Projects 1930 Sportster, shortened cockpit, tilted post cowl, door caps.
Discussion in 'Traditional Hot Rods' started by sloppy jalopies, Dec 16, 2017.
  1. sloppy jalopies
    sloppy jalopies
  2. fiftyv8
    fiftyv8
    from CO & WA
  3. chrisntx
    chrisntx
    from Texas .
    Ambitious
    markin59 likes this.
  4. waxhead
    waxhead
    from West Oz
    What are your plans for the build??
  5. sloppy jalopies
    sloppy jalopies
    wow... now that is a coupester ! … great ideas, skill = great MODEL A body.
    Coupester parts pile ;
    '30 cowl, tilted and narrowed posts..
    Vicky filler panel between w/s and tanktop..
    cheap asz, polished aluminum, closed car w/s frame [speedway]..
    truncated '30 coupe doors with home made caps or armrests..
    sport coupe quarters, 3" of door cap to match the door cap line..
    panel above / below deck, trunk lid..
    front half stock subfloor.. kicked rear...
    '38 car dash..
    bobbed rear fenders...
    maybe a '38 truck grill, hood sides, and the front 1/2 of the hood top, [Banister '32 roadster].
  6. vtwhead
    vtwhead
    Smitty, looks like you have healed up and are back it. Nice winter project. Gee, is that "snow" lying on the floor by that machine??????? Washed the Rv yesterday.....it was 49 here in KY:):):)
    sloppy jalopies likes this.
  7. sloppy jalopies
    sloppy jalopies
    last year i fabbed this '30 closed car cowl with tilted back 10* and narrowed [F-R] w/s posts...
    narrowed [L-R] lower A pillars...
    chopped w /s posts... temp. header...
    '32 cowlvent in an A tanktop...
    gonna take the coupester the closed car cowl route...
    DSCN1687.JPG View attachment 3748148
    tb33anda3rd, brEad and biggeorge like this.
  8. sloppy jalopies
    sloppy jalopies
    played around this am, wizzer and some duct tape;
    .the white showing from underneath is the roadster cowl section...
    .stantion looks to need a little t******* for the door top to fit ...
    . View attachment 3748293
    going to build the steel inner structure with threaded bungs for the w/s stantions before I weld up the skin so I can get at it...
    going to try and cut the tank top off with a nibbler Monday...
    tb33anda3rd, bct and brEad like this.
  9. sloppy jalopies
    sloppy jalopies
    If you have not cut the top off a '30 A tank...
    IMO...cut it about 1.25" from the top... all the baffles are soldered to the bottom and sides not the top... I cut all the way around and the bottom half fell off...
    if you start at the bottom you will have to cut it into 20 pcs. to get at the baffles.
    I drill [10] 1/4" holes into the remaining flange to hang a wire harness from... . DSCN2015.JPG
  10. Vanness
    Vanness
    You doing all this today???
  11. sloppy jalopies
    sloppy jalopies
    yesterday,
    today i removed the broken tank screws in the firewall, tapped them out to 1/4"-20... plowed 2" of new snow...
    took pix saftanoon... bum knee, down for the day.
    biggeorge and Stogy like this.
  12. vtwhead
    vtwhead
    plowing with a bumb knee! Not what the DR. ordered I bet..................can't keep a good Mainer' down for long:rolleyes::rolleyes:
  13. The37Kid
    The37Kid
    That must have been a problem when the A's were new, at some point Ford spot welded a plate behind that bracket. Bob
  14. wheeldog57
    wheeldog57
    Go Smitty, Go! I am watching (and learning)
  15. sloppy jalopies
    sloppy jalopies
    have had them both ways...
  16. dumprat
    dumprat
    from b.c.
    Wicked! Right up my alley. Start with cast of junk and build something cool.
    carolinakid and King ford like this.
  17. sloppy jalopies
    sloppy jalopies
    brEad, biggeorge, Blues4U and 6 others like this.
