Projects 1933/34 ford roadster project
Discussion in 'Traditional Hot Rods' started by Elvis100, Jan 13, 2018.
  1. trey32
    trey32
    Watcha using for wood?? Some hard *** oak??
  2. Elvis100
    Elvis100
    We are using a tight grain red oak. We ran short and are going to Tucson to pick up some more today.
  3. flynbrian48
    flynbrian48
  4. Elvis100
    Elvis100
    Thanks,
    We are putting a bunch of hours into the wood. The cost to buy them doesn’t seem so unreasonable now.
  5. x77matt
    x77matt
    This is going to be good. Subscribed!
  6. FlatJan
    FlatJan
    great work here, keep em updates comin ;)
    Elvis100 and loudbang like this.
  7. Chris
    Chris
    Killer! Love those 33/34 roadsters
  8. So-cal Tex
    So-cal Tex
    Looks like your a Zonie too and I dig your flathead build style in the 3 window, what part of the state are you in?
  9. Elvis100
    Elvis100
    [​IMG][​IMG][​IMG]
    Did some rough fitting of the wood on the drivers door and then worked on some of the small bits.
  10. Elvis100
    Elvis100
    Down in Bisbee. I’m doing the roadster with a later model flathead also...not as many cylinders.
  11. Elvis100
    Elvis100
  12. Elvis100
    Elvis100
    Thanks Chris,
    I may use those hinges I got from you.
  13. Atwater Mike
    Atwater Mike
    Elvis, that beautiful wood work makes me miss building large Control Line model airplanes!
    ...at the same time, makes me excited to get back on my '27 tub...
    Elvis100, chryslerfan55 and loudbang like this.
  14. uncle buck
    uncle buck
    Your workmanship looks way better than what I bought. I hope to do as good as you are on the rest of my needed wood
  15. Elvis100
    Elvis100
    Thanks, I don’t have good enough examples of the cowl and a-pillar wood to duplicate so I bought those pieces from Brad’s. Really amazing quality, I would say perfect.
  16. Elvis100
    Elvis100
    [​IMG][​IMG]
    Did some more fitting of the drivers door wood, all it needs is screws and final sanding.....and some metal work.
    Started fitting the wood to a drivers door skin I have. The plan is to marry this up with whichever p***enger door I don’t use and move them along.
  17. Pewsplace
    Pewsplace
    Nice wood work.
    Elvis100, loudbang and chryslerfan55 like this.
  18. Elvis100
    Elvis100
  19. Elvis100
    Elvis100
    [​IMG][​IMG][​IMG]
    Worked on fitting wood a little this morning then started on replacing the top of the second p***enger door. As you can see in the third picture the top looks like lace.
  20. Elvis100
    Elvis100
    I ordered the screws and a special tapered bit that does the countersinking for you.
  21. Elvis100
    Elvis100
    [​IMG][​IMG][​IMG][​IMG]
    Had to fab up a few inches of the top of the metal door tin on the same door
  22. Squablow
    Squablow
    Looks good. Fine metalwork and woodwork so far.
    I'll buy that lacey top piece if you'd be willing to sell and ship it to me, all I need it for is a pattern and measurements so it would do just fine. Let me know, thanks.
  23. Elvis100
    Elvis100
  24. Bill Rinaldi
    Bill Rinaldi
    I had NO IDEA how much wood was in the structure of a 33/34 roadster!! Lot of work!! Subscribed , want to see "the rest of the story".
    Stogy, Elvis100 and loudbang like this.
  25. brady1929
    brady1929
    Great job!
  26. flynbrian48
    flynbrian48
    Wow. Was it upside down in a ditch for 50 years? More killer work.
  27. Pete
    Pete
    Are those new door skins?
  28. Elvis100
    Elvis100
    I’m trying to keep as much of the original metal as possible. I used a new door skin as a donor to repair the top of one p***enger door and the bottom of the other p***enger door. The second drivers door is a new skin that I’m going to build into a door.
    Steve from McPherson auto fabricated the door skins last year for me.
    Stogy and kidcampbell71 like this.
  29. Elvis100
    Elvis100
    I think so
    Stogy likes this.
  30. Cyclone Kevin
    Cyclone Kevin
    Alliance Vendor
    Beyond impressed with the fab work here!!!!
    Kudos to you and your dad!!!! Do you have time to train me????;).
    Stogy, kidcampbell71 and Elvis100 like this.
