Projects 1932 Roadster Project
Discussion in 'Traditional Hot Rods' started by AULIZ, Jan 4, 2018.
  1. AULIZ
    AULIZ
    Happy New Year HOT RODDERS all over The Ball.
    I was 2days out of homeoffice and same time picked up new Project.
    Project arrived from Houston Texas (Originally from Iowa) few days ago. Now familymember is safely in own garage.
    I built this car ready during this winter. Some body changes, change engine and ******, drop down rear end of body and maybe little front too,......
  2. Stogy
    Stogy
    Awesome Hotrod, awesome garage, looks like it'll be ready to fly down the dry lakes soon.
    Looking just so right @AULIZ. Congratulations & Happy New Year to you to.
    Mr T body and lothiandon1940 like this.
  3. Bandit Billy
    Bandit Billy
    Santa was good to you!
    lothiandon1940 likes this.
  4. Nobey
    Nobey
    Looks good, have fun, and keep us posted.....
  5. $um Fun
    $um Fun
    from Nor Cal
    Love the molded wood P-40 seats, you don't see to many of those.
  6. AULIZ
    AULIZ
    Thank You Sirs.
    You are correct about those military seats. Made By Friz Zieparth Co. Rialto CA.
    I bought those from Reno-NV. Older Gentleman, Hot Rod builder who has many times interesting stuff for sale.
    Aulis
    lothiandon1940 and Stogy like this.
  7. waxhead
    waxhead
    from West Oz
    We need more pictures :)
  8. brady1929
    brady1929
    With your skills, it's going to be amazing.
  9. AULIZ
    AULIZ
    Never knows,.... but I try my best.
    Still try to remember few phrase:
    -Hot Rods are made for driving, not for trailer queens
    -Dare to be different, but keep it simple.
    ah
  10. x77matt
    x77matt
    Looks great! Subscribing!
  11. Latigo
    Latigo
    Another one escapes to Finland. Nice looking project. I'll follow along.
  12. AULIZ
    AULIZ
    I have been lazy,... but today worked hours with roadster.
    Need to make holes to that panel and tigweld those new sheetmetal pieces there.
    Taillights are 40´s K-D 540.
    Dash is next after this. Need to shape it to fit auburn style alum. dash panel.
    Aulis
    IMG_4698b.jpg IMG_4696b.jpg IMG_4695b.jpg IMG_4693b.jpg IMG_4691b.jpg IMG_4690b.jpg IMG_4701b.jpg IMG_4694b.jpg
  13. AULIZ
    AULIZ
    Now sheetmetals are welded and lights bolted on.
    Tomorrow need to cut and weld dash.
    Aulis
    rod-roadster 2017-1b.jpg IMG_4713b.jpg IMG_4710b.jpg View attachment 3768849 IMG_4708b.jpg IMG_4706b.jpg IMG_4705b.jpg IMG_4703b.jpg
  14. AULIZ
    AULIZ
    Dash changed.
    Gauges and gaugepanel bought from HamB, thanks "n***aublue65" VA Usa.
    KD taillights bought also from HamB, thanks "hb32", B-C Canada.
    Aulis
  15. Just Gary
    Just Gary
    Beautiful work.:cool:
    chevy54man and lothiandon1940 like this.
  16. brady1929
    brady1929
  17. movingviolation
    movingviolation
  18. AULIZ
    AULIZ
    Thank You Sirs.
    Two days out of Garage, but today I was continue.
    pictures coming soon.
  19. AULIZ
    AULIZ
    Here today result. Continue Friday Morning.
    I like more original style body, when Wood tack rail set is "dropped", so... I cut and weld.
    Total drop is 1/2" . Cut upper side of tape.
    Aulis
    IMG_4746b.jpg IMG_4745b.jpg IMG_4744b.jpg IMG_4743b.jpg IMG_4742b.jpg IMG_4736b.jpg IMG_4735b.jpg
  20. AULIZ
    AULIZ
    few pics bodyworks.
    some engine swap pics.
    somebody has made nice clutch arm......
    Maybe I change it original 1932 arm.
    aulis
    IMG_4768b.jpg IMG_4766b.jpg IMG_4765b.jpg IMG_4764b.jpg IMG_4763b.jpg IMG_4762b.jpg IMG_4761b.jpg IMG_4758b.jpg IMG_4757b.jpg IMG_4755b.jpg IMG_4751b.jpg IMG_4747b.jpg
  21. AULIZ
    AULIZ
    Questions:
    1) what is difference between 1939 Double Detent ****** gears and Lincoln Zephyr gears? Earlier I have had only DD ******s and this one with LZ gears I have keep stored for good Project.
