Projects 1957 Chrysler Mild Custom
Discussion in 'Traditional Customs' started by Gotgas, Jan 15, 2018.
  1. bskustoms
    bskustoms
    from Aloha, Or.
    Love the look of your sled. Always have loved fins, that's why I put a set of '57 Windsor fins on my 1956 Ford sedan.
    Gotgas likes this.
  2. The point is he should consider painting his car a nice dark color, lower it and ride around. I'm not seeking history lessons in the middle of his thread, you know?
  3. George
    George
    I bet!
    Jet96, jakespeed63, hendelec and 2 others like this.
  4. I really like that... so much so, I'm going to steal your idea for my '56 Desoto!
    Gotgas likes this.
  5. George
    George
    Front mounting plate that the dragsters use....
  6. I have done a disk brake conversion on several of the Chrysler forward look cars with Scarebird parts. I always use a ford 8.8 rear (usually from an Explorer), chevy caprice prop valves, and gm caprice pedal ***embly spliced into the original, caprice brake master and booster. Worked great. Yours sounds like a very similar setup, so I would ***ume it would also work well.
    I had this exact setup on the primered 57' Plymouth I drove to the HAMB drags a few years ago.
    Gotgas likes this.
  7. Any good Heliarc welder can weld your cast iron
  8. Gotgas
    Gotgas
    from DFW USA
    Please do! The '56 Chryslers and Desotos are my second favorite FL cars. ;)
    While I agree that's the best use of the block at this point if I don't repair it, I really don't want a motor plate in my ride.
    Weather was cold this week, so progress has been slow. Now that I have the correct pilot adapter, I am mocking up the transmission again to install everything this weekend. I'm running into an issue with the pilot depth. The input shaft bottoms out a half inch before everything aligns. Grr.
    mgtstumpy, Stogy, Ford52PU and 4 others like this.
  9. Gotgas
    Gotgas
    from DFW USA
    Apparently I still don't have the right transmission pilot, so the drivetrain is still out of the car for now. We worked on a few other things this weekend instead. I pulled the dashboard out of the parts car and will work this week on cleaning the gauges and prepping it all for paint. As you can see, it's in amazing condition; it looks brand new. Door jambs are painted black. A little progress... but I sure would like to see that engine where it belongs. :rolleyes:
    VANDENPLAS, mgtstumpy, Stogy and 4 others like this.
  10. dwollam
    dwollam
    So..... How did you get what looks to be a picture of the finished car as your avatar if the car isn't finished yet?
    Love the car, reminds me of Dad's '57 New Yorker in 1961-63. Man that thing would run!
    Dave
    toolmaker likes this.
  11. dwollam
    dwollam
    I see later you say the pic was Photoshopped! Nice job!
    Dave
    Gotgas likes this.
  12. 55Deso
    55Deso
    from Wyoming
    Love this! In my opinion the forward look mopars are the most beautiful designed cars on the road. Of course I may be a bit biased....
    Gotgas likes this.
  13. 55Deso
    55Deso
    from Wyoming
    Do you have a thread or at least pictures of said Desoto? I have a '55 Firedome project myself
    golferforpar likes this.
  14. Moriarity
    Moriarity
    SUPER MODERATOR
    Love those finned mopars, your plans are spot on for this one. congrats on finding such a rust free example. this is really going to be a *****in car man, good going!
    HEMI32, Sancho, Gotgas and 1 other person like this.
  15. jack_pine
    jack_pine
    from Motor City
    If you do another 392, the manifolds used when they put Hemi engines in trucks are much like the units you used. Much higher flow and can be found cheap on eBay
    Sent from my SM-G892A using The H.A.M.B. mobile app
  16. Gotgas
    Gotgas
    from DFW USA
    I took a look, and they are indeed 7.10-15s.
    Hey man, thanks! Your cars are all dripping with that 60s kustom vibe, so I appreciate you saying that. Maybe someday I'll have it made. ;)
    Yep, I'm aware! The truck manifolds are a tight (impossible?) fit in a torsion bar ch***is. Even with an inch cleaved out of the side, the ones I have are really close.
