Projects 26 T Roadster Pick Up build Thread
Discussion in 'The Hokey Ass Message Board' started by Blue One, Mar 27, 2010.
  1. Tim_with_a_T
    Tim_with_a_T
    Yeah, BUT... what kinda grip you rockin'? Mob? Jessup? Grizzly? If you're running Mob you might be shredding the treads of your nice, new tires... Sorry, I can't help myself. I doubt anyone else will understand on this forum.
    Your ch***is looks great by the way. I like the vented brakes a lot. Keep pluggin' away!
    brEad, Blue One and loudbang like this.
  2. 26 T Ford RPU
    26 T Ford RPU
    I got it.;) JW
  3. Blue One
    Blue One
    from Alberta
    :D You know Tim I don’t even know what it is :D I didn’t ask, I went to the skateboard shop and asked them for 4’ of grip tape and what I got looks like black. 80 - 100 grit or so sandpaper.
    (My son would probably know what it is)
    As for shredding the tires well I’m thinking that I’ll be okay there as all the grip tape helps with is keeping it on the stands when I pull on a wrench :D
    loudbang and Tim_with_a_T like this.
  4. Tim_with_a_T
    Tim_with_a_T
    Well that all sounds fine haha. For the record, Jessup is a cl***ic and been around forever. I prefer it. Grizzly is somewhat new and a bit of a buzz word in the current market - I can't really tell the difference between it and Jessup. Mob grip is the stuff that a homie at Zumiez will try to push on you. To me it just completely shreds your shoes and does no good whatsoever...way too grippy.... anyway, back to hot rods.... I never would have thought to grip your stands, but that's a great idea.
  5. Blue One
    Blue One
    from Alberta
    I’m thinking that it’s probably the old cl***ic stuff that’s been around as it looks the same as what my son used for years.
    The reason I thought about using it is because once I built the stands and painted them I realized that since I hadn’t wanted to add any side plates (allowing for possible wider tires)
    the tops ended up rather slippery .
    The curve cradles the tires it was sideways that was the concern.
    So after years of skateboard repair and maintenance the idea just came kind of naturally.
    Use grip tape :D
    In the interest of shop safety :D:cool:
    brad2v, loudbang and Tim_with_a_T like this.
  6. Tim
    Tim
    from KCMO
    On a related note @zibo has some on the floor of the roadster pickup to act as a heal stop. Kinda clever :)
    loudbang, Tim_with_a_T and Blue One like this.
  7. Doctorterry
    Doctorterry
  8. Blue One
    Blue One
    from Alberta
    If you’re referring to the wire mesh in the brake vents, it was supplied by MT Car Products with the vented backing plate option on the Lincoln brake kit I bought.
    They supplied the stainless mesh and it’s formed to fit the holes nicely.
    http://www.mtcarproducts.com/Brakes.html
    brEad, loudbang and Stogy like this.
  9. tfeverfred
    tfeverfred
    Yawn................ is nap time over?
    Blue One and 26 T Ford RPU like this.
  10. Blue One
    Blue One
    from Alberta
    :D Extreme cold weather and snow along with a busy schedule slow things down but I’m trying to get something going. :)
    t-rod, loudbang and 26 T Ford RPU like this.
  11. tfeverfred
    tfeverfred
    Figured that. I was just razzin' ya!:D
    26 T Ford RPU and Blue One like this.
  12. Blue One
    Blue One
    from Alberta
    Just to prove that things haven’t come to a full stop I ***embled and installed the start of the brake system.
    The pedal and master cylinder ***embly.
    Next will be a trip to the brake supply shop for nicopp tubing and other stuff :cool:
    A14D3392-CD96-492B-B37E-523AA4B31EF7.jpeg AACF0341-D195-4274-8BA8-F419C0C46BDF.jpeg 904E64FF-57D5-47DB-AB5F-015680DAD418.jpeg
  13. tfeverfred
    tfeverfred
    Thanks, man. Looks good!
  14. Blue One
    Blue One
    from Alberta
    A rather momentous thing happened today.
    I decided that since the transmission ends up so close to the brake master cylinder I would probably be better off having it in place before running brake lines.
    It will make it a little bit harder to install lines however everything will fit.
    So the momentous event was the ***embly of the engine and transmission and putting it into the frame. :cool:
    7C66E32C-B286-4337-8335-A1693B2B6AC9.jpeg 2D8D7393-C639-4EDB-A39E-A03FA35CE3F4.jpeg A86947EE-F5C1-49FC-AA1A-B6DFD4E1A8EB.jpeg
    eddie1, Tim_with_a_T, brEad and 14 others like this.
  15. bobbytnm
    bobbytnm
    Awesome!!!!
    That's really looking great!
    loudbang, 26 T Ford RPU and Blue One like this.
  16. tfeverfred
    tfeverfred
  17. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
  18. 57 Fargo
    57 Fargo
    That’s a huge step forward!!
    loudbang and Blue One like this.
  19. 26 T Ford RPU
    26 T Ford RPU
    Looking OH so good, Larry. That engine balancing gizmo it the Cats PJ's !! All way cool.:cool::D JW
    loudbang, Blue One and Stogy like this.
  20. Tim
    Tim
    from KCMO
    Very cool
  21. loudbang
    DAM FINE can't wait to see it all together.
  22. Six Ball
    Six Ball
    from Nevada
    What they ALL said!
  23. Blue One
    Blue One
    from Alberta
    Got home from work today and another piece of the puzzle jumped into place :D :cool:
    brEad, brad2v, Tim and 6 others like this.
  24. K13
    K13
    Getting lazy Larry leaving your driveshaft black.o_O:D
    brad2v, loudbang and Blue One like this.
  25. Blue One
    Blue One
    from Alberta
    Sorry :D
    I overlooked it but since a lot of my other parts have a coat of black powder coat I figured it would be okay.
    I did brush on a fresh coat of KBS rust paint and believe me that stuff is tough.
    Another benefit if you think about it will be the ease of repainting the driveshaft should it need to be removed in the future to replace a U joint. ;)
    The black looks good with the blue anyway :D
    My rad will be black as will the fan shroud.:D
    brad2v, loudbang and Stogy like this.
  26. Stogy
    Stogy
    Whats Black and Blue and Read All Over?
    @Blue One's Thread
    You might just bring on an early spring with your build...
    to heck with the ground hogs...
  27. GASSERBOB
    GASSERBOB
    from USA
    Beautiful,beautiful.....................
  28. Blue One
    Blue One
    from Alberta
    Today I called Gene at Flat O products and ordered up a high torque gear drive starter made specifically for my Y Block and C4 combo using the Flat O adapter which I have.
    It also has a solenoid so that will be helpful. :cool:
    loudbang, brEad and tfeverfred like this.
  29. brEad
    brEad
    Engine looks good in the frame! Nice seeing the progress.
    Blue One, loudbang and Doctorterry like this.
  30. loudbang
    You mean no more Y Block starter bendex noise how you going to know it's running LOL. :)
