Projects De ratting a model a
Discussion in 'The Hokey Ass Message Board' started by JOYFLEA, Oct 9, 2017.
  1. JOYFLEA
    JOYFLEA
    This is a 3” but will be adding 1”,2”,4”,5”,and 6” . Well when I hit the lottery. I have a full set of punch and dimple dies already and now I will not have to drill a hole first and squeeze with a bolt . Working smarter rather than harder in my old , sore age . Blue
  2. JOYFLEA
    JOYFLEA
    Finally got back to work on the Tudor yesterday . Had to do some plumbing and other honey do s . 80% of the wiring is done . Dash is mounted and I cut a huge hole in the old gas tank for room for glovebox . Man it is nice and deep with no heat or ac in the way .
    2AB20469-F92B-4743-8B15-3592B30DEAF4.jpeg BBE9D67B-E240-4B74-95A5-6B836CB29109.jpeg BBE9D67B-E240-4B74-95A5-6B836CB29109.jpeg C3D397BC-5BFA-46CC-B25D-EF2CA10AE178.jpeg
    The stock gas tank had been coated with tank sealer. Not a good job . The sealer that I show was just in the area I cut out !
    Changed the headlight stands while I’m wiring. I like these much better .
    F4B34811-3C76-4045-AFDF-3E082657A079.jpeg F0827385-AA19-4351-B90B-E374180A9E9F.jpeg C596B82C-D91E-4D6C-8256-F29531D6F6C1.jpeg
  3. JOYFLEA
    JOYFLEA
    Ok , now I’ve a question. Anyone know what this column came out of ? And does anyone have another one of these wheels , 16x4 , for sell ? Thinking of going to these wheels. I have 3 16s and one 17 .
    4C0D40D3-5481-454F-93C0-6471107CB5F1.jpeg 8B90C439-1DE6-4DB0-9E58-DAA38CC70896.jpeg 8D7D4D9F-F08F-4EA6-8571-50B3197DE34C.jpeg BA453DB8-E2DB-472D-B2BA-D62E7C04FA34.jpeg
    Also I will finish the wiring and fuel system this week and start beadrolling the interior the next . Got the design narrowed down to diamond panels with one of these designs in door panels. Bird or tiki?
    Thanks for the help in advance! Blue
    380EFCD6-94D7-4BA0-B7D8-685061C8F6E0.jpeg 4C45D7C8-C700-4A4C-BE88-953CB7331B65.jpeg A27249FC-D0CE-4391-9F51-858FC8910112.jpeg
  4. enloe
    enloe
    from east , tn.
    Like the Tiki
    Larryboy? and JOYFLEA like this.
  5. loudbang
  6. OFT
    OFT
    ^^^ I go for diamonds also
  7. JOYFLEA
    JOYFLEA
    All of it except the art section on front doors will be diamonds . But will have art in it like this . Not done by me . Vote for which art , thanks Blue .
    7B4E8AF8-95F4-4EB5-BEC6-42DAFADEBBA8.jpeg EC789585-D440-4ACA-969A-B95A58007421.jpeg B24775C1-DB1E-4AE0-B4E6-E14C39BDEF43.jpeg
  8. treb11
    treb11
    Steering box looks like Mustang so maybe the column is too.
    Sent from my SM-G950U using The H.A.M.B. mobile app
    chryslerfan55 and JOYFLEA like this.
  9. loudbang
    V-8 Looks GOOD
    chryslerfan55, tinsled and enloe like this.
  10. Dick Stevens
    Dick Stevens
    I like the V8 panels better than the Tiki or the Bird!
  11. JOYFLEA
    JOYFLEA
    Yes I two love the v8 but I don’t like to copy others work exceptional my friend Gaylons .
  12. rfraze
    rfraze
    X2 on Mustang column.
  13. woodbutcher
    woodbutcher
    :D Hi Blue.Looking good.Just remember"Diamonds are a girls best friend":rolleyes::p.
    Good luck.Have fun.Be safe.
    Leo
  14. Dick Stevens
    Dick Stevens
    Maybe do them without the flames and have the V8 inset in an area in the middle of the diamonds?
  15. JOYFLEA
    JOYFLEA
    Been working on the A a bunch , just not much interesting to show . All but 3 wires to finish in the car . Ordered some different headlights , will mount and wire and be done with the wiring . Going to change the steering wheel without the 2” adapter. Gauge panel looks good , I think .
    95131164-3C0D-4386-B510-633E39F9918D.jpeg 7B0AB4AD-B0AA-40F2-8C7C-2D53D95E5469.jpeg
  16. raven
    raven
    I've got two 16" wires to compliment your three.
    r
  17. 28TudorAZ
    28TudorAZ
    Dash looks really good. I am jealous of having a glove box. Where is your stereo? ;)
    chryslerfan55, loudbang and JOYFLEA like this.
  18. JOYFLEA
    JOYFLEA
    3BD43A24-D425-463F-B8DF-988FBEA0FBFC.jpeg 954B4C30-B4CF-46BC-8C84-B9563C055870.jpeg Does anyone know if they make an adapter to use 16x4 wires on my front disk setup . Or will they even work .????? Blue
    chryslerfan55 and enloe like this.
