.
  2. sloppy jalopies
    sloppy jalopies
    Memory says you need both senders as one is wired through the other... I put the shut off valve where the heater's input hose enters the firewall...
    I had a hard time adding water without removing a coupe grill shell screws, I close the valve, remove the hose, crack open the cap and add water from there...
  3. Mike VV
    Mike VV
    from SoCal
    Why would you need to heat...hot water ?
    Mike
  4. Deuces
    Deuces
    For a heater core....(????):confused:
  5. fordrodsteven
    fordrodsteven
    Aren't there two ports on the drivers side also? why don't you move your radiator fan sending unit to the driver's side and then just run your hot water line (with shut off valve) from the rear port on the p***enger side?
    sunbeam and Thaplumbr like this.
  6. lodaddyo
    lodaddyo
    Its like twiced baked potatoes
  7. 42merc
    42merc
    Remove the heat gauge. Use the single terminal gauge in the left hand head, put the 2 terminal gauge & jumper wire in your tool box, don't need it.
    Put the fan control in the front port on the right head use the rear port for the heater pipe or valve. I know you know but the other hose will go to the right hand water pump or lower hose.
    "Why would you need to heat...hot water ?"
    He's not heating hot water, he is using hot water to heat the car.
  8. woodiewagon46
    woodiewagon46
    from New York
    My local Advance Auto has in line manual heater valves. The valve has a heater hose bung on both sides. Cut your hose and install the valve with a hose clamp on each end. I have this set up in my '46 and it works fine.
    lothiandon1940 likes this.
  9. Mr48chev
    A Ford Bronco/Pickup heater control valve C3UZ18495A YG133 Isn't expensive an is cable operate.
  10. sloppy jalopies
    sloppy jalopies
    Just thinking that if you used a Y to the heater with a valve on each upper end you could let the cooled water dump back into the block in summer... and send the water through the heater in winter... with a hot running flattie you might run another Y to dump the return water into both heads...
    and then there are the through the lower hose "add a ******" thingies from the '40's - '50's.
  11. Budget36
    Budget36
    I've a set of water pumps off a Ford Pilot engine, and the p***enger side one has a pipe fitting which fed the heater, don't recall where the return went. Just giving you another option.
  12. Rick Hegdahl
    Rick Hegdahl
    No, only one port on drivers side head. That is where the other temp. sender is located.
  13. Rick Hegdahl
    Rick Hegdahl
    thanks! I like this possibility. I have a valve for the head but I haven't installed anything yet. May use this path instead.
  14. tb33anda3rd
    tb33anda3rd
    how cold of weather do you drive in? skip the heater and ugly hoses and just get electric seat units put in under the upholstery. i bet it will be cheaper.
  15. Rick Hegdahl
    Rick Hegdahl
    I would still need a source for the hot water.
  16. Rick Hegdahl
    Rick Hegdahl
    Still need a source for the hot water..... where do I tap into the block? See my original story....
  17. Rick Hegdahl
    Rick Hegdahl
    UPDATE:
    I have been told that I can put my fan sensor in the drain pet**** location in the lower radiator.
    I would then have to use a lower radiator hose to drain when needed.
    Other option, I suppose, is to take the radiator to a shop that can add another bung to the lower tank for that.
  18. nrgwizard
    nrgwizard
    from Minn. uSA
    Don't forget about the temp differential 'twixt the various locations. OK if the fan sensor is adjustable so you can compensate, otherwise it may not come on when you need/want it to. I played w/this in the mid-80's when I had a ford v8 flattie. I had measured the temps at different locations, but have forgotten, & notes are long gone. IIRC, the head temps n top-tank-radiator temps aren't all that far apart, but the lower tank is quite a bit different(lower temps, esp w/a proper shroud n fan. If the sender isn't adj, & you're happy w/when it gets triggered, I'd mount it on the top tank, probably between the inlets. Shop can put the bung there easily. Should come close to duplicating the current head location temps.
    Just something to be aware of. Lots of good suggestions on this thread.
    FWW.
    Marcus...
    Rick Hegdahl likes this.
  19. sloppy jalopies
    sloppy jalopies
    Fords had a unit that screwed into a hole cut in a lower rad hose, had a heater hose size ****** exiting the hose... to add a hot water heater instead of hot air...
    we are in the middle of a big snow storm, 8" so far, the heater hose ****** is down in the garage, maybe pix Friday...
  20. 42merc
    42merc
    It looks like an 8BA motor, would have 3/8" pipe threads & plugs in both water pumps.
    Take a good look. Re-read post seven.
    This "ain't"a rocket ship.
  21. sidevalve8ba
    sidevalve8ba
    In the center of this photo above you can see the shut-off valve for the hot water for the heater and the heater hose. In the lower, right-hand corner of the photo you can see the other heater hose exiting from the right-hand water pump. Does that clear it up for you?
  22. Blue One
    Blue One
    from Alberta
    When I read the thread ***le my first thought was that Home Depot could help you with that.
    o_O Hot water heater :confused:
    Not automotive terminology.
    Besides everyone knows that a Flathead is a hot water heater, more often a boiler. :D
    An automotive heater heats the interior air of the vehicle not the water.
  23. fiftiescat
    fiftiescat
    from NY
    My ‘46 239 runs at 150 degrees all damn day, wish it would run hotter!! [​IMG]
  24. Engine man
    Engine man
    from Wisconsin
    Seat heaters don't keep the windows from fogging up.
    Rick Hegdahl and Blue One like this.