    2) Gemmer steering box. Looks like 1932 Ford original box, but this one has very long columnshaft and -tube.
    Steering wheel is higher and upper. Maybe I need to cut column .... Now looks like strange.... What is this steering box? Is there many different lenght steering column/column shaft in year 1932?
  22. wheeltramp brian
    wheeltramp brian
    never seen offy heads without fins.whats the deal?
  23. Vanness
    Vanness
    The car and the charger look awesome.
  24. AULIZ
    AULIZ
    Maybe fins has been broken, not good condition and somebody has cut all....
    I have just fixed , rounded all corners and blow with gl***...
  25. Drylake
    Drylake
  26. trey32
    trey32
    Is it possible that it's a model A steering box??
  27. AULIZ
    AULIZ
    I do not know. I have never had any model A box. I do not belive, because A-ford box is 4" longer than B ford box.
    Not that way, not possible.
    I slide out column tube and one thing is sure, nobody weld this column axle longer. Looks like very good condition and original lenght.
    All dimensions, size,...is same than original 1932 ford - 1934 Ford.
    Only that mounting adapter is not same those 33 and 34 yearmodels, if we compare those for 1932 box..
    I was google and try to find info Sunday evening and Im rather sure that its BB box.
    I open box when I take body off and work with frame.
  28. On the transmission with LZ gears, you should be able to just use a stock 39 top - there is nothing special to do for the LZ gears. You'll be using the same synchros, slider, main/tail shaft, first gear slider, reverse gear and small parts kit. If you're building the trans, make sure you have the correct clearances and fitment on everything - especially the main shaft front, ***ociated bearings, 2nd to main fitment, etc.
    The issue that I hate the most (with any 39 box) is the tendency to pop-out of second gear when you slow down (especially at higher RPMs). On the 39 LZ box I build for my 32 cabriolet, I had Charlie NY rebush the second gear for a tight fitment to my specific main shaft (he is the only guy I know that does this). I made new shafts for the cluster and reverse (as I could not find NOS ones and the repops are incorrectly sizes). Make sure you have good quality parts and not some of the repop junk - talk to VanPelt if you need things. Anyway, when it was all done, it stays in second as it should - that makes me very happy.
    Note: If you want a little 'rebuild book' that I put together - along with Dennis Lacy (he let me modify his original text), then drop me a PM. It shows the special modifications that I do on top of a 'regular' 39 trans.
    Take care!
    B&S
    PS: Might be coming over to Finland with some of my family this next summer. Mom has never been (she's 85) and is 100% Finn!
    Tuumer, Ric Dean and kidcampbell71 like this.
  29. AULIZ
    AULIZ
    Hello,
    THank You for Your advice. I need to read it twice more (not so good english).....
    I have bought this LZ gear ****** ready rebuilt from older man (california). He has rebuilt 3 speed ford ******s over 60years. I have rebuilt some normal 1935-38 ******s and two full syncro 1939 DD ****** too. No problem, easier than Muncie 21 and 22 ******s and bearings are free for me (I sell bearings my dayjob). Old US made ******s and superchargers have metric bearings, very low price here and our Company has over 6milj.Usd value stock,...so "I can take some bearinngs for test use".
    I was just interested in to know what are main differences between LZ gear ****** and 1939 DD ******.
    Is 3rd gear same ratio ? I think, that maybe LZ ****** helps me, if there is 3.78:1 ring and pinion in my roadster rear end....
    Please, let me know if You come to Finland next summer. Do not rent car. Just drive fast train from Helsinki Airport to Seinajoki (350km, 2hours) and take my Mercedes. It´s only C-model turbo diesel, but its STW, so easy to take bags, luggages. Free car for You (one week, two week.....as long as You need it). I drive summer season hot rods, so not need car. You need only to buy diesel (approx. 1,6usd litre), but this 6y old turbodiesel takes 5-5.5litre 100km (8-9litre 100miles 8-9litre= little over 2gal/100miles). I drove 3years 2005 Ford Mustang, but sold it last March and buy again diesel Mercedes dailycar. Mustang was little too expensive to use all winter. Expensive kilometers, winter tires, not so good heater,.... but it was so cheap car (10/2013 I bought it from LA area 6000usd and exchange rate was very good for me), so I still get 5000euro profit when sold it last year,.... Normally You never get profit with dailycars.
    bambbrose likes this.
  30. chevy54man
    chevy54man
    from NC
    Wow, awesome work on that car! Love the Hot Rod poster too!
