Technical Is this ok to use for fuel line?
Discussion in 'The Hokey Ass Message Board' started by DOCWHIT, Jan 12, 2018.
  1. DOCWHIT
    DOCWHIT
    Just making sure this is safe to use as fuel line??
    Thanks!!!
  2. It should be fine. It's common. They have been making steel gas tanks for a long time, too. But that's not to say there haven't been occasional problems. There are probably better choices for a little more money.
  3. oldolds
    oldolds
    That should be fine. I would jump up to 3/8 line. Most factory built cars that had engines less than 330 cubes used 5/16, over 330 cubes they used 3/8 line. Not knowing what you are building I would spend the couple extra dollars and get the bigger line.
    loudbang, DOCWHIT and Elcohaulic like this.
  4. RICK R 44
    RICK R 44
    I would use the copper-nickel alloy line. It is more expensive, but much easier to bend and shape
    Texas57, Chavezk21, DOCWHIT and 2 others like this.
  5. HOTRODPRIMER
    HOTRODPRIMER
    I use 3/8" line from NAPA. HRP
    DOCWHIT likes this.
  6. DOCWHIT
    DOCWHIT
    Sorry HAMB family I got in a hurry posting this, so I should have included what engine & setup I'm using. It's on my 48 Plymouth 218 Flathead & 2 single barrel carbs. Going to fuel pump to 2 port fuel block to the carbs. I have wire hangers as models that I thankfully learned from some of you. So hoping that this 5/16" is good. thought of using copper. & using br*** connectors w/ flare connectors. Thanks for all your input!! Mike newest48engine.jpg
    scrap metal 48 likes this.
  7. BamaMav
    BamaMav
    from Berry, AL
    I think it will be fine. The factory line coming out of my 47 Lincoln is only 1/4", and it fed the factory 305 V 12 as well as the Chevy 350 V8 that was in it later just fine.
    DOCWHIT likes this.
  8. DOCWHIT
    DOCWHIT
    Another question that I didn't think about until the Wife asked... "How are you going to get that that coil of steel tubing straight from the fuel block to the carbs?"
    ****, so i didn't think of that.... Suggestions??? besides go buy straight 5/16" tube... LOL
    Thanks!!
  9. Mr48chev
    verno30 and Hotrodmyk like this.
  10. loudbang
    Drill a hole a bit oversized in a 2 x 4 put it in a vice a bit of grease in the hole. Insert one end of the roll and grab the end as it sticks out of the wood block and pull it through the block of wood. Nice and straight. :)
  11. egads
    egads
    You're going to put some kind of flexible hose between the moving engine and firewall ?
    Texas57 and loudbang like this.
  12. Joe H
    Joe H
    If not a flexible hose, add two or three loops in the tubing, you need something that will take up engine movement. Direct to firewall will fail at some point!
    DOCWHIT, egads and loudbang like this.
  13. 302GMC
    302GMC
    from Idaho
    If you plan to run the stock fuel pump, you're facing some vapor lock & fuel boil problems. Might want to run a blockoff plate and go electric ...
  14. crminal
    crminal
    One more vote for Nicopp. Easy to bend, straighten. Polishes nicely and will have a nice copper hue.
    Chavezk21 and lothiandon1940 like this.
  15. southcross2631
    southcross2631
    Aluminum line flares easily and is easy to form. Just make sure it is supported in Adel clamps on long runs. From the fuel block to the carbs you need something that will flex. I like the Summit twist ***e hose and fittings.
    DOCWHIT and AHotRod like this.
  16. Rusty O'Toole
    Rusty O'Toole
    How to straighten a coil of fuel line the easy way -
    Hand straighten a foot or so. Lay it on the garage floor, step on it with one foot and unroll the rest of the line while pressing it against the floor. In other words roll the coil along as if you were rolling a tire, unwinding it as you go. If you are careful it will be surprisingly straight, and this method costs nothing and takes almost no time.
    Later... I see this is for the firewall to carbs, DO NOT use a hard line here, use neoprene (rubber). More later.
    DOCWHIT and loudbang like this.
