Projects Project 29 Phaeton
Discussion in 'The Hokey Ass Message Board' started by 340HilbornDuster, Jan 29, 2013.
  1. 340HilbornDuster
    340HilbornDuster
    Don't know Y it disappeared.....(maybe when the site crashed..?)
    It's a little busy for some maybe -
    Going for that forced perspective "Old Bentley" / Train blowing over the hill / "Grundy" look...
    6f1abd56ddd56019253bbc60121f92a6--car-posters-event-posters.jpg d77236beb1f9de0695547fa9077c55f5--hot-rods-cartoon-characters.jpg
    Got Plenty hills over here....................
    Tim_with_a_T, biggeorge and AndersF like this.
  2. 340HilbornDuster
    340HilbornDuster
  3. 340HilbornDuster
    340HilbornDuster
    Bolt On Hand Brake Bracket for a ......yeah i know , took forever.....
    Sometimes "just get started"...........&......use what i got allready + a pinch of City Mill!!.........till the End! 20171207_183420 (Medium).jpg
    Front Cable Bracket bolted to Trans Mount.
    metal man, biggeorge and AndersF like this.
  4. 340HilbornDuster
    340HilbornDuster
    Alternator bracket + turn buckle-tension bracket
    I'll paint the Chrome Bracket!
  5. 340HilbornDuster
    340HilbornDuster
    Mix and match base bracket is one of those cheap o Car Store type.
    Bent the **** out of it....
    I preloaded it first....Realised I needed a support bracket. flat iron look like ****,Beated a piece of round steel and drilled....better.
    Sent from my SM-G930T using The H.A.M.B. mobile app
    chriseakin, tomkelly88 and AndersF like this.
  6. Tim_with_a_T
    Tim_with_a_T
    First time seeing this. Made it all the way through in two sittings. Nice work man. Be proud.
  7. 340HilbornDuster
    340HilbornDuster
  8. 340HilbornDuster
    340HilbornDuster
    AndersF and biggeorge like this.
  9. 340HilbornDuster
    340HilbornDuster
  10. 340HilbornDuster
    340HilbornDuster
    I was trying to make the weld look good from the back, screwing uqqp the front with burn through (bird poops)
    Cool thing - Y'allways learn what Not to do.
    patmanta, biggeorge and AndersF like this.
  11. 340HilbornDuster
    340HilbornDuster
    Drip rail. Cooper nickel Brake line bent and cut in half.tscked with the TIG. Sealed with 5-minute epoxy.
    AndersF likes this.
  12. 340HilbornDuster
    340HilbornDuster
  13. 340HilbornDuster
    340HilbornDuster
    Remember this one ... I Always regretted cutting it up...so slick looking!
    ---------------From Page 1 in this build---------------
    The 39 front suspension with the spring in front?
    If i can find a dropped 39 axle, I might just go with it...
    Cause it's different, it's Old school (Wally Parks did) and it's COOL!
    Someone said "it's like painting a mustach on Mona Lisa, Don't do it!"....AWESOME!
    Not as nice...but... It'll clean up good!
    I kept the Lower Spring from the first one...
    I'm whole again...Thanks Buddy!!
    upload_2018-1-3_20-3-15.png Yup!
    AndersF likes this.
  14. 340HilbornDuster
    340HilbornDuster
    What?....No - I'm not putting it on the Tub!....Next Project....
    AndersF likes this.
  15. 340HilbornDuster
    340HilbornDuster
  16. 340HilbornDuster
    340HilbornDuster
    Dannerr and patmanta like this.
  17. 340HilbornDuster
    340HilbornDuster
    biggeorge, Dannerr, patmanta and 2 others like this.
  18. 340HilbornDuster
    340HilbornDuster
  19. 340HilbornDuster
    340HilbornDuster
  20. 340HilbornDuster
    340HilbornDuster
  21. 340HilbornDuster
    340HilbornDuster
    Stogy, Dannerr, AndersF and 1 other person like this.
  22. 340HilbornDuster
    340HilbornDuster
    Stogy, Dannerr and AndersF like this.
  23. 340HilbornDuster
    340HilbornDuster
  24. 340HilbornDuster
    340HilbornDuster
    20180127_162725 (Medium).jpg Finish welded the hoop stuff.
    20180127_163602 (Medium).jpg 20180127_172927 (Medium).jpg Tank "lock" rubber bumper combined.
    20180127_181544 (Medium).jpg 20180127_181506 (Medium).jpg 20180127_183812 (Medium).jpg Bottom leather belt tensioner.
  25. 340HilbornDuster
    340HilbornDuster
    [​IMG] I was grinding it clean , by the time I got to the other side it started rusting on the first side again.
    (kind of humid over here...)
    Sprayed it with stuff called "must for rust" and wiped it off , then primer.
  26. 340HilbornDuster
    340HilbornDuster
  27. 340HilbornDuster
    340HilbornDuster
    Cleecos out - holes drilled everything - bolted together.
    Bubble' s hitting.
    take all the bolts out again
    Crude! But never fails.
    Now back to...[​IMG][​IMG][​IMG]
    AndersF and Stogy like this.
  28. 340HilbornDuster
    340HilbornDuster
    Roll-bar / tank / seatbelt bracket bolted down..decided to trim & keep the Aluminum (protect the frame when welding).
    More Backwards work - got rid of that gas tank thingy...good idea at the time...maybe?
    New plate w. 1/2" and 3/8" NPT in the bottom.
    Chased holes in the tank w. Soap n' water...2 hours later ... DUN!
    Closer.
  29. 340HilbornDuster
    340HilbornDuster
    Bottom left top right.
    S'more pukas!
    Slosh the rest of the inside of the tank with the must for rust not a single leak![​IMG]
    Sent from my SM-G930V using The H.A.M.B. mobile app
    AndersF likes this.
  30. 340HilbornDuster
    340HilbornDuster
    AndersF likes this.
