Art & Inspiration Just Louvers////////
Discussion in 'The Hokey Ass Message Board' started by Stogy, Aug 1, 2016.
  1. Stogy
    Stogy
  2. Stogy
    Stogy
  3. Stogy
    Stogy
  4. Stogy
    Stogy
  5. Dean Lowe
    Dean Lowe
    Kind of defeats the purpose of the Moon disc doesn't it.
  6. Stogy
    Stogy
    Yes it would create resistance therefore causing drag equaling slow or make funny noises...:p. If running on the street with 'the look' of the day one would at least hope the direction of the louver would push on and not pull off therefore you would have to have two with opposite direction for the other side...if it was even a consideration.
    This is also a vintage show car and we all know that some louver everything...even today...
    Other than what Veterans of some the most celebrated and cherished period of Hotrod/Custom share in story the pics help in making it a full circle even if it generates a what were they thinking...
    Ron Funkhouser and loudbang like this.
  7. Stogy
    Stogy
    Awesome Vintage Hotrod
    (from across the pond)
    with inspiring video
  8. Stogy
    Stogy
  9. Stogy
    Stogy
    A Sleek Inspirer
    The 1939- A win at Indianapolis
    The first product of the Orsi-Maserati era was unveiled in March 1938. This was the 8CTF (8 Cylinder Fixed Head). Maserati saw its first American victory in 1939 with their 8CTF model, renaming it “The Boyle Special.” Maserati was the first Italian manufacturer to win the prestigious ***le, and they succeeded in repeating the feat the following year.
    http://www.maseratiusa.com/maserati/us/en/brand/a-history-of-innovation
  10. Jim Huseby
    Jim Huseby
    I don't know how to post pics, but to see some creative louvers, go to my web site olympicspeedsters.com then click on "Gallery", then "Fabrication" then "Louvering". Some of the speedsters and my daily driver CCPU, shown, also have my louvers.
    Stogy likes this.
  11. ct1932ford
    ct1932ford
    Here are some on a five window I once owned. My favorite louvers are these on the trunk lid that are more rounded than straight across. IMG_8209.JPG IMG_8245.JPG IMG_8238.JPG
  12. Stogy
    Stogy
  13. Stogy
    Stogy
    Even louvered backing plates. Nice Hotrod CT...Could you find a favorite 3/4 view of Ole Blackie (then your gonna tell color blind Stogy its Blue) to share...please...pretty please...;)
    Hey what's that thing on the frame in front of the headlight post...a signal?
    Ron Funkhouser likes this.
  14. ct1932ford
    ct1932ford
  15. Mike Rouse
    Mike Rouse
    image.jpeg image.jpeg Here are a few I did in my shop.
    1947knuck, chop job, 509garyd and 5 others like this.
  16. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    I would like to see how that was done (louvered backing plates)
  17. JOYFLEA
    JOYFLEA
    Just built myself a press for louvres and punches . Made a little LP brace for My Tudor. Just learning how to use it . Will play with it a bit more before tackling something complicated. Blue
    732547DF-7F4E-41AF-9BD7-6F10FE6C1646.jpeg 95A39F46-8D61-4419-A173-F2EEDB5BF161.jpeg F4221AAF-3797-4B7B-8F0D-691FF6F83C16.jpeg
  18. Mike Rouse
    Mike Rouse
  19. 61cad
    61cad
  20. Stogy
    Stogy
    All great information Mike as you know this thread is about period correct Hotrod / Custom louvers. The whole experience is welcome.
    I like to see the machines you guys use in the rendering of your craft. Some are pretty jazzed up just like a hotrod. Thanks Mike.
    Great job Joyflea...
    Ron Funkhouser and JOYFLEA like this.
  21. Stogy
    Stogy
    Nice teaser 61...the lid looks bang on...;)
    Is the lid from your Hotrod?
    I thought of an old Hamb favourite by the name Coupe de Cab but it has no louvers or handle on lid...
    @VonSkip's Hotrod​
  22. Stogy
    Stogy
    So speaking of Coupe De Cab which is over yonder in Holland...lookie at this...
    @VonSkip's Hotrod
    Perhaps he will chime in and let us in on the updates to this awesome Hotrod...
  23. Stogy
    Stogy
    Just add Dry Lake...strap on the Helmet, Goggles and Gloves and Giver...Stunning Hotrod...
    Credit to Photographer, Owner
  24. 61cad
    61cad
    Yes indeed!
    lothiandon1940, Stogy and hrm2k like this.
  25. Mike Rouse
    Mike Rouse
    0DCB948C-9C74-46F0-8117-F4F1F893DD2D.jpeg B85D04FA-F5EC-4EA5-8755-657365EBEBC4.jpeg D30B2D96-EAAD-43AC-9892-5618225B2FEC.jpeg A hood with Louvers I did for a customer.
  26. JOYFLEA
    JOYFLEA
    Mike , did you build your buck exact size and bend . What gauge cr did you use ? Any spring back ?
    Thinking of building one for my Tudor . Blue
    Stogy likes this.
  27. Mike Rouse
    Mike Rouse
    I,built the buck full size. Make templets of both existing ends. Transfer to the buck. Next using heavy paper from Home Depot placed over the hood area cut for an exact fit. Be sure to mark the centerline on the paper templet. Paper from HD is used to protect floors
    I used my English wheel with a rubber top wheel to make the curves I used 20 gauge steel.
    When bending this way spring back will be minimal
    Cut the metal about 3/8" larger on all sides then cut to size after final fit up. I have a tool that I made to trace the outline of the ends ov the hood. Made of two half inch wide by three inch long pieces of plastic .090" thick. The lower piece is bent down on one end about 1/4" to ride against the hood opening the top piece has a hole drilled in it right above the bent down lower piece. The two strips are fastened together at the other ends
    Hope this helps
    JOYFLEA, 509garyd and Stogy like this.
  28. rmorris
    rmorris
    image.jpeg My chopped top, shaved door handles with poppers, suicide left rear door 57 Chevy 4 door wagon has 100 louveres in hood. Love everything vented.
  29. Stogy
    Stogy
    could we see more please & thank you...;)
  30. 61cad
    61cad
    45BA4710-767B-4A98-8E96-827DA4779515.jpeg 2366FA06-21FE-4D9F-BB35-7FC6577FFA0D.jpeg
    Next stop interior