  17. Rusty O'Toole
    Rusty O'Toole
    O wait you don't use hard line from a firewall fuel block to carbs, you use rubber or rather neoprene. If you want to go real traditional you would use clear plastic, or tinted red or blue (definitely not recommended)
    Go ahead and use neoprene, but be warned these fuel blocks have been illegal in drag racing since 1957. A couple of cars with blown flywheels, chopped the fuel lines resulting in bad fires. Not a big concern in your case.
    DOCWHIT, 302GMC and loudbang like this.
  18. Joe H
    Joe H
    It was a NHRA rule that you could not mount any fuel line to the firewall, it still maybe. If the body was to come off the frame, it would pull the fuel lines with it.
    loudbang and Bandit Billy like this.
  19. scrap metal 48
    scrap metal 48
    Motor looks great...
    DOCWHIT, loudbang and lothiandon1940 like this.
  20. Bandit Billy
    Bandit Billy
    I totally get that would be a bad scenario but I think if my car body came off during a race the last thing I would be concerned about is a gas leak on the frame that just left me head over teakettle at the 60 foot traps. :cool:
  21. alanp561
    alanp561
    Wouldn't use copper. Vibration will work harden and crack it.
    XXL__, Texas57, DOCWHIT and 2 others like this.
  22. DOCWHIT
    DOCWHIT
    Hadn't plan to because I was trying to go traditional & looks so much better. BUT since everyone is suggesting not to it looks as if I am running neoprene hose. Luckily I can return the steel hose, but stuck with the clear red hose.
    Thanks for all your input HAMB family!! Mike
  23. Poh
    Poh
    from Quincy,Ca.
    You can run the hardline , but you need a small piece of flexible line at the firewall . That is all they are saying [​IMG]
  24. Texas Webb
    Texas Webb
    Nice air cleaners.
    loudbang and Poh like this.
  25. Poh
    Poh
    from Quincy,Ca.
  26. Bandit Billy
    Bandit Billy
    I always use a piece of flex from the firewall to the carb. On my flatty I mounted the fuel filter on the firewall, I mounted the fuel block on top of the blower, ran hard lines to the 97's and flex line between the filter and fuel block.
    On that intermediate flex line I bought this barbed male fitting for a 3/8 hose...
    upload_2018-1-19_9-40-15.png ...to be mounted on the fuel line at the firewall filter, a female receiver mounts to the filter outlet and is 3/8 NPT, both are valved. It allows for a quick disconnect and a valve inside each fitting shuts off fuel flow upon disconnect in both directions This will make for fast removal and service of my carbs/blower/motor. Cost is not cheap at $20 bones for each side of the coupler, so a $40 bill. Not for everyone's budget and style, but it is mine.
    Fittings handle up to 250 PSI, the Nitrile o rings Have an excellent compatibility rating with all vehicle fuels. Temp range from -40 to 180 Fahrenheit.
  27. carbking
    carbking
    At one time or another, in alphabetic order: aluminum, br***, copper, steel, and flex rubber have all been used as original equipment.
    In 55 years of working on fuel systems, I have only seen a few failures: 1 steel, the rest either neopreme or the (*&^%$# plastic.
    Beginning in the 1930's (maybe earlier) on O.E. applications, it was customary to use a short flex hose (for engine vibration) from the frame to the engine (generally the fuel pump). Before that, solid line was used with a vibration loop. These worked well for years.
    One comment about the size of the line: if you run a return line, size is less important, but if you don't run a return line, bigger is definitely not better, as the fuel will be in the line longer (higher volume) and be hotter when it reaches the carburetor, even to the point of contributing to vapor lock. The factory engineers knew what they were doing when they sized the line.
    Jon.
    loudbang, egads and DOCWHIT like this.
  28. ....and make sure you sweep the floor before doing this. Any bit of **** will get squished into the surface (annealed copper is soft), or worse, leave a dent. I have straightened miles of refrigeration tube this way. If you have to do a long length, get a buddy to stand on the already straightened end as you walk and unroll.
  29. Rusty O'Toole
    Rusty O'Toole
    If you are concerned about scratching the line unroll it on a soft pine board.
  30. FritzJr
    FritzJr
    If you want the tubing to be really straight. Attach on end to the back wall of the garage. Attach a come-along to the front wall and to the free end of the tubing. Stretch the tubing with the come-along. It will become very straight.
