Projects 30 Ford coupe build
Discussion in 'The Hokey Ass Message Board' started by Fitnessguy, Oct 18, 2015.
  1. Dino 64
    Dino 64
    from Virginia
    Here’s a ****py pic of one Hilton’s coupes. A trunk shot of the tank and hose and you can see the cap mounted in this rear shot if you zoom in. That’s where I’m putting mine except on the driver’s side.
    Hope that helps.[​IMG][​IMG]
  2. INVISIBLEKID
    INVISIBLEKID
    from Gilroy,CA
    Things I'm looking for. No good or bad, just preference, but pro's/con's. Always seem's after the fact so to speak. Is that Gem vented?(cap)....?
  3. Fitnessguy
    Fitnessguy
    No it’s not vented. The tank is vented. Came with the tubing and a one way valve for the vent.
  4. INVISIBLEKID
    INVISIBLEKID
    from Gilroy,CA
    Thanks- Info to be aware of. Depending on tank,=I like yours, and might do the same, becomes the Q of filler location.....Can always vent from the tank, or filler tube if needed.
    One again=Thanks. I wont clog your thread with stuff...... Carry on with the fine job your doing, as I'm watching!
    loudbang and Dino 64 like this.
  5. Fitnessguy
    Fitnessguy
    Ya no worries. I have searched for pics of guys mounting them on the quarter but I haven’t been able to find that many. Most of the ones I’ve found seem to be 32’s where the profile on the quarter is spaced differently. I would like to see pics where guys have done it on A’s
  6. Bandit Billy
    Bandit Billy
    Love the Crafty B cap, he does some amazing things! I have a few of his creations. The trick with a cap mounted that high is I have always heard that the vent should be higher than the cap (or vented cap).
    Great build so far.
    loudbang and Stogy like this.
  7. wackdaddy
    wackdaddy
    Me three James. Here's a few pics I have been ac***ulating for when I attack this issue. There is a hell of a lot a contour going every which direction on top of those quarters. 11GasFiller04S.jpg fullsizeoutput_be.jpeg gdg10.jpg
    mgtstumpy, brEad, Dino 64 and 4 others like this.
  8. Stogy
    Stogy
    The roadster has significantly more real estate on that panel as beautiful as that whole last installation is including the cap. The quarter still ends up most sensible place albiet a challenge like all the others...I remember a coupe maybe B***'s that had reworked the panel out and the trunk lid modded to allow the panel mod. Ton of work but looked pretty cool.
    Thanks @31chevymike for confirming what I was thinking...a pic with a link and the author of the mettalic sculpture
    https://www.jalopyjournal.com/forum...upe-build-thread-photo-journal.336494/page-24
    mgtstumpy, brEad, Dino 64 and 2 others like this.
  9. Stogy
    Stogy
  10. Fitnessguy
    Fitnessguy
    I agree with Stogy, the quarter panel is a challenging install as there is not a lot of real estate. I have seen the pics where someone put it in the middle top of the deck lid which i like the look of. good things to discuss with the body guy when we roll it down.
    Dino 64, loudbang and 31chevymike like this.
  11. Indeed, that builder who placed the fuel cap in the center above the trunk lid is Brian B*** on the Wade Model A Coupe. LOVE that hot rod!
    Sent from my SM-G955U using The H.A.M.B. mobile app
    Dino 64, loudbang and Stogy like this.
  12. Fitnessguy
    Fitnessguy
    Ya i thought that was the car. I will google it and see if i can find some pics. I thought he had some youtube videos of the build.
    Stogy, 31chevymike and loudbang like this.
  13. The Wade Coupe thread is here: The Wade Model A Coupe: Build Thread & Photo Journal. The fuel cap installation is on page 24. Crazy installation though, B*** notched the trunklid to pull this off. He finished this because the fuel tank filler neck is directly in the center and connects right above to the fuel cap.
  14. Stogy
    Stogy
    I posted the link to that build back a few posts with a pic of the cap with a T-shirt...
    Just an observation on that Blue coupe...while the quarter install is cool and it looks fine the base to the quarter almost looks and may be grey plastic. If it was me albeit a challenge I might have an aluminum mount with a gasket to the quarter to protect the surface as plastic is a little newish looking.
