hows this for a floor??
Discussion in 'The Hokey Ass Message Board' started by A to Z speed, Apr 29, 2006.
  1. A to Z speed
    A to Z speed
    here are a couple shots of my floor that i'm finishing up in my 28 A, this car has about 90 % brand new sheet metal on it... due to some ***hole wielding a 12 gauge... new firewall, lower cowl on both sides, both doors inside and out, both rear quarters, wheels wells and decklid, and of course the floor. luckily most of the beltline was unmolested and the cowl was only rust-stricken on the bottom. i'll have to get some before and after pics of the body, some might see it a waste of time- it was that bad... hows it look??
  2. gasheat
    gasheat
    from Dallas
    Good plan, Good execution. You should be proud.
  3. evilgenius
    evilgenius
    i think it's quite lovely, even with just the tack welds.....
  4. Mule Farmer
    Mule Farmer
    from Holland MI
    I can see why your proud of it very nice work.
  5. Haunted Ken
    Haunted Ken
    That boy has skillz.......
    Nice work!
  6. pistinbroke
    pistinbroke
    Want to re-do mine? Those look great!!!!!
  7. Just Gary
    Just Gary
    Looks great!
    It would be a shame to cover that up with upholstery-- it needs to stay exposed for everyone to enjoy.
  8. Levis Classic
    Levis Classic
  9. Scott
    Scott
    Great metalwork. Definately should be exposed.
  10. JD's 32
    JD's 32
    from TX
    Man thats good!
  11. LUX BLUE
    LUX BLUE
    Alliance Vendor
    from AUSTIN,TX
    Heh...you've built a couple race cars,I see...only thing missing is the dzus fasteners!
    nice work! you obviously have good fab skills so I ask a question not to ruffle feathers, but out of curiosity--why no support beads rolled into the actual floor panels?
  12. A to Z speed
    A to Z speed
    well, i used 16 gauge for the floor which the roller at the shop won't touch, for one reason, and there's enough support under the floor with the trans "K", and when i mount my bomber seats i'm gonna make brackets under the floor and tie in the the frame, so that will finish it out. with everything tied in together, the thing is really, really strong anyway... now i have about a million more tack welds to finish. Now that i have it almost done, i'm kinda up in the air about the carpet and interior plan...
  13. Brewton
    Brewton
    Very nice work! Can't wait to see the completed hotrod.
  14. jalopyshots
    jalopyshots
    Hey gary, saw your chevy in Rod and Custom, looking good.
  15. Dirk35
    Dirk35
    Nice. If you can un-do those tack welds on the floor pans, do you think you would put a couple of beads on the floor panels? I didnt on my 35, and they "oil canned" after welding them every 4 inches with a 2 inch long weld bead. I wish I had a bead roller then, I do now.
  16. A to Z speed
    A to Z speed
    in my opinion, welding a 2 inch bead is a exessive for any sheet metal. i like to stick to a bunch of tacks, just to be safe, and only do about a half an inch at a time, depending on the area and joint. on my quarters, i did no more than three tacks in a row in the flat areas, and immediately blow with air to cool. about an hour later, your done w/ a 10" seam before you know it!! you can keep beer canning down as long as you dont get too antsy.
  17. Flipper
    Flipper
    from Kentucky
    Almost ****.
  18. tred
    tred
    i thought we were seeing the "carpet and interior"! :D
    great work!
    nice fit and finish.
    tred.
  19. Good job, but what the heck is beer canning ? You mean oil can ?
  20. A to Z speed
    A to Z speed
    oops, maybe i had to many oils last night!
  21. Tony
    Tony
    LMAO :)
    The fab work looks great! Nice job.
    Tony
  22. ray
    ray
    from colorado
    looks great, but my smart ***ed question is: why didn't you make the side panels etc. removeable instead of welding them in? at some point down the road chances are you are going to need to get in there for some reason, it'd be a shame to have to cut out all that metal for access.
  23. mikekillstheday
    mikekillstheday
    wow. thats amazing
  24. G V Gordon
    G V Gordon
    from Enid OK
    Just starting to figure out a floor for the A tudor I have. That is very nice work. Inspiring, in fact. Thanks for sharing!
    GV
