Customs ford aod
Discussion in 'The Hokey Ass Message Board' started by pistolitas, Jan 16, 2018.
  1. pistolitas
    pistolitas
    from orange ca
    i have a aod in my shoebox that won't shift .i already set the tv cable correctly my question is if i put a cheap filter in it would it cause it not to shift
  2. JeffB2
    JeffB2
    from Phoenix,AZ
    Did you install a shifter or make any change to the valve body ? Filter shouldn't affect anything.
  3. 1946caddy
    1946caddy
    from washington
    Maybe some more information might help. Was it working properly before the filter change or is this a new installation?
  4. chevyfordman
    chevyfordman
    Tell us how you set the cable.
    BurntOutOldMechanic likes this.
  5. pistolitas
    pistolitas
    from orange ca
    All I did was put all the stuff that comes with the lokar shifter and kick down cable i did have to open the pan to switch the shifting lever from down to up
    Sent from my SM-G935P using The H.A.M.B. mobile app
  6. pistolitas
    pistolitas
    from orange ca
    Yes it was working before I put the lokar stuff on it .this is the second aod trans i got and the same problem .I did use the brand of filters on both trans am i missing somwthing
  7. pistolitas
    pistolitas
    from orange ca
  8. southcross2631
    southcross2631
    Did you put a pressure gauge on it ?
  9. pistolitas
    pistolitas
    from orange ca
  10. 1946caddy
    1946caddy
    from washington
