Technical GM Phillips head door hinge screws
Discussion in 'The Hokey Ass Message Board' started by S10_37, Jan 11, 2018.
  1. S10_37
    S10_37
    I have a #3 bit with impact no luck busting loose. Seen a #7 bit on the web but have to order 50 bucks minimum. Any suggestions.
  2. eaglebeak
    eaglebeak
    A good drill bit?
  3. Dave Mc
    Dave Mc
    I'm restoring a 53 Cad , same problem . I ended up using an air hammer chisel to break them loose , got some replacement screws from a donor car. heat also works well , if you can get them red hot and let them cool before trying to breakem loose .If the phillips head is gouged out , you can mig weld a hex nut to the head , turn them with a wrench , welding heat will break the rust free
    S10_37 likes this.
  4. Sporty45
    Sporty45
    S10_37 likes this.
  5. I have been known to drill the heads of them then extract what was left after the fact. I use a center drill to start with. then hit them with a drill bit a little larger then the shank of the screw. The head will actually crawl up the bit when you are almost onto the hinge.
    What you are left with is a good center for drilling or sometimes you can worry them out with a pair of vise grips.
    S10_37 likes this.
  6. American Pie
    American Pie
    from Lemont IL
    I was a bodyman since 1971. We used a hand held impact driver with an impact socket thst accepts 3/8th inch number 3 Philips tip. Use a lighter ballpene hammer to smack the driver and hold dead square to the screw. If you use a heavier hammer, you chance damage to the door or jam.
    I've never had one that would come out. Never had to drill, etc. We were on commission, so time was critical.
    Dave
    juan motime and tb33anda3rd like this.
  7. Dave Mc
    Dave Mc
    on my 53 the Hinge will not open wide enough to allow a square hit with Impact Driver,
  8. vtx1800
    vtx1800
    This is the method I use, as stated before heat the screws up red hot, after they cool I squirt 'em with FreezAll (that's not a correct spelling, sorry)or your favorite lube choice, then I use the tool pictured below that I made, I cut apart an air chisel tool, a 3/8 extension and welded them together as shown, then put the tool in your air chisel and hit it in bursts until it breaks free, I've got them loose where the manual hammer didn't even touch it, I guess that vibration is the key to loosen them up, I go both clockwise and counter clockwise just like you have to do using a wrench on a stubborn bolt. I think I got this idea either on here or on Garage Journal, I can implement good ideas, just don't have a lot of originality of my own:) On my Studebaker I replaced the screws with a socket head screw, I know it's not original, no one can tell at 60 MPH IMG_1218.JPG
    302GMC, egads, tb33anda3rd and 3 others like this.
  9. Jim Lato
    Jim Lato
    ive gotten them loose by first getting them cherry red. then crank
  10. Dangerous Dan
    Dangerous Dan
    I used the bit adaptor and # 3 bit from a hand held impact screw driver and a 3/8 to 1/2 socket adaptor with a 1/2 in air impact wrench. Got all 16 out and saved every one. PB Blaster is your friend.
  11. Halfdozen
    Halfdozen
    Heat 'em up, don't have to be cherry red, touch a candle to them. You'll be amazed how the wax will wick into the threads. Works on all sorts of things.
  12. AZbent
    AZbent
    I have a tool very similar to what vtx1800 showed. In the aviation industry it is called an "old man", yes they are sold at places that specialize in aviation tools. The only time I have to drill the screw is when the head is completely stripped. The old man rarely let's me down.
    vtx1800 likes this.
  13. The tool shown above with a bit of valve grinding compound on the bit will usually shift them. Never met one that won against the oxy-acetylene as well.
    vtx1800 likes this.
  14. jazz1
    jazz1
    Heat them up one at a time, once cooled a couple minutes turn it out. Removed 10 that way on my chev. Heat is a real time saver
  15. Had the same problem with the hinge screws on my model A. Since I was going to replace them, I didn't care about destroying them. Ended up welding nuts with the same inner diameter as the screw heads to the screws. It heats the screws + you get at good grip on them with a wrench.
  16. squirrel
    I thought they were #4 Phillips?
    what year car is it?
  17. S10_37
    S10_37
    I will try heat spray lube and #4 impact bit this weekend. 64 bel air wagon
  18. squirrel
    If you've been using a #3 bit, that is not helping.
    I don't recall ever having any trouble getting them out using the correct size bit on the end of a ratchet.
  19. vtx1800
    vtx1800
    You need to come to the Midwest (I've lived in New Mexico so I understand why you wouldn't want to come this way), I had to heat the hinge screws multiple times to get them loose on the Studebaker pictured that came out of Minnesota as well as to get some hinge screws out of a 56 Chevy door, you don't know how lucky you are to live in a dry environment when it comes to working on old cars.
  20. squirrel
    yeah, I do...why do you think I live here? :)
    I'm not surprised you've had trouble getting bolts out of rusty cars.
    Hopefully we gave the OP enough ideas that he can get it done
    Atwater Mike likes this.
