Technical How do you remove magic marker (sharpie) from parts?
Discussion in 'The Hokey Ass Message Board' started by quickchangeV8, Jan 20, 2018.
  1. quickchangeV8
    quickchangeV8
    I have a couple of aluminum intake manifolds and a plastic box that has a dial caliper in it. These parts were purchased at a swap meet and the vendor marked the purchase price on each piece with a magic marker. Is there an easy way to remove magic marker from parts? So far I have tried varsol, paint thinner, gasoline, and acetone and none of these don't seem to have any effect at all in removing the magic marker. Anyone have a solution to remove magic marker?
  2. Beau
    Beau
    Rubbing alcohol. Or MEK.
  3. brake cleaner on metal parts. it might damage the plastic box.
  4. CNC-Dude
    CNC-Dude
    Acetone works good too!
  5. Deuces
    Deuces
    We use lacquer thinner all the time on cast aluminum parts at work..... That and a shop rag..
    Works like a charm!!!! ;)
  6. KoolKat-57
    KoolKat-57
    from Dublin, OH
    Try an automotive polish on the plastic box, Brakleen on the manifold as Racer X said.
    Soak the area on the manifold well but don't let it dry, soak up the area with a clean cloth or paper towel.
    KK
  7. 41rodderz
    41rodderz
    from Oregon
    Yes on the brake cleaner;)
  8. ClarkH
    ClarkH
  9. fordrodsteven
    fordrodsteven
    I have had success taking the same type marker and scribbling (or blanking) out over the writing I want to get off the part. Then quickly wipe it. It usually removes most of it then I get the rest using alcohol. Maybe even scribble over it again and quickly wipe with alcohol. Try it on another piece of metal or plastic to prove it out.
    loudbang and Ron Funkhouser like this.
  10. patterg2003
    patterg2003
    If it is true magic marker it should come off easy with isopropyl alcohol or lacquer thinner. Alcohol wont hurt the plastic case.
    rc57 likes this.
  11. HOTRODPRIMER
    HOTRODPRIMER
    Bead blast the manifolds,the magic marker has probably soaked in the cast aluminum as for the plastic box the goof off should do the trick,even the boss lady's fingernail polish remover might get it. HRP
    Mr48chev likes this.
  12. WD40 has saved my *** more than once.
    Lacquer thinner usually takes it off like magic.
    loudbang and Speedys Garage like this.
  13. dan31
    dan31
    x2 on the "goof off"
  14. john worden
    john worden
    from iowa
    FWIW Sharpie ink will bleed through paint products.
    loudbang and lurker mick like this.
  15. Sheep Dip
    Sheep Dip
    from Central Ca
  16. vtx1800
    vtx1800
    Carb cleaner works great. Ask me how I know:) I use an iron slag
    product in my sandblaster and it takes it off too. I use magic markers
    to point out areas I need to hit again (no matter how often I change
    the plastic shield, old eyes can't see the little stuff).
    LOST ANGEL and loudbang like this.
  17. Yep!
  18. edcodesign
    edcodesign
    That's what I use also.
  19. Slopok
    Slopok
    Waterless hand cleaner ( Goop, Fast Orange) and an old toothbrush.
  20. Mr48chev
    [QUOTE="HOTRODPRIMER, plastic box the goof off should do the trick,even the boss lady's fingernail polish remover might get it. HRP[/QUOTE]
    Nail polish remover is usually Acetone. Don't use it on the plastic. Simple way o getting a little bit of Acetone without buying a quart though.
  21. Latigo
    Latigo
    Discovered that hairspray takes permanent marker off a dry erase board. Just sayin.
  22. DDDenny
    PB Blaster on the intake.
  23. LWEL9226
    LWEL9226
    from So. Oregon
  24. DDDenny
    Well, I just tried it on some 1/8" aluminum sheet that had a small patch of black marker on it for quite some time, didn't do much but I didn't let it set, that may have made a difference.
  25. Beau
    Beau
    Goof Off will eat away at plastic fyi
