Projects Pounding out a T roadster
Discussion in 'The Hokey Ass Message Board' started by justabeater37, Nov 22, 2017.
  1. justabeater37
    justabeater37
    And this is where it sits now. Done for the year. Time to take my wife out for supper since we didn’t go out yesterday for her birthday. 63EEB690-AB6D-4C52-9159-BBAA5B9D5CBF.jpeg 914AC181-FE92-4183-A8FA-CEC3F67EB0A7.jpeg FFD0E55B-2B30-432E-95E5-7C3696BEC68B.jpeg
    Flipper, Tim, Dannerr and 14 others like this.
  2. 56 Dodge Pickup
    56 Dodge Pickup
    How are you bead rolling the panels after they are on the car? Great Work very impressive!
  3. justabeater37
    justabeater37
    It was the turtle deck. My son helped, I man handled. Had to add the bottom piece in the rear anyhow so rolled it before welding.
    spurgeonforge and loudbang like this.
  4. 56 Dodge Pickup
    56 Dodge Pickup
    Ahh that makes sense I was trying to figure out how you rolled that after welding I thought you invented a new tool. Happy New Years ! Hobo Jim
  5. justabeater37
    justabeater37
    And I decided to fall down the stairs. Trip to the ER with a broken toe, 9 s***ches and IV antibiotics. Progress may be slowed for awhile. I won’t blow that picture up.
  6. Stogy
    Stogy
    Happy New Year...;)...it could have been worse...you lived to tell the story so to speak...this year new leaves arrive...liking your adventure...keep it up.​
  7. justabeater37
    justabeater37
    It gets me a day off work tomorrow but will probably hurt too much to go to the shop. That means I will likely sit at the keyboard and spend money.
    juan motime, brEad and loudbang like this.
  8. Stogy
    Stogy
    Rest it Beater...take in some of the Hamb projects going on...glean..glean...glean and then get back on to that evolving machine...Did you check out the Pizza van T @edwardlloyd put together...Happy New Year again...
    Dannerr, brEad and loudbang like this.
  9. justabeater37
    justabeater37
    I did see that one, and the 32 out of a VW beetle.
    kidcampbell71 and loudbang like this.
  10. justabeater37
    justabeater37
    Too bad I wasn't far enough along to start the upholstery. I could sit at my sewing machine.
  11. 56 Dodge Pickup
    56 Dodge Pickup
    Like Stogy said just sit back and relax I was going to grind welds today on my 37 build but I may just hang out with my family Happy New Year ! Hobo Jim
  12. So...did you cry?...Seriously, just between you and I...I won't tell anyone.
    Hope you're back on your feet soon...literally.
  13. justabeater37
    justabeater37
    Due to my broken foot, no progress in the shop. However, spending time at the desk spending money and ordering stuff. Paint for the outside, Vinyl for the inside, and Excelsior Stahl Sports for the roadside. Foot hurts too bad after work to work in the shop. Wallet hurts too bad sitting at the desk. Now to decide if the wheels should be black to match the ch***is, or red to match the body. Or do I go red on the outside and black on the brake side? I have 40 ford wheels and center caps with ribbed trim rings 279DF5F6-41D5-45EB-BE2F-9CF41B597989.png 4C4CDB90-0C54-42D3-AF85-3CD0A469E19E.png
  14. 1-SHOT
    1-SHOT
    from Denton
    Your color combinations look good. I think the wheels will look good body color with ribbed trim rings , but I think I would paint the backside red just for the contrast.
    Frank
    justabeater37 likes this.
  15. justabeater37
    justabeater37
    I was contemplating going black on the back of the wheels since the brakes on the 8" are 10" vs the 12" Lincolns up front. It would make the difference less noticeable. Right now I don't know which hurts more, my foot, or not being able to go to the shop.
    indestructableforce and loudbang like this.
  16. justabeater37
    justabeater37
    New science experiment to clean up these hood sides. Citric acid. AB0D6D96-3D1A-4E4D-8A51-9B16C337CC72.jpeg A92AA679-F563-4584-B941-5CD6B40C1E6F.jpeg DCE138E8-4E99-4579-A2AD-2666725C9A01.jpeg A1B54DDC-79D7-45C3-8F70-CF7821B49422.jpeg DB7F2E8D-09B6-4D89-B324-D8C2D63E02E6.jpeg
    Tim, Stogy, Dannerr and 5 others like this.
