Hot Rods Fabricating a Battery Cable to lug end crimper
Discussion in 'The Hokey Ass Message Board' started by blazedogs, Jan 9, 2018.
  1. blazedogs
    blazedogs
    Ya normally one crimps the lug on the battery cable before you install the wire on the car , doing it in a vise, hitting it with a big hammer on a hard surface or whatever. Too late , I don't want to back up.. Have any of you made a Battery wire to Lug crimper or done it in such a manner that will be secure, doing it when it,s on the car ? Gene
  2. Yep ^^^^^ These are the one I have. Made by Greenlee.
    [​IMG]The Wizzard
    upspirate likes this.
  3. blazedogs
    blazedogs
    Looks great but probably expensive Won't be using the tool that often to justify the cost. Thanks tho
  4. MercDeuceMan
    MercDeuceMan
    from Indiana
  5. I'd bet an industrial electrician would have them.
    At the very most it Might cost you his service call charge.
    If you wanted to fart around you probably could grab a set of bolt cutters and modify them.
    I've squeezed and reset and squeezed and rest vice grips till the lug gets tight in a pinch & then soldered the lug. The problem is you need a lug that fits super snug to pull it off. I've also used the frame rail as a the vice and a hammer.
    Chiss likes this.
  6. wraymen
    wraymen
    Borrow one, any Electrician, Utility worker, lineman should have one. Bring the lug with you to see what die you will need. Ratchet ones are not as good but much cheaper.
    olscrounger likes this.
  7. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Never done any while on the car. That's because I solder mine.
    46international likes this.
  8. squirrel
  9. I've soldered them on the car, just did one last week on my wife's car.
  10. Johnny Gee
    Johnny Gee
    from Downey, Ca
    There's trickery in what I wrote. Away from it with slack ;).
  11. tb33anda3rd
    tb33anda3rd
  12. rusty valley
    rusty valley
    ya go to the local tractor dealer. they have nice ends and a hydraulic crimper. its cheap
  13. Burkedore
    Burkedore
  14. upspirate
    upspirate
    On a threaded terminal, not a post though
  15. Sheep Dip
    Sheep Dip
    from Central Ca
    I've made several cables over the years I use an anvil and a center punch just before I fill the void with solder, cool, clean, coat with dielectric grease then shrink wrap a heavy duty sleeve over it.....never had a problem or failure.
    Chiss, 302GMC and stanlow69 like this.
  16. I forgot all about those! They are really easy neat and clean at the battery.
    Are we doing a battery post or a lug on a stud, like a starter?
    MrPhat40 likes this.
  17. choptop40
    choptop40
    Remove it , use a chisel ...smack one side ..reverse smack again ....first get some shrink tubing...then slip it over and heat it with a cigarette lighter.....yes .no .maybe..
  18. Rocky
    Rocky
    Classified Editor
    • Being in the truck and heavy equipt. repair bidness for 40 years, we never, ever relied on a crimped on cable end. It was easier and much better to remove the last 3/4 inch of insulation from the end of the cable, clamp the end in a vise and use a propane torch to heat the cable end while poking resin core solder in the opening..fill it with molten solder and when it's 3/4ths full, stick the skinned-back end of the cable into the pool of solder in the cable end....hold it in place for about 10 seconds...run some shrink tubing over the junction when it cools a bit and you're done! Even running it on a salt truck won't hurt it...try that with a crimped end and you'll be out on the street at 3 am fixing it! Do it right and you'll only have to do it once..jus sayin
    • This can also be done with the cable still on the truck/car. Just use vice grips to hold the end still while heating it.
  19. blazedogs
    blazedogs
    Yes
  20. slowmotion
    slowmotion
    Take it to your local Napa. They should have the facilities to crimp & or solder that up in short order. IF you're a regular customer, chances are they'll fix you up & send you on your way.
  21. butch27
    butch27
    Local welding shop did mine for free
  22. carryallman
    carryallman
    send yours to me -i will do & return -im about 4 hrs away & "speedy " or postal is cheap ?? thanks mike
  23. Blues4U
    Blues4U
    from So Cal
    Hey guys, he's asking about doing it ON THE CAR. The cable is already on the car, now he wants to crimp the terminal onto it. It' kinda late to have NAPA or the local welding shop do it, or send it to anyone.
  24. bobss396
    bobss396
    I have a Thomas & Betts one at work and I bring in what I need crimped. For my Ford, a local speed shop fabbed up my battery cables from my cave-wall sketch. 20 minutes and $40 I was out the door.
  25. Canuck
    Canuck
    Battery cable crimper made from a old Nut Splitter, modified the original chisel and welded in a adapter to keep the connector from flattening. Checked results with some High Voltage Electrician friends, their verdict, excellent. Some glue filled HD heat shrink and good to go.
    Made connector Lugs from a piece of copper tubing that was a snug fit on the "0" welding cable I was using on the coupe.
    Canuck
    Fitty Toomuch, RMR&C, Kiwi 4d and 2 others like this.
  26. nochop
    nochop
    from norcal
  27. gatz
    gatz
    @ Canuck, I like the re-purposed nut splitter idea. Got one that's been sitting around for 40+ years and only used it twice. (only worked once....)
    If using a crimp fitting (no solder) what would be the best thing to help conductivity?
    Di-electric grease, some type of metallic paste, heat sink paste/compound, or leave dry?
