Projects Border Bandits Gas class builds to the Southeast Gassers rules.
Discussion in 'The Hokey Ass Message Board' started by II FUNNY, Nov 5, 2014.
  1. 91whitestang
    91whitestang
    from Wisconsin
    P***enger side header tacked together
    Side view of p***enger side header with collector.
    Wheelie bar casters made.
    Pan hard mounts and bar made, once weight in the rear this will be more level than what it currently is.
  2. enloe
    enloe
    from east , tn.
    Very cool
    loudbang and 91whitestang like this.
  3. 91whitestang
    91whitestang
    from Wisconsin
    Front fender braces on the frame.
    Both seats mounted.
    Put it together partially for the meltdown drags this past year.
    OahuEli, 55belairx2, catdad49 and 9 others like this.
  4. 91whitestang
    91whitestang
    from Wisconsin
    Got Jeff over to do some more tig welding for me, wish I could tig weld 1/2 as good as him.
  5. Gammz
    Gammz
    from Lincoln Ne
    great work so far!!
  6. 91whitestang
    91whitestang
    from Wisconsin
    Getting the front brakes together to make it a roller.
  7. 91whitestang
    91whitestang
    from Wisconsin
    I'm sure I'm missing some photos in here, but the cage is in besides the door bars and bar behind the seat, rear suspension is getting close to being done. Probably going to get the pedal ***embly done next so I can get the steering box mounted along with getting the steering column mounted in the car. I started a page on Facebook for the car also that if you want to follow along on there you can, search for 1931 Ford Model A coupe the main stage southeast g***ers or you can find it by putting in @themainstageseg
    Sent from my SM-G955U using The H.A.M.B. mobile app
    catdad49, Dog_Patch, loudbang and 3 others like this.
  8. 0NE BAD 51 MERC
    0NE BAD 51 MERC
    Thank goodness someone is building something cool again! It was starting to get boring around here! A full fender A g***er is a breath of fresh air from everyone chopping, channeling and slamming them into the dirt. Larry
    OahuEli, 55belairx2, loudbang and 5 others like this.
  9. Hang'emHigh
    Hang'emHigh
    Your "A" looks great! Very close to the ones in the mid '64 copies of Eastern Drag News I have! Love it!
    Dog_Patch, loudbang and 91whitestang like this.
  10. 91whitestang
    91whitestang
    from Wisconsin
    Thank you really appreciate it!
    1931 Model A Coupe G***er
  11. enloe
    enloe
    from east , tn.
    91whitestang, Gammz and loudbang like this.
  12. southcross2631
    southcross2631
    I really like the direction your car is headed. My rear suspension will be similar to yours on my Morris. Trying to load some some photos to my dropbox , but Sprint is fighting me.
    Cool build.
    Dog_Patch and 91whitestang like this.
  13. 91whitestang
    91whitestang
    from Wisconsin
    Thank you guys for the support and feedback, helps keep the motivation of building this car with this ****py cold snowy weather we have coming down.
    OahuEli, Dog_Patch and loudbang like this.
  14. Quain Stott
    Quain Stott
    Great job, can't wait to have you racing with the Southeast g***er family. Please let me know if you need anything.
  15. savannahDan
    savannahDan
    can you post any more pics of what appears to be jack bolts on the coil springs? Been thinking about this for a while for my car, but can't decide how necessary they are. Any input would be welcome.
  16. 91whitestang
    91whitestang
    from Wisconsin
    Sorry this isn't a very good picture but it is a jack bolt that I went through the tubing with and then welded a bung on the bottom side of the frame that goes into the spring pocket to adjust the load. I'm not really sure if I will need them or not just wanted to have them there just in case. Sorry I'm not much help for input but that's how we did it on this frame.
  17. saltflats
    saltflats
    from Missouri
    Better to have than not. ;)
  18. savannahDan
    savannahDan
    Thanks!
  19. 91whitestang
    91whitestang
    from Wisconsin
    Started cutting into the old gas tank/gauge panel area to loose some weight. I'm just going to make a panel out of aluminum probably to go into that area with the temp and oil gauges to make a nice clean easy look.
    Then started working on getting the door bars made to fit for the cage.
    Was doing a little practicing on tig welding to on some s**** metal laying around also but I tell ya, that's one thing that takes time to make look decent and actually functional. I have to give credit to Jeff (strokedstang331) for the welds that are currently in my car as I cannot take credit for those compared to my welds.
  20. strokedstang331
    strokedstang331
    from Beloit WI
    Glad to see you making progress keep picking away at it and soon enough you will be sorting out the new car bugs and tearing up the track.
    Sent from my SM-G950U using The H.A.M.B. mobile app
  21. strokedstang331
    strokedstang331
    from Beloit WI
    Not to much for an update on the Skairlane but I got my new transmission about a month and a half ago. The car is still in storage going to have to dig it out real soon to get it ready for the first race in April. Also found a few good shots from 2017 I saved. Make your plans now the 2018 season will be a good one see pics for the schedule.[​IMG][​IMG][​IMG][​IMG]
    Pufff, 55belairx2, TFoch and 7 others like this.
  22. strokedstang331
    strokedstang331
    from Beloit WI
    Also the best thing that has ever happened in my life my son was born 12/29/17 only weighed 4pounds 11 ounces and was 18.5" long. Puts a entirely new perspective on life that's for sure. He was a month early and had to spend 21days in the NICU but he is doing well now. We had his newborn pictures done rite after we took him home thought I would share them as well.[​IMG][​IMG][​IMG][​IMG][​IMG]
    Pufff, OahuEli, 55belairx2 and 22 others like this.
  23. 0NE BAD 51 MERC
    0NE BAD 51 MERC
    Congrates on the new hot rodder Jeff. Keep those pictures handy so when he becomes a teenager and starts acting like a teenager, you tell him you will have his momma start showing them to his friends and start telling them how cute and adorable he was! lol That will straighten him out :)! Good luck this season . I will be cheering you on! Larry
  24. Higgy's Henry
    Higgy's Henry
    Way cool BRO!!! Great pics, glad everyone is doing good!!
  25. saltflats
    saltflats
    from Missouri
    Congratulations!!!
    They can be a true blessing.
    loudbang and strokedstang331 like this.
  26. enloe
    enloe
    from east , tn.
    Awesome
  27. rawcjw19
    rawcjw19
    Congratulations on the boy! Enjoy every minute,he will be a teenager in a blink of an eye
  28. Hang'emHigh
    Hang'emHigh
    My first spent 21 days in NICU as well. Hardest 21 days of my life. Congrats! And overwhelmingly joyful that everyone is home safe and sound!
  29. loudbang
    Shots of the new addition are GREAT. Congrats Mom & DAD :)
    strokedstang331 likes this.
  30. Congrats. Cool pics.
    strokedstang331 and loudbang like this.
