Projects The Y- BROCK Coupe
Discussion in 'The Hokey Ass Message Board' started by garage2small, Aug 18, 2015.
  1. garage2small
    garage2small
    Received and mounted the 682 C headlights I will be using today. Also Jim B fabricated and installed the seat brackets for the seat today, and yes the cloth will be replaced with leather and a different pattern. The seat is a center unit from a mini van complete with adjustable track and back angle from the local Pull A Part for the princely sum of 35 bucks. 20180108_181531.jpg 20180108_162632.jpg Also thought I would share a couple of pics of two of the car also under construction at Barillaro's 20180108_163538.jpg 20180108_163522.jpg
    kiwijeff, AHotRod, loudbang and 3 others like this.
  2. garage2small
    garage2small
    Getting closer to blowing it apart for paint. Got the OTB Gear headlights mounted, windshield is installed operates smoothly, Mikey B fabbed some cool header extensions and modified the baffles to fit, can't wait to hear what that Y block sounds like through them it was super loud unbaffled. The seat and steering column are in and fit me pretty well. The seat and rest of the interior will be given the black leather treatment. Shift lever has been cut off to rework it to clear seat bottom in 2nd and 4th. 20180117_142934.jpg 20180108_181531.jpg 20180108_154624.jpg
    mctim64, kiwijeff, loudbang and 2 others like this.
  3. garage2small
    garage2small
    Dam ! should have checked that previous post before I put the same photo and info in again.
    loudbang and lothiandon1940 like this.
  4. lothiandon1940
    lothiandon1940
    ............It's all good. We love seeing it no matter how many times you post it.:D
    lothianwilly71 and loudbang like this.
  5. garage2small
    garage2small
    Here are some progress photos that aren't repeats. Jim mounted the fuse panel, voltage regulator, coil, and heater so they are accessible yet out of view from the driver and p***enger. Mike's design and metal shaping for the E brake handle recess was a home run in my book! IMG951507.jpg IMG951508.jpg IMG951509.jpg Photos by Jim Barillaro .
  6. garage2small
    garage2small
    I could not find a ready made dash insert that I liked so this morning Jim picks up a sheet of aluminum and a couple of hours later he has fabricated a simple insert that adds just the right amount of bling around the SW gauges. The raised edge will be polished and the flat surface will either be engine turned or scotch bright pad rubbed to a nice satin finish. IMG951531.jpg IMG951530.jpg We rolled it out the shop for one last full view before taking it apart for paint, looking forward to seeing it in an evil shiny black topcoat! 20180124_171836.jpg 20180124_165627.jpg 20180124_163107.jpg The turnouts Mike made for the Geardrive headers look great and keep the baffles in place.
    enloe, kiwijeff, BCCHOPIT and 4 others like this.
  7. loudbang
    YAY for nice SHINY black topcoat. :cool:
    1947knuck, enloe, czuch and 1 other person like this.
  8. ty johnson
    ty johnson
  9. cadillacoffin
    cadillacoffin
    This turned out fantastic!
  10. el Roach
    el Roach
    WOW! Those headers!!!
    lothiandon1940 and loudbang like this.
  11. Blue One
    Blue One
    from Alberta
    I have to say that I love this build. The coupe is turning out really nice.
    Hard to beat an A coupe on 32 rails.
    And you can probably figure out Y I like the Y Block ;)
    If I build a coupe after my RPU it will be similar to this one :cool:
    crminal, loudbang and lothiandon1940 like this.
  12. garage2small
    garage2small
    The baffle was modified to fit then welded to the stainless extension and the unit is held in place on the header with two set screws out of sight on the bottom side. . 20180202_160532.jpg
  13. BCCHOPIT
    BCCHOPIT
    Like the extra length!!!!
  14. garage2small
    garage2small
    More progress is being made on the coupe, the Barillaro brothers have been doing body prep for paint and shot the first coat of primer today. One step closer to shiny black! 20180217_121957.jpg IMG951677.jpg IMG951676.jpg
    enloe, 51box, crminal and 3 others like this.
  15. seadog
    seadog
    Yes Sir, that’s a Hot Rod!!
    lothiandon1940, kiwijeff and loudbang like this.
  16. loudbang
    YAY for SHINY Paint
    1947knuck and kiwijeff like this.
  17. Tim
    Tim
    from KCMO
    Very cool
  18. garage2small
    garage2small
    Well the coupe did not get completed in time to take it to the LSRU, but a lot of progress has been made in the past two weeks and it should be on the road soon. The ch***is is painted and about 95% ***embled, 20180409_171124.jpg looking great in shiny black single stage. The priming and blocking is finished and the body will receive its shiny black single stage before the week end. Thanks to the Barillaro brothers for all 20180409_160851.jpg 20180409_155042.jpg 20180409_161137.jpg 20180331_082615.jpg 20180328_214321.jpg their hard work on this project.
    55Deso, loudbang, crminal and 2 others like this.
  19. lothiandon1940
    lothiandon1940
    This is gonna be sooooooo sweet!:D
  20. garage2small
    garage2small
    The body received some paint yesterday. 20180412_175303.jpg 20180412_175312.jpg 20180412_175346.jpg
    1lucky1, Blue One, enloe and 7 others like this.
  21. y'sguy
    y'sguy
    from Tulsa, OK
    Oh My!
  22. loudbang
    NICE real nice.
    1947knuck likes this.
  23. garage2small
    garage2small
  24. hotrodA
    hotrodA
    Looking GREAT!
    I can only stand in awe of Mike and Jim's abilities. They're just fantastic.
  25. garage2small
    garage2small
    It's a roller now, brakes and clutch are operational, gauges are set in the panel and wired. 20180418_154552.jpg 20180418_152356.jpg 20180418_153026.jpg
    1lucky1, enloe, loudbang and 3 others like this.
  26. garage2small
    garage2small
    Got the seat back from the upholsterer today. It looks grey in the photo but it's actually black. 20180502_162753.jpg 20180502_165002.jpg
    1lucky1, Blue One, 55Deso and 2 others like this.
  27. hotrodA
    hotrodA
    VERY nice!
    Was that done in Knoxville?
  28. garage2small
    garage2small
    Yes it was done locally by Kirk's Kustom Upholstery. High quality, fair price, quick turn around.
    Blue One, loudbang and lothiandon1940 like this.
  29. lothiandon1940
    lothiandon1940
    .............Beautiful job on that seat.
  30. loudbang
    Man that whole interior looks GREAT :)
    1947knuck and enloe like this.