  17. tfeverfred
    tfeverfred
  18. justabeater37
    justabeater37
    It’s working. Should be good by tomorrow. I have to go back to the spe******t for my foot on Wednesday. Hopefully I can be back on this thing full speed again. CEC47C34-6D1F-4C9B-9E37-5CF3965E36E8.jpeg 0363B016-0F3C-4668-8497-42471A08B16A.jpeg D99A4EAB-D441-46AB-8986-1DF0090E1A55.jpeg
    Tim, Stogy, Dannerr and 7 others like this.
  19. Roadsir
    Roadsir
    Citric acid looks like it worked pretty well. Was thinking about using evaporust on some ch***is parts. Might try that instead.
    Whereabouts in IA are you?
  20. justabeater37
    justabeater37
    Somebody asked about heavier rust on Facebook. It takes a little wire brushing but still works. I am about 10 miles east of Iowa City Roadsir 2F98A2A3-D026-4FC4-BDFC-14D1BF244C76.jpeg 1DD963E6-C231-4324-912C-25CA001F9F05.jpeg 255192F0-2591-4010-81E1-2FDA7939FE07.jpeg
    Dannerr, patmanta, brEad and 3 others like this.
  21. I'm gonna have to try citric acid. Looks to work pretty quick and do a good job. I've got plenty of stuff to use it on, too.
  22. Finnrodder
    Finnrodder
    from Finland
    I have used citric acid for years.It works fine with the sheetmetal parts,but it destroys cast or forged pieces.I have used 5% mixture,let the piece sunk there 24 hrs,rinse it with water+brushing it with steel brush.After that an another 24 hrs again and some brushing and rinsing.If the piece is done,after the rinsing i have dried it with a heat gun.Without drying it will start to get some rust again.Usually that 48 hrs works,but it doesnt hurt anybody to let it be in there longer.If you can warm the citric acid somehow,it will be more effective when the acid is warmer.
    Keep up the good work!
    Stogy, Dannerr, AndersF and 3 others like this.
  23. justabeater37
    justabeater37
    Indeed it may be weak but it is an acid. I wouldn't use it on anything that I feared hydrogen embrittlement. Better safe than sorry.
    Dannerr and loudbang like this.
  24. justabeater37
    justabeater37
    Pulled the hood sides out and wire wheeled them with a drill. Ready to cut down hopefully tomorrow night. Doctor appointment for my foot tomorrow so fingers crossed that all is well with it and I can get back in high gear. Here is a running board that was left outside for years with only primer on it. Guess which end was in the barrel. C3822F8B-B780-4A3C-878C-9D553BEB8BC1.jpeg C91E2D45-5967-4F12-A40A-D77AED2E7286.jpeg 36DFF580-E6CF-4EA0-B201-1FC1F238EC99.jpeg
  25. mkebaird
    mkebaird
    Love that Citric acid - I used a 7% solution
  26. justabeater37
    justabeater37
    Well, the orthopedist cleared me to go ahead and do whatever I can tolerate. Spent 3 hours in the shop working on the hood sides. Unfortunately, my phone died, so no tutorial on wire edging them not using the bead roller. I will use the bead roller to finish them though after making a flat lower die. I also ran to town to buy a bunch of stuff before Ch***is Engineering closes up shop for good, which sounds like end of this week, or early next week. I will likely be listing a bunch of stuff in the cl***ifieds at a later date. I will try to get back to the pictures tomorrow.
    bobwop and loudbang like this.
  27. Roadsir
    Roadsir
    When you say 7% I ***ume that's by volume?
  28. justabeater37
    justabeater37
    I mixed mine 20 pounds of acid to 50 gallons of water. I don't remember what that ended up as percentage wise. I can try to find the chart again.
    loudbang and mkebaird like this.
  29. mkebaird
    mkebaird
    Yes. I just used a 2x6 frame & pond liner to do doors and fenders.
    Roadsir and loudbang like this.
  30. justabeater37
    justabeater37
    Bottoms redone. Now to figure the tops out. 3A2F3399-34BB-4F65-8A8D-CCB34675030D.jpeg 96DEFF17-1285-4847-93FF-C3E669418EEB.jpeg 054B9A1A-142B-441F-9479-686AC926F504.jpeg