  19. pat59
    pat59
    I've got 16x4 wires on mine with Pete and Jakes disc brakes set up. Clear fine.
    Stogy, loudbang and JOYFLEA like this.
  20. JOYFLEA
    JOYFLEA
    Cold this morn so I got a late start . Worked on cutting down a stock taillight bracket for a mount for my 3rd brake light Thursday and painted it yesterday . Mounted it today . I live on a rough road and didn’t want it vibrating to much so made a LP mount/ brace . Just an excuse to use my punch press . Will go back to work after dinner and mount my new steering wheel . Latter, Blue
    29721E94-A4EF-478A-9262-CBDF9B9906A8.jpeg 6344E09C-697F-4992-90B6-E42D50EF81D3.jpeg D288C81E-4429-4026-B86D-06A6F2DA268F.jpeg 70C0035C-2508-4C6C-8495-A97C018FDDF9.jpeg 0F54E972-4396-423B-9D0E-C8DA6644C2BF.jpeg 8A5CEC23-8592-4C7C-8C51-76FE157DC79C.jpeg 2B3A519B-1A19-454F-B162-9A5DE2E07FAC.jpeg E8BA09FB-37CF-40B4-B887-A8AB0A4EE2F7.jpeg 7B37C76F-7F12-4CF4-AD50-7DE57C58428A.jpeg E6CAF92B-6FB3-47DE-81B1-68DAB2E41F97.jpeg
  21. JOYFLEA
    JOYFLEA
    My feet have been hurting with this plantar fasciitis and haven’t done much . Did get the new headlights and mounts on . They lean in and need some tweaking.
    CD190255-16CD-46C0-9D58-E0E1935B38A8.jpeg 4E263C15-DFBF-4C43-8BAE-7393FE72DA63.jpeg
    Need to bend the stands or may look at the attachment place ?
    Also mounted the gas tank for the last time . Uaisg the original inlet hose ,with a plug , for a vent to tie into filler spout . Using exaust pipe , grease cap and fitting . Should work fine . Hard to see in picture but short piece of hose is for vent and one with tape is for filler. Blue
    993DE2C4-EFD0-4C04-96D4-145D38CB9430.jpeg 36458C66-B4BF-4ACE-8DFF-C6BF985F7363.jpeg A20D84B7-A2A4-407F-857D-745BA83B00AA.jpeg 2236D534-5BBD-472C-9BF6-AC175003E21D.jpeg
  22. JOYFLEA
    JOYFLEA
    New steering wheel in . I likeyyyyy.
    CF95BD14-118F-46DB-979D-FDFE34FF3413.jpeg D7125EF6-6031-42B7-9905-E824EF1309D6.jpeg
  23. Hombre
    Hombre
  24. Dick Stevens
    Dick Stevens
  25. enloe
    enloe
    from east , tn.
  26. 28Hud
    28Hud
    "I've factory suicide doors on my Hudson, with original piano hinges, and Bearclaw latches. Never had any issues, and I sometimes drive fast on our shirty roads, with it Rattling like crazy."
    I just picked up my 28 Hudson a few months ago and drove her 13 hours home. The suicide doors never gave me a moments worry, although the drivers side window unwound a few times and scared the **** out of me! Those doors are strong!
  27. JOYFLEA
    JOYFLEA
    Been out of town ,taking care of my wife and my feet . Got home late yesterday and saw it was going to be warm for 2-4 days . Decided I needed to do some painting .
    When I was at SEMA this year I saw a new product being handled by hush mat for heat , headers paint . I bought a can and thought I would try it . I had my old headers baked at my radiator shop over night and it cleaned all the oil and such off . This morn I got up and sandblasted them as per instructions. Layer the paint on and it looked great . When wet it looked just like my 69 Dodge Cornonet RT , metallic bronze . Loved that car . Got it in September of 68 after being discharged from active duty , USMC . Took all the money I had earned in VN and bought it 426 radio and heater delete , twin hood scoops two fours......... I’m getting off subject .
    Pipes look great and will give a report on how they hold up .
    Blue
    C8FA703B-B270-454B-AC99-A7FB1C96DA7E.jpeg 6C82277E-0E5C-41AC-AF60-5FFE67BA3FBA.jpeg 4AFC084E-8690-4AF5-AB0A-7DC2D9684204.jpeg 8A309A67-A506-4462-96E2-53ACB7CA4F11.jpeg AFDCA3D0-2116-40E9-8D91-F5D74F392DF3.jpeg
    Can’t tell color very good in photos ,copperish bronze with a slight metallic.
  28. brEad
    brEad
    Header paint looks great, hope it holds up. What gas tank are you using? Looks like a truck tank maybe? Anyway, enjoying your build & I hope your feet feel better.
  29. JOYFLEA
    JOYFLEA
    48-52 Ford pu . Got it from Speedway .
    I too hope the paint holds up , kind of expensive. About half the price of ceramic.
    Feet= old age , hard floors for68 years .
  30. brEad
    brEad
    Thanks for the answer regarding the tank. Thought that might be it as it is what I have been wanting to use. Did it fit width-wise without modification?
