Hot Rods PAINTERS ! Help with Ford Redfire Pearl
Discussion in 'The Hokey Ass Message Board' started by Bubzy, Jan 18, 2018.
  1. Bubzy
    Bubzy
    from Detroit
    What can I add to factory B/C C/C to get more metallic finish. Thinking about going Ford Redfire Pearl it doesn't seem to have much of a metallic to it. Painting a G***er style Chevy and don't want to get into flake, a lot of sanding, etc. Just shoot & clear. Any advise is greatly appreciated
  2. talk to you paint store guy
    they have flakes in different sizes
    I have had them change the metallic size on an OE paint code
  3. Joliet Jake
    Joliet Jake
    from Jax, FL
    I had my local paint store add more metallic to my paint until it had the amount I liked, at no extra cost.
  4. Jack of Arts
    Jack of Arts
    Careful, you can float pearl & flake in the clear,don't overdo it
    Sent from my SM-N950U using The H.A.M.B. mobile app
    anthony myrick likes this.
  5. watch this
    there are some mid coat clear flake/pearl systems that can be sprayed through normal guns
    google clear flake additives
  6. Paint_Rep
    Paint_Rep
    You could also add extra flop adjuster or flatter to your base to make the metallics/micas stand up on end when you spray them. Old trick to give your metallics more life! If you were using PPG Deltron (DBC) basecoat you can add DX821, DX995, or DX685 to any existing regular metallic formula and radically change the “wow” factor of basecoat by changing how the metallics stand up!
