Technical Metal forming classes
Discussion in 'Traditional Hot Rods' started by scott34, Jan 8, 2018.
  1. oj
    oj
    The best thing you can learn in a cl*** is how to get out of a ****up. If you watch a video and do exactly as they say on an exact piece with the exact same equipment then you'll get exactly the same result as they show. I'll bet that happens in about 1 in a hundred. What you need to learn is how to fix a nasty set of tucks that you just made, the guy in a cl*** will be able to turn your ****up into a learning experience for everybody.
    That is the priceless part that you can come away with.
  2. gimpyshotrods
    gimpyshotrods
    Exactly. Who does something new, exactly right, on the first try.
    I have been pushing metal back and forth through an English wheel for over 20-years, and I still ruin stuff, but a little less often, with every project (I swear).
    chryslerfan55 and oj like this.
  3. scott34
    scott34
    Where are you located
    Cheers Scott
  4. gimpyshotrods
    gimpyshotrods
  5. scott34
    scott34
    I here and see Wray come up numerous times
    But I need more to go on than a name
    Anything else you can tell me like last name location etc
    Thanks
  6. gimpyshotrods
    gimpyshotrods
    http://www.proshaper.com/
  7. cornfieldcustoms
    cornfieldcustoms
    we offer cl***es at my shop in Cincinnati, and cl***es at kyle yo***s shop in Sunbury NC
    chryslerfan55 and ls1yj like this.
  8. scott34
    scott34
  9. 48stude
    48stude
    When you're shaping metal , you will run into a train wreck occasionally . The more experienced you become, you know the train wreck is coming and you can do things to lessen the damage. When you know how to fix the train wreck , you can consider yourself a metal shaper. Twenty five years ago , I threw away a lot of train wrecks because I didn't know how to fix them. For the last few years I haven't shaped very much sheet metal cause I've been building hot rods. I suspect that I'm heading for a train wreck again. :p Bill
  10. luckythirteenagogo
    luckythirteenagogo
    from Selma, NC
    Baileigh is supposed to have a really good cl***. The cl***es either filled up on me or I didn't have the time to make it.
    Sent from my SM-G920V using The H.A.M.B. mobile app
  11. That would depend on who's there teaching it and I suppose it's more of a sales event,
    just saying.
  12. justabeater37
    justabeater37
    Yes, there is a certain sales to it, but I went to one with Kyle Yo***, Mike Wagner, Joe Mielke, and a few others I can't recall off the top of my head. We shaped on everything from a stump to the latest tools that weren't even available to the public yet. very hands on and was as basic or advanced as you wanted to be.
  13. luckythirteenagogo
    luckythirteenagogo
    from Selma, NC
    That was the one thing holding me back from really making it happen. I'm sure I'd learn a lot there, but how much of what I learned would I be able to do without a garage full of their equipment?
  14. gimpyshotrods
    gimpyshotrods
    I spent the first 10-years of my metal forming career with a Martin hammer and dolly set, and a chunk of cleaned up railroad track.
    I used this:
    (Yes, that close-quarters double-brake was made with a hammer, on the railroad track.)
    To make this:
    It is the whole section, from the soot on the B-pillar, down. The weld-in was tricky.
    You don't need a garage full of tools. They might make your work faster but they might not make it better.
  15. AULIZ
    AULIZ
    Need to buy first good quality machines (english wheel, beadroller machine, shrinker stretcher....) and hand tools. Test and learn. After course, You need to have all ready to use, if You want to keep "touch" and use skills You have learned....
    I have never been in metal forming cource, but would be good to be there one week.
    Need to remember; metal forming is not "rocket science".
  16. jvo
    jvo
    Nope. I personally wouldn't spend 20 grand on one,(most folks won't buck up and spend several hundred bucks on a made in america beverly shear, let alone a power hammer) cause it takes up too much space for a small shop, and it makes your ears bleed, and would really piss my neighbours off for about a 3 block radius.
    I have tried several of them at various metal meets and cl***es. All I was getting at was they are very spendy for the average person. Perhaps if you had a commercial operation it would make sense.
    I've taken Wray Schelin's cl*** twice and plan on going back one day for the week long coach building cl***.
    I've taken Peter Tommasini's 5 day cl*** several years ago, and it also is an excellent one. He teaches mostly e-wheel and hand tools also.
