Technical Is there a "short" waterpump for a LA engine?
Discussion in 'The Hokey Ass Message Board' started by Budget36, Jan 4, 2018.
  1. Budget36
    Budget36
    Tried google, but maybe I'm search illiterate?
    I've a 318 and would like to gain some space if possible.
    Thanks.
  2. Burkedore
    Burkedore
    If you can live with the outlet changing sides, the 318 poly pumps are shorter
  3. Budget36
    Budget36
    And they bolt right up to the LA engines?
  4. Burkedore
    Burkedore
    The a series and la series have almost identical blocks. The only difference is a coolant transfer hold at the rear of the head surface.
    To answer your question more directly, yes they interchange. I can go put a tape measure on my water pump for you in a few minutes
    Budget36 likes this.
  5. Budget36
    Budget36
    That'd be nice, but don't rush.
    I have the engine mounts in a set up as far back as I can go without getting into the firewall, I "think" I'll have enough clearance ('32 Dodge PU-originally a straight 6) to keep the hood on and radiator in the original position. I'm just looking ahead in case I run into an issue with the fan/radiator clearance.
    Trying to line up plan B if needed:)
    Thanks.
  6. squirrel
    Which pump do you have now? does it have the hose on the driver or p***enger side?
  7. Budget36
    Budget36
    I'll go out and take a look...but it doesn't matter really, because the pump I have has been off the engine for 15 years...I just kept it for exchange (engine was originally going into a van I had).
    The reason the outlet isn't a concern is because the original radiator is a honeycomb, which most likely won't be up to the task, which means I'll have one made to fit in the grill shell...so I can have the lower neck put where ever I need it.
    Seems you have an idea based on where the outlet points?
  8. squirrel
    just to give you an idea how they compare, 1969 and earlier pump has the rad hose on the driver side.
    1970 and later has it on the other side, and it's a bit longer shaft.
    But the timing cover is different, and the damper is different, so you can't just change the pump!
    indestructableforce and Budget36 like this.
  9. Burkedore
    Burkedore
    Darn it squirrel, I forgot that part. Anyway, from the block to fan mounting surface is 7-1/2".
  10. Budget36
    Budget36
    Awesome Jim!
    My balancer is old...engine was out of a '70-something...so replacement is just fine.
    Thanks for the help, that earlier pump looks a lot shorter!
  11. Budget36
    Budget36
    Oh my...see I guess I'm showing my Mopar UN-intelligence!
    Never thought to mention my engine year...thanks for the pic, sure seems like your' is a earlier setup like Jim was mentioning above.
    Thanks!
  12. Burkedore
    Burkedore
    Yes my engine is a 66
  13. squirrel
    The thing about the damper...the timing mark is in a different place. And they changed the crank from forged to cast sometime around then, too.
    But if your engine is 1966, then you already should have the short pump, so none of this will do you any good. Aside from the little bit of education about mopar small blocks.
    and the 318, if it's from 1966, is not an LA engine, it is an A engine (polyspherical heads, not wedge heads)
  14. Burkedore
    Burkedore
    Squirrel, you have gotten my engine, (66 poly pictured above) confused with the op Budget36s' 1970s era 318.
    Mixup non withstanding your information is spot on.
    Budget36 and squirrel like this.
  15. squirrel
    ah....sorry about that! then the early water pump should help him make it fit.
  16. jaxx
    jaxx
    have you thought about an electric pump - they are only 4 3/4 deep I believe - just a thought - ja**
  17. Budget36
    Budget36
    Thanks again, Gents.
    Thanks also Ja**, but I think at worst case I can change over to the earlier setup.
  18. They also went to external balance about that time (1970) and you would have to find a damper that is external balance. Or get your rotating ***embly balanced, it can be done they usually have to add Mallory (SP?) Metal.
  19. squirrel
    The 318 wasn't externally balanced. but the 360 was (and the later 340s, iirc)
  20. Thanks never knew that. I know that my ex bro in law had a '73 ( I think maybe a '72?) Dart Sport 340 and it was externally balanced. Still ran like a scalded ape. LOL
  21. Blues4U
    Blues4U
    from So Cal
    You mean Inlet, right?
  22. LOL hose barb. :D
  23. Burkedore
    Burkedore
    Inlet, outlet, same thing when you are all doped up on hydrocodone.
    Just to be safe, I meant the lower one.
    Blues4U and RMONTY like this.
  24. gene-koning
    gene-koning
    If you have to have a rad made, have them move the mounting brackets on the rad towards the motor so the rad sits a little more forward on the ch***is and in the grill shell. Should be able to shift that rad forward an inch or two (I can on my 39 Dodge Grill). Moving the mounting brackets on the rad will probably yield more room then the shorter pump. Gene
  25. Budget36
    Budget36
    I'll have to look that over hard...but my grill shell is kinda like a Model A shell, where the radiator is sitting flush with the front of the shell. There's no bars in front of it like a '32-up Ford grill.
  26. Budget36
    Budget36
    I knew what ya meant;)
