Technical Looking for recommendations for spray bomb chassis paint
Discussion in 'Traditional Hot Rods' started by banjorear, Jan 14, 2018.
  1. banjorear
    banjorear
    Looking for recommendations for spray bomb ch***is paint. I know many have used box store off the shelf Rustolium, but curious if there are other products out there that work better or are more durable.
    Thanks,
  2. VHT Rollbar and Ch***is paint is pretty good from my experience. Black is the only color but it does come gloss or satin.
    Adam.L likes this.
  3. drtrcrV-8
    drtrcrV-8
    HF carries a decent "Frame & Ch***is" spray paint.
  4. 56longroof
    56longroof
    I used Rustoleum 2X semi gloss black when I detailed the frame and suspension on my '56. Its been on there 2 years now and has held up great.
    Sent from my SM-G950U using The H.A.M.B. mobile app
  5. aerocolor
    aerocolor
    from dayton
    Another vote for Rustoleum 2X.
    We use it over etching primer but it does a great job by itself.
  6. banjorear
    banjorear
    OK, great. About how many cans did it take to do the ch***is? Aerocolor, did you use it on your motor as well?
  7. 56longroof
    56longroof
    I don't remember how many cans I bought. I did my engine bay also. If I had to guess I'd say maybe a dozen by the time I was done. But that includes all the suspension,springs, firewall, inner fenders and core support.
  8. southcross2631
    southcross2631
    Depends on the size of the car. My morris Minor has an 87 inch wheelbase and a Cadillac commercial frame will be almost twice as long.
  9. banjorear
    banjorear
    OK, that helps. '32 ch***is so I'd ***ume a dozen cans as well.
  10. Vimtage Iron
    Vimtage Iron
    KBS has a lot of spay can paints from primers,to top coats to high heat paints and primers, I've used it and it works very well, but it likes sand blasted areas the best, prep work is a pain in the neck, needs to be clean and then washed with their kleen solution, but that does work I didn't do that step and paid dearly for it one time, but as any spray can it takes several coats to get where you want it, it is durable, also their pint or quarts can be brushed on I used that on a truck frame and I steamed cleaned and wire wheeled the scuz off and used the kleen, and brushed on two coats one of rust seal and the other a top coat, came out looking real good, it is a self leveling paint so it has to go on in thin coats.
    59 restomod corvette likes this.
  11. NWRacing
    NWRacing
    If you have access to Kimball Midwest their line of spray can paints is very high solids and lays down like spraygun type paint. We painted some equipment with it at work at it has held up for years and still looks shiny and new.
  12. Mike Colemire
    Mike Colemire
    Rustoleum is great, I use their bed coating over it on some stuff. You can get either in qts, but a HF $10.00 spray gun and save money. If you drill the nozzle out to a 1/16 , you can spray it. Rustoleum etching primer is some really tuff stuff also.
  13. greybeard360
    greybeard360
    Duplicolor engine paint with ceramic... Works great and lasts if you make sure the frame is real clean. I have used it on frames and suspension parts and it keeps it's gloss or sheen well.
    Sent from my Moto G Play using The H.A.M.B. mobile app
  14. bobss396
    bobss396
    I used the VHT ch***is & rollcage black too. Look for 6-packs on eBay or Amazon.
  15. Bandit Billy
    Bandit Billy
    Not cheap but worth it, Eastwood 2K ch***is black. Catalyzed enamel in a spray can. Wear a respirator!
    IronTrap and lurker mick like this.
  16. Adam.L
    Adam.L
    from York,SC
    Another vote for VHT ch***is paint. Best spray bomb paint I've used.
    Sent from my SM-G900V using The H.A.M.B. mobile app
  17. bchctybob
    bchctybob
    I use Krylon Rust Tough for most of my ch***is painting. If you prep well and primer first, it will last for years and cleans up with just a wipe with a rag. I've used Rustoleum, but mostly its the Krylon stuff on the ch***is' of my cars.
    porknbeaner likes this.
  18. I second Krylon. It even ages like factory paint.
  19. tb33anda3rd
    tb33anda3rd
  20. I like the stuff the Eastwood Company sells A LOT. Not cheap but worth every penny. I used it on a 66 GTO I had and 20k miles later (when I totaled it) it still looked new
    Sent from my LG-K373 using Tapatalk
  21. aerocolor
    aerocolor
    from dayton
    I tried the brush on method one time.
    Never again. Takes too long and I didn't like the texture.
    We buy Rustoleum 2X by the case so I think six cans did the frame. Covers well.
    I've used Ch***is black, POR15, Rustoleum brush on and Krylon. 2X works best for me.
    As far as the engine, always engine high temp paint.
  22. steinauge
    steinauge
    from 1960
    I have had good results with rustoleum,I am always careful to use Rustoleum rusty metal primer with it as the paint seems to stay on better with that.
  23. Eastwood ch***is black. Spray or brush. Easy peasy
  24. rusty rocket
    rusty rocket
    A buddy just used some hirsch auto ch***is paint, brushed it on and said it layed down nice.
  25. gene-koning
    gene-koning
    I use Farm & Fleet Anti-Rust in a qt can, and spray it on with a cheap HF gun. Covers well and holds up well. Drys pretty slow though. The quart cans sprayed on are the least expensive way to paint the frame.
    The 2nd option is the Rustoleum 2X spray bombs. Gene
  26. LostBoy
    LostBoy
    Hammerite smooth finish works well and dries hard.
    Sent from my LG-V520 using Tapatalk
  27. bchctybob
    bchctybob
    I liked the Eastwood stuff when I tried it but you can get that extra can of Krylon or Rustoleum at the corner hardware store when you run a little short. We ordered several cans and one was a misfire, too much trouble to return a can of paint and wait for more. Better to buy paint local.
  28. Texaswino
    Texaswino
    I use "Blitz Black" in aerosol and quarts available at the John Deere store. Perfect satin finish. It is said a person could paint dirt with this stuff
    bchctybob likes this.
  29. Tomcats30
    Tomcats30
    Good info here...Thanks to all!
  30. southcross2631
    southcross2631
    I started buying Rustoleum in qt. cans and have a Harbor Freight gun dedicated for that use. Thin it with acetone and it works great for ch***is and fender well and floor pans. Way cheaper than spray bomb paint. The new spray bombs have a tendency to have more leakage around the nozzles and plugged up cans . I always turn them upside down and spray them out and soak the nozzles in paint thinner, but you still have too much waste. I have also brushed it on with foam brushes and rolled it on with foam rollers with good results.