    Moriarity and jack_pine like this.
  17. Gotgas
    Gotgas
    from DFW USA
    Managed to get a lot done this weekend. Blasted and painted a ton of parts, like the air cleaner, hood hinges, sway bar, all kinds of stuff that needs to be done. Dad painted the steering wheel and it turned out great.
    After fighting the clutch pilot situation for weeks, we got it dialed in with this flywheel-mounted adapter. After getting the transmission bolted up, it was time to get the Hemi in the car. It lowered the front of the frame about eight inches! And I get to reclaim about 50 sf of shop space back.
    20180128_150218.jpg 20180128_160013.jpg 20180128_185139.jpg 20180128_190600.jpg 20180128_200818.jpg 20180128_194950.jpg
    VANDENPLAS, mgtstumpy, Thor1 and 31 others like this.
  18. cobramerc
    cobramerc
    Looking real good! it's starting to come together quite nicely
    Gotgas likes this.
  19. Sauli
    Sauli
    Wow, what a beautiful car You have!
    The '57-61 Chrysler cars are some of the best-looking automobiles of all time!
    Good luck.
    Gotgas likes this.
  20. Ford52PU
    Ford52PU
    from PA
    looking good. will be a beautiful car
    Gotgas likes this.
  21. Mr48chev
    Great thread. Add me to the brigade who always thoght the avatar was a photo of the finished car. This is going to be sweet when it is done.
    Gotgas likes this.
  22. Okie Pete
    Okie Pete
    Thank you for taking us along on your build . I like the pics with your Dad in them . The grin on his face is priceless.
    Gotgas likes this.
  23. chopolds
    chopolds
    from howell, nj
    Really looking forward to seeing this one done!
    Gotgas likes this.
  24. FNG
    FNG
    from New Jersey
    Very cool, a few years back chopolds and I were in a local junkyard and there was one of these pretty intact
    Gotgas likes this.
  25. manyolcars
    manyolcars
    I bought a Henrob torch at Pate 15 years ago because the vendor was demonstrating on cast iron. I have been using it ever since with awesome results. It welds cast iron like melting ****er. My friends watch and say, "Its gonna drip out!" Nope. Never had a drip. All of the welds have held up.
    A henrob can quickly and easily fix the ear
    Gotgas likes this.
  26. 57fordor
    57fordor
    That's a great looking car. Nice work!
    Gotgas likes this.
  27. Toner283
    Toner283
    Go Man Go! Looking great. I know almost zero about this era of Chrysler, but they are definitely cool looking. That scoop looks spot on to me. You will likely have lots of people guessing where it came from. Looking forward to more.
    Gotgas likes this.
  28. Gotgas
    Gotgas
    from DFW USA
    Thank you all for you comments! You guys are very motivating. I apologize to those of you that thought the car was 'done' because of my avatar. Next time I'll try to make it more obvious that it's photoshop. ;) :D
    We had a decent weekend of weather, so we blew apart the dashboard and cleaned it up. The padded dash has more lumps than I'd like, but no tears. Instead of buying a new one for $600+ we're going to dye it and run it this way for a while. Hopefully we can get it to look nice. The dash is the same gray as the roof, the pad will be black, and the gauge pods are gold. All the instruments and chrome are cleaning up nicely. I am using a 150mph speedo from a 300C, I wonder if anyone will even notice. :D
    VANDENPLAS, mgtstumpy, 55Deso and 9 others like this.
  29. Chili Phil
    Chili Phil
    Go, Danny, Go! After all the threads about "g***er" farm trucks and borderline rat rods, your Chizzler is a breath of fresh air. I think you have a cohesive vision for this car. I'm enjoying watching you build this thing.
    Phil
    scotty t, 62hotcat, Sauli and 6 others like this.
  30. Rolleiflex
    Rolleiflex
    Your car is really coming together nicely! I love the forethought into the look you're after. I remember seeing your wagon years ago at some of the early LoneStar Roundups. I hope you're able to make it this year.
