Technical Anyone have a good pic of a 35 36 ford running fentons / duals through the stock crossmembers?
Discussion in 'Traditional Customs' started by Ball and Chain, Jan 11, 2018.
  1. Ball and Chain
    Ball and Chain
    from Nor Cal
    Looking for a good under ch***is pic of dual exhaust on a 35 -36 with a flathead routed in the stock location, through the crossmember above the axle ect.
    Thanks!
  2. john worden
    john worden
    from iowa
    In the front area it's trial and error or slice and dice.
    Rearward it gets easier.
    You want a pro with a pipe bender and/or a selection of bends to weld together.
  3. stillrunners
    stillrunners
    from dallas
    well....let's bump it....bump it good....
  4. lakepipes
    lakepipes
    from australia
    I have these, not the best pictures but they were on file. I hope they help. You can pretty much see where things are going.
    Mike.
  5. Ball and Chain
    Ball and Chain
    from Nor Cal
    Thats a good start thanks! bump