    I have rubbed shoulders with Lazze at the Santa Cruz Metal meet several years back and have also done a shop tour there. He is a wonderful guy, and I imagine a great teacher as well, but his tools are very expensive also, even though I have a thousand bucks worth of his bead roller dies for my homemade bead roller. I couldn't justify the price of his e wheel or bead roller.
    Ron Covell was also at the Santa Cruz meet when I was there, and he is also a wonderful person and teacher, although his cl***es I understand are not hands on.
    Some of the best money I have spent is on David Gardiner's DVD. Its a little dry to listen to, but it has a wealth of information in it for a decent price.
    I used to spend a lot of time on the metal meet site, but I now spend my time in the garage building my projects, which is why I got into the metal shaping end of rod building in the first place. Best way to learn, as others have stated is to just start doing some stuff. All the cl***es in the world won't help if you don't just step up to the plate and start swinging the bat, or hammer if you will. Good luck.
  17. My entire point was trying it first and then making a decision.
    That's just what you did .
  18. luckythirteenagogo
    luckythirteenagogo
    from Selma, NC
    Amen to That!
  19. Jimbo17
    Jimbo17
    I remember watching a show a few years back on Jessie James when he also went some where in M***. to learn metal shaping and I was wondering it this is the same guy? The shop I remember was much smaller but had loads of metal shaping tools in it.
    Jimbo
    chryslerfan55 and ilinrods41 like this.
  20. gimpyshotrods
    gimpyshotrods
    Email him and ask.
  21. Jimbo17
    Jimbo17
    Thanks your a real rocket scientist!!! Jimbo
  22. jimdillon
    jimdillon
    Jimbo I remember when Jesse James went to Fay Butler's place years ago. Fay did quite a bit of work with Pierce Arrows (and some other cl***ics). Super talent for sure.
  23. gimpyshotrods
    gimpyshotrods
    He has been a member of this board, and he has given out his email address here, too.
  24. WC Durant
    WC Durant
    I took Jeff Fournier's 3 day metal shaping cl*** in Mt. Clemens, MI. His focus was hand tools coupled with the English wheel. It was a great experience, I learned a lot, and it really gave me a good knowledge base for when I returned to my home shop. I ended up buying a modestly priced English wheel and have been able to make the necessary panels for my hot rod project.
  25. toreadorxlt
    toreadorxlt
    from Nashua, NH
    That guy is Fay Butler, not Wray Schelin. They are 30 miles apart, but worlds apart in methods. My summary in my previous post will help you understand more
  26. Happydaze
    Happydaze
    I did a 2 days Ron Covell course in the UK a few years back. Steel day 1, Aluminium day 2. It wasn't hands on at all. I'll admit to initially having my reservations about that but they were soon dispelled. It was pretty basic in as much as it was all basic hand tools plus a welder, but the tips and tricks just kept coming and I learned a lot, probably a lot more than being in a hands on cl***. Probably better than just Youtube and you could freely ask questions as it went along. I found just hearing the real sounds was of value to me. Probably not advanced enough if you've got reasonable experience? I'll soak up education any way I can though, so it's all good and tends to compliment each other.
    Chris
  27. Jesse at Steve Davis's shop
    MIKE STEWART and chryslerfan55 like this.
  28. gonzo
    gonzo
    Have truer words ever been spoken?
    chryslerfan55 and deathrowdave like this.
  29. Jimbo17
    Jimbo17
    Thanks for your reply. For the life of me I could not remember the name of the guy.
    Jimbo
  30. oj
    oj
    You might have better luck attending a 'metal shaping' event. At one of them you'll find all different types of techniques and lots of machines to try out. A metalshaping cl*** is a semistructured thing where the instructer is cast into the role of teaching. At a metalshaping event you'll find many different skill levels where a novice can pick and chose what he needs to learn, there'll be groups of a few people working on all different stuff and you can move in and out of those groups like one guy might be wire-edging a fender and another making a buck while others are tuckshrinking on a stump. There'd be lots of different equipment you can experement with and watch how others do things. After a few years where you've found your own preferances then consider a proper cl***, they are expensive but if you prefer to wheel you'd want a cl*** by Tomosinni or Kent (Master Wheelers) rather than a cl*** by Fay Butler about using a Yoder.