  18. sloppy jalopies
    sloppy jalopies
    Got the right side closed car cowl to the roadster stantion skin welded in today, had to invent a little skin as the patch was short to start with...
    looks like I will need to add about 1.5" to the width of a closed car w/s frame for it to seal flat against the stantion's face... DSCN2036.JPG
    Getting a little done before Santa cruises by in his "slay"...
    taped a '28 roadster stantion to the cowl for ideas... not today !
    tb33anda3rd, brEad, biggeorge and 2 others like this.
  19. Just found your post and looking forward to following as I am just into the same on converting my '31 sport coupe to roadster style windshield. After considering modifying the existing posts, doing '29 stantions or 30-31's decided on the '31's. Have to order the pricy littles devils first though (none close by here in western Canada).
    Look forward as to what you plan to do for the support in the door post for the stantion to bolt to ( ie, for the factory cast ram horn idea). Been looking at that- not a lot of room to put something in there and get a good weld. Needs to be good to combat the wind and wind vibration on the windshield. Thanks.
  20. sloppy jalopies
    sloppy jalopies
    Sorry to anyone wanting to follow the closed - roadster cowl... I am going to use the narrowed [F to B] and tilted back 10* posts '30 cowl...
    I have a $300 polished aluminum w/s frame and the closed car cowl lets me use it...also has all 4 cowl hinges... no need to buy roadster hinges...
    I also had already narrowed the A pillars L to R for a more roadsteresque [thinner] look and lets me narrow the doors to match... note the lower hinges only have 2 screws...
    still may reverse the '30 firewall ?...
    DSCN1687.JPG DSCN1691.JPG View attachment 3756541
    tb33anda3rd and biggeorge like this.
  21. sloppy jalopies
    sloppy jalopies
    And let there be doors !, well one anyway.
    armrest section removed... View attachment 3763183
    .buddy "spanky" hammerforms these door tops on a wooden buck... $50 -pr. ... DSCN2064.JPG
    . save that section that overhangs, it can be the rear quarter cap so it matches the door... DSCN2065.JPG DSCN2066.JPG DSCN2067.JPG DSCN2068.JPG DSCN2069.JPG DSCN2070.JPG
    going to narrow the doors to the white line, should give the doors the more roadsteresque look... DSCN2071.JPG DSCN2080.JPG DSCN2083.JPG
    biggeorge, cactus1 and tb33anda3rd like this.
  22. Nice looking work, I always try to follow your projects.
  23. sloppy jalopies
    sloppy jalopies
    note the 2 layers of duct tape... more forgiving when grinding near the beltline creases... DSCN2099.JPG DSCN2100.JPG
  24. sloppy jalopies
    sloppy jalopies
  25. The37Kid
    The37Kid
    Looking good! I'm going down to the ba*****t and do something other than cut up firewood. ;)Bob
  26. Vanness
    Vanness
    Doors came out nice!
  27. vtwhead
    vtwhead
  28. sloppy jalopies
    sloppy jalopies
    just checked it out, nice job, revamps a standard dash, I posted a deluxe conversion on that site...
  29. sloppy jalopies
    sloppy jalopies
    Clamped the skeleton '40 dash to the cowl... used the front 18" of some compound curved hood as upper dash to cowl patches... needs work on the upper corners.... but I think an hour with a grinder and a little bondo can make it work... DSCN2115.JPG DSCN2113.JPG DSCN2112.JPG View attachment 3770739
    I may weld a 12" strip of trimmed stock "upper cowl / dash bar" to the inside of the dash, as it is a perfect match to the one in my '30 ... should align the dash to cowl nicely... maybe an alignment pin and a bolt into the A pillar on each side... I run a separate steering column support brace behind the dash...
  30. sloppy jalopies
    sloppy jalopies
    toughest part is done... jams, patch panels and inner panel to come... DSCN2126.JPG DSCN2127.JPG
    tb33anda3rd, Beau, biggeorge and 2 others like this.
