Hot Rods Got a model a coupe for "FREE" prepare to cry
Discussion in 'The Hokey Ass Message Board' started by haileyp1014, Jan 15, 2018.
  1. 49ratfink
    49ratfink
    you must be the King of the Stupids. did you sign up just to make idiot comments?
  2. 37hotrod
    37hotrod
    Sure you can...
    Clay Belt, biggeorge, Mikel50 and 8 others like this.
  3. MikieOne
    MikieOne
    NO not stupid from what I also have read from here from time to time, whats the matter don't you like re runs?
  4. MikieOne
    MikieOne
    Most people I see here have a sense of humor, I see its going to take awhile for you to get up to speed!
    haileyp1014 likes this.
  5. upspirate
    upspirate
    I wondered the same thing
  6. alchemy
    alchemy
    I once bought an A coupe body that had fallen off a moving trailer for $100. It looked very similar to yours, minus the charring. Parts of it went into this coupe:
    It lives on in infamy.
  7. Vanness
    Vanness
    That looks like the a they did for Paul Tuttle sr.
  8. Ebbsspeed
    Ebbsspeed
    That's a decent core for some of the metal gurus on the HAMB.
    That's a bottle, not a can.
  9. Corn Fed
    Corn Fed
    It is. Here's what the body looked like before we started grafting parts of other bodies to it.
    And here's one after the patching:
  10. Vanness
    Vanness
    Figured it didn’t start white lol. Came out nice.
  11. 37hotrod
    37hotrod
    I knew someone would call me on that. :)
    Couldn't find a decent picture of the old can during my 3 second google image search.
    Clay Belt and kiwijeff like this.
  12. 37hotrod
    37hotrod
    Is this better?
    crashfarmer, biggeorge and kiwijeff like this.
  13. Donut Dave
    Donut Dave
    You may have paid too much, Good Luck...
    scrap metal 48 likes this.
  14. joey7508
    joey7508
    from TX
    Any chance the owner had a ***le for that car? Hopefully in the house and not the garage. Might be the most valuable part left from that car.
    Clay Belt and 41 C28 like this.
  15. 48FLIP
    48FLIP
    from DENVER CO
    Look a the pictures closely. Does it look like this is a slant windshield? Is this a cabrolet or a coupe. If it is a slant windshield why does it have a visor? Only slant windshield coupe I've seen was the one proto type 3 window which has no visor.
  16. low budget
    low budget
    from Central Ky
    This is almost as common as the buffing comments:D
    caseyajones and kiwijeff like this.
  17. haileyp1014
    haileyp1014
    from so cal
    Garage was detached so the house didn't burn.the owner of the car took the ch***is and left the body behind.land Lord kicked guy out and she asked me if I knew any one who would haul it off. 20180116_121007.jpg 20180116_121003.jpg 20180116_120959.jpg
  18. joey7508
    joey7508
    from TX
    Interesting. Me and that horse are on the fence about whether or not this could be repaired.
  19. luckythirteenagogo
    luckythirteenagogo
    from Selma, NC
    You could get that up and running, and still have the whole afternoon to drive it around town.
    Sent from my SM-G920V using The H.A.M.B. mobile app
    kiwijeff and haileyp1014 like this.
  20. 1946caddy
    1946caddy
    from washington
    Chances are that the sheet metal was annealed due to the heat of the fire. Chances are that the fire dept. hosed the car down while still hot. You got it at fair market value.
  21. classiccarjack
    classiccarjack
    I wonder if you could fix the hardness of the metal still? Can a burned body be salvaged? I turned down a 1970 Challenger that was burned. That is why I am curious. I was told that the metal would tend to crack.... Did I get bad information?
    Sent from my XT1585 using The H.A.M.B. mobile app
  22. 1946caddy
    1946caddy
    from washington
    It depends on how hot the metal was and how fast it was cooled. I would ***ume that if it were a structural fire or car fire, the fire department showed up rather quickly and added cold water to the hot sheet metal. When you add cold water or air to hot sheet metal, it also shrinks the metal. Hammering on the metal after it has hardened to try and stretch it back into shape would surly add to the chance of cracking.
  23. classiccarjack
    classiccarjack
    Thanks 1946caddy for the information.
  24. mike bowling
    mike bowling
    LOTS of parts to rescue! ( a full set of hinges is worth 150 bucks all day long)
  25. Donuts & Peelouts
    Donuts & Peelouts
    from , CA
    And if cracked. What's the fix for that???
    Do we treat this job like any other job???? What factors must he and others working with metal from the 30's??? AND rusted too?.
    I ask because I was working on a similar car that rolled over. Rust had settled in and made the metal thin, orange, crusty and weak. When hit with a body hammer it did not act the same. Here is a picture of a door that has what im describing[​IMG]
    The hardest part will be where its crushed on the body lines, well it was for me. The easy solution would have been to cut it out. But when working with what you have and not having another car to take from you made due...
    Worked it back at 1st with a jack and 2×4 on its side and hammered/dollied out the rest but my question is what do you do when you have a developed a crease like in this picture, top left. [​IMG]
    And as I said in the beginning what do you do when you overwork it and stretch the metal out? Thanks.
    And don't give up hope OP.
    Sent from my SM-J727T1 using The H.A.M.B. mobile app
    VANDENPLAS likes this.
  26. indyjps
    indyjps
    Porta power that back into the general shape of a car, get the doors opening and closing, winshield in, and on a ch***is. Scuff it down all wrinkly and wipe it down with gibbs oil.
    Drive it around and tell the story everytime you stop.
    Perfect place for a rustoleum paint job. It sticks to anything, if it does flake off, jist brush more on.
    Dont know if thats workable back into a nice car with the unknown heat damage, but it can still be a fun car.
  27. redoxide
    redoxide
    That doesnt look like its been hot enough to anneal it. It more scortched and had something drop on the roof
    Secure it to a body jig and get the Porta power to work, pick the correct start point and it will come out as it went in.. The metal has a memory and its just amazing sometimes how they pull back into shape .. What would you have to loose, better to have tried and failed, before you let it rot into the earth..
    Does look worse now I take a second look , maybee has been hotter in some areas but still, what you got to loose? ( but your sanity )
  28. Painfulbanter
    Painfulbanter
    Don't harp on me too much, but what about selling it to a rat rodder, it would be one less nice car getting distroyed. But I was always wondering what would happen if you lit it on fire again and let it cool slowly, would it soften the tempering process that happened from the fire and water? I don't see trash at all, I'm glad you saved it from the s**** yard and I hope she sees the road again.
    Sent from my SAMSUNG-SM-G930A using The H.A.M.B. mobile app
  29. WTF really
    WTF really
    I definitely would've dragged her home as well. Good job.
  30. gene-koning
    gene-koning
    One thing about a project like this one, you sure can't hurt it!
    Get the body bolted to something solid and start jacking the roof back up, it might even come somewhat close to original, who knows. You have nothing to loose except a little time.
    Donuts & Peelouts, When a body is really bent up, the best thought is to get it as close to the original shape as you can, then tap the high spots down to just below the surrounding area, with something having a close contour behind it. Eventually it will have some filler in it, the idea is to have as little filler as possible. If you have a high spot, the surrounding area needs to be built up for the high spot to blend in, requiring a lot more filler. The secrete to filling low spots is to stop sanding before you remove too much filler and have to add more. Gene
    Clay Belt and indyjps like this.
