Hot Rods PAINT EXPERTS I HAVE A ?????
Discussion in 'The Hokey Ass Message Board' started by Todd's Rod's, Jan 12, 2018.
  1. Todd's Rod's
    Todd's Rod's
    from MInnesota
    What color paints do you use to paint traditional flames? Please be specific on the color and a picture would be greatly appreciated. I plan on adding flames to a project I want them to stand out but still remain the traditional look. Thank you.
  2. zzford
    zzford
    I always went from yellow to orange to red, from the front of the flames to the back. Paint the yellow first, then add the orange, ending in red. Then a blue pinstripe to finish them off.
    Fordor Ron likes this.
  3. squirrel
    In the 70s, on TV, this was traditional flames....
    blackout78666, Hank37 and catdad49 like this.
  4. K13
    K13
    The flames on that car have nothing to do with TV. Manuel flamed it before it was considered for the movie or given the name the California Kid and it was based on a number of historic cars.
    https://www.peteandjakes.com/flame-history/
  5. clean cut creations
    clean cut creations
  6. squirrel
    I know. But seeing it on TV over 40 years ago was my introduction to the glorious world of traditional hot rods.
    0NE BAD 51 MERC likes this.
  7. K13
    K13
    Got it. Your comment just made it sound like it was TV's interpretation of a traditional flame job.
  8. buffaloracer
    buffaloracer
    from kansas
    Tom Mc's roadster got me started on flames.
    pitman likes this.
  9. RICH B
    RICH B
    Gene's '40 has always been my idea of decent old time flame colors.
    catdad49 likes this.
  10. You can't go wrong with this advice. I've also seen it start with white and fade into yellow/orange/red/etc. It's hard to mess up and easy to visualize and explain to painters or helpers. I suggest you Google search "flame paint job images" to review dozens of styles and examples. There's a lot of wild stuff way out on the fringe but you will be able to identify many in the traditional, core style. Just separate the sheep from the goats and you'll have your answer. "Pictures are worth a thousand words."
    blackout78666 likes this.
  11. oldolds
    oldolds
    Do you want specific color manes and paint manufacture? That will be hard to define.
    I think all "graphic" colors are dependent on the color they are being applied over. I.E. I don't think you would put the same red, yellow, orange color combination of flames on a blue car that you would put on a green car or a black car. You might still go with the traditional red yellow, orange, but it will be different shades of those colors.
    Every car I ever had pinstriped the paint was never straight out of the can. They always mix something in it. I may have told the artist what colors I wanted, but it is just a guide. I let them do as they see fit, as long as it is about what I want.
  12. White
    Yellow
    Red
    I like a little white, you may not.
    Blending the colors gives you orange.
    Blue pinstripe sets it off especially on a black car.
    It's the layout of the flame licks that change eras
    blackout78666, henryj1951 and brad2v like this.
  13. catdad49
    catdad49
    The first car that came to mind was Bob McCoy's sedan. Pretty basic and if I remember correctly, they were blended using rubbing compound. The two examples presented above are also nicely done. Yes, the McMullen roadster would also be worth a look. Specific colors will be harder to pin down, good luck to you.
    henryj1951 likes this.
  14. indyjps
    indyjps
    Never laid flames, you asked for experts, but...do you have a mixing bank. Lots of fade, requires lots of color variation.
    If you dont mix your own, get a red, yellow, orange in your favorite paint and mix some mids in between.
    Lets see what you come up with.
    henryj1951 and Todd's Rod's like this.
  15. deathrowdave
    deathrowdave
    from NKy
    These are done in my driveway , gold base candy yellow , candy orange , candy red , green outline . May not be the best layout , but I did it , no funds for pro to do it , babies needed shoes .
  16. Todd's Rod's
    Todd's Rod's
    from MInnesota
    Thanks looks great thanks again for the information and color variations
  17. flamedabone
    flamedabone
    I like to sneak a tiny bit of white in at the leading edge.
    But, I don't like any of my flame jobs, so don't listen to me.
    -Abone.
  18. You said "traditional". To me that suggests non-metallic, opaque solids.
    I do like what Deathrowdave did a lot, though. It has the cl***ic influence and style but with more modern metallics. Very tasty...... and cl***y. You can always do something that is true to tradition but with your own twist added. In fact, you really should.
  19. henryj1951
    henryj1951
    from USA
    RIGHT on(as usual)
  20. henryj1951
    henryj1951
    from USA
  21. henryj1951
    henryj1951
    from USA
    like i said 28 years ago glow 1990.JPG Glowin the dark 1990.JPG ....
  22. 0NE BAD 51 MERC
    0NE BAD 51 MERC
    Flames can be any color and style, but to be traditional in the sense of what is acceptable here I stick with shades of white, yellow, orange and red with blue or white stripe's. candies in those tones would also be acceptable. But a pink 32 with lavender flames not so much. The main color of your car will really dictate your choices. If I am building something that I see as traditional it will usually be black and start with either Gm appliance white or Plymouth Prowler yellow { the cleaness yellow I have ever found} hugger orange and Ford red . good luck Larry
  23. Lou kriger
    Lou kriger
    [​IMG][​IMG]We went with the yellow-orange-red route. But some of the best flames I’ve seen come from some wild imaginations. I don’t know what they were Smokin.
  24. Lou kriger
    Lou kriger
    The style on the “California Kid” is killer. Having a Black base really makes it happen. Just my humble Op.
  25. bigdog
    bigdog
    Always did yellow, orange, red
  26. BamaMav
    BamaMav
    from Berry, AL
    On some colors, a little blue on the tips looks good, too. Not on every tip, just on about maybe half of them. Wouldn't work on a blue car, but on a black or white or red, it makes the flames stand out a bit.
  27. You're basically doing a "fade" of one color into the next. If you're handy with a spray gun and can shoot down at an angle or have an air gun, you should be singing in the kitchen. It doesn't have to be 3 or 4 steps: you could blend the colors and do 6 or 8 steps.
    Todd's Rod's and henryj1951 like this.
  28. philly the greek
    philly the greek
    from so . cal.
    Full color-3.jpg Here's a photo sequence that might help . When I did these I first painted a white base as the color yellow is quite transparent and it helps with color coverage . Next I start the fade process from light colors to darker , starting with the orange which I blended into the yellow followed by the red color . IMO it helps to use the slowest reducer possible for the temperature when doing the fades as it helps to blend from getting to much like stucco . Follow this with the clearcoat of your choice , color sand , rubout , pinstripe the edges and your done . Good luck with your project . IMG_2799.JPG IMG_2800.JPG IMG_2801.JPG IMG_2802.JPG IMG_2803.JPG IMG_2804.JPG
  29. Todd's Rod's
    Todd's Rod's
    from MInnesota
    Thanks that really helps great looking car
  30. B1gDaddy
    B1gDaddy
    from aladambama
    That's what legends are made of right there!
    henryj1951 and deathrowdave like this.