    Anyhow...have fun Fitness...decisions, decisions...;)
  15. Fitnessguy
    Fitnessguy
    Yes I remember seeing it before and spent some time looking at it yesterday. My take sits straight in the middle as well. After some debate I am gonna try my hand at this route as well as long as Brian didn’t patent the install! Ha ha I printed off the pics of each basic step. Making the piece that the cap itself lands on is not that hard. Getting the decklid notched and that all lined up will be a little more challenging but what’s life without a challenge! With the height of my tank, frenching the cap on the quarter would make the cap sit below the fill hole on the tank so no bueno.
  16. Stogy
    Stogy
    That is going to look purdy spiffy...
    Fitness I was just reaching from the side over to the center on the ole Sporty here...its a long reach. I am of the opinion B*** accessed this filler from the back. When I fill up the Hotrod I watch for fuel backup as it has. All cars fill differently but you would have trouble seeing it in the center so far away. You might want to consider the B*** setup your thinking but offset it to one side or the other perhaps a few inches from the corner so you can have visual and ease of reach.
    It would still look fantastic even offset.
    Just thinking out loud my friend...;)
    loudbang, Fitnessguy and 31chevymike like this.
  17. Fitnessguy
    Fitnessguy
    Welllllllllll Bam! Here’s an afternoon of work! I decided to go square instead of round like b*** so it matches the straight lines of the decklid. Took my time with the layout. Happy with how it turned out. I will leave the notching of the decklid to my body guy! He can sweat that part! Ha ha I don’t profess to be Mr. B*** but I think it turned out not bad for a home built hot rodder. [emoji3]
    [​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
  18. Stogy
    Stogy
    Hey thats a great job there Fitness...;)...and revisiting B***'s craftsmanship is quite remarkable. He is definately a force of all things Hotrod.
    Backing up my thought to you I produce this without even a flame or smell of burnt skin annnywhere...:D
    Credit to Hamber @B***
  19. Fitnessguy
    Fitnessguy
    Thanks man. Looks good off to the side as well. Will have to decide which way to go.
  20. Max Gearhead
    Max Gearhead
    from Wisconsin
  21. chop job
    chop job
    from Wisconsin
    Great idea and nice work I am going to use this for mounting cap on the roof of my sedan.
    mgtstumpy, Stogy and loudbang like this.
  22. Nice fab work on your fuel cap - guess it comes down to how high your fuel tank is to determine the design of the filler tube, whether it has room to bend at the proper degree if you decide to mount on the driver's side as Stogy suggests.
    loudbang, Stogy and Dino 64 like this.
  23. Fitnessguy
    Fitnessguy
    Next item on the agenda... a little custom hold down plate for the shifter and e brake boots. Used my new slip roller to put the curve in the plate. Sure is nice having the right tools!
    [​IMG][​IMG][​IMG]
    mgtstumpy, brEad, wackdaddy and 5 others like this.
  24. Deucedreamer
    Deucedreamer
    from BC Canada
    Looking good!!!
    Fitnessguy likes this.
  25. Fitnessguy
    Fitnessguy
    Well no turning back now! Coupe went to the bodyshop today for bodywork and paint. It's my friend's bodyshop so i will actually be helping a lot with the work which will be good to get some knowledge on that end of the biz anyways. Excited and nervous all at the same time. Taking cash donations from anyone willing... :D Ready for this
    next big step!
  26. Max Gearhead
    Max Gearhead
    from Wisconsin
  27. Deucedreamer
    Deucedreamer
    from BC Canada
    I’ve already donated 2 cents to your project when it came to your dash...now you want more??:D:cool:
    Stogy and brEad like this.
  28. Dino 64
    Dino 64
    from Virginia
    You had that beautiful bare steel body in the Canadian weather !?
    Best of luck with the paint. I’m sure having a friend in the biz will guarantee a great result. [emoji106]
    lothiandon1940 likes this.
  29. Fitnessguy
    Fitnessguy
    I always want more!! I have taken a page from the millennials! Ha ha
    Stogy likes this.
  30. Fitnessguy
    Fitnessguy
    Ah it’s cold and dry right now so took advantage to slip it down. The shop is less than 5 minutes from my house. Ya pretty excited to see some colour squirted
    Dino 64 likes this.
