Customs 39 Willys Coupe Body Question
Discussion in 'The Hokey Ass Message Board' started by 10secterror, Oct 22, 2017.
  1. 10secterror
    10secterror
    Has anyone replaced a Willys A pillars and cowl as one piece?
    Comparing the inner structure 38 to 42 are not any big changes, and have same shapes.
    Looks like the first 12 inches of the 4 door roof is the same profile need to swap it out as well.
  2. xracer40
    xracer40
    10secterror likes this.
  3. 1934coupe
    1934coupe
    My good friend did, there is a 39 coupe from the northeast running around with the cut going through the windshield and across the floor. If I recall correctly 38 Willys have different hood hinges, they go through the cowl at the sides were as 39 - 41 hinge at top of firewall and cowl area with a single piano type hinge.
    Pat
  4. fsteddie
    fsteddie
    from Pa
    The first (of the fat Willys) 37 Willys had the hood hinges mounted in the cowl. By 38 and later they went with the single piano hinge in the center of the hood. The only other difference in cowls is the wiper mounting hole position. 37 - 40 had the wipers up top above the windshield. 41 and 42 had them on the bottom of the windshield. This is the most obvious way to know a real 41 or 42. The coupes and sedans shared the same cowl and a pillars so it is possible to cut and splice them. Again there is an exception, the 41 and 42 sedans actually had a larger windshield, (and different back end,) and would not be correct for a coupe or earlier car.
    modelkitbasher likes this.
  5. 10secterror
    10secterror
    Thanks, I cut the coupe. A pillar and cowl was toast
  6. willyscoupe
    willyscoupe
  7. 10secterror
    10secterror
    That's awesome, I didn't end up just doing the A pillar. Ended up having to do more. IMG_4075.JPG IMG_4127.JPG IMG_4183.JPG
    Have to finish a really rare car for my best customer, then back to work on my Willys
  8. 10secterror
    10secterror
    I notice between the roof of yours and the rear quarter is smooth as gl***. Mine had over a 1/4" of lead from the factory. Did you cut out and replace?
  9. Rocky
    Rocky
    Classified Editor
    Wait....did you need to use the front 1/2 of your sedan doors to match hinges? Coupe hinges were different?
  10. oldrelics
    oldrelics
    from Calgary
    I could use a 6" chunk out of the upper old windshield opening if its not rotten....
  11. 10secterror
    10secterror
    A pillar hinges are the same with three fasteners, B pillar on sedan are different with 2 fasteners.
  12. 10secterror
    10secterror
    Roof is rough, that is why I ended up doing more that the A pillars.
