Projects Shade tree Model A speedster kind of thing
Discussion in 'Traditional Hot Rods' started by rwrj, Nov 21, 2017.
  1. Do the shoes seem to match the arch of the drums well?
  2. rwrj
    rwrj
    from SW Ga
    They do. I'm off the brakes for a bit, though. My latest progress necessitated removing the gas tank temporarily, so the car isn't driveable right now, anyway. I tend to jump around a bit on projects.
    The old Jeep seat had some issues. I felt like it sat too tall and, since it was just a flat bench, it didn't inspire a feeling of security, so I decided to make some seats. I copied the staggered arrangement a lot of European pre-war racers used, and I think Paco made a Model T speedster body with them, as well. Not much explaining to do. Same strip/epoxy method I've been using all along. Again, the epoxy is a modern convenience, but there is nothing here you couldn't do with one of the old hide glues they had back then. It would just take longer. You can see my mocking-up/eyeballing methodology pretty well here. Made them way oversize and just kept cutting the ugly away until I got it where it looks right to me. Probably some more adjustments to come.
    IMAG1378.jpg IMAG1379.jpg IMAG1380.jpg IMAG1392.jpg IMAG1396.jpg IMAG1398.jpg IMAG1397.jpg IMAG1399.jpg IMAG1400.jpg IMAG1402.jpg
    I just measured my *** and went from there. They fit pretty snug, but I think they will be comfortable enough.
    ratrodrodder, Dannerr, brEad and 9 others like this.
  3. rusty rocket
    rusty rocket
  4. Cosmo49
    Cosmo49
    What did you wrap the steering wheel with?
  5. rwrj
    rwrj
    from SW Ga
    Just regular cotton twine from Lowes, and some Linseed Oil, which may have been a mistake. It's taking days to dry. Keeps my hands from turning black from the ancient rubber, though.
    Jet96 likes this.
  6. You sir just gave me an idea for after I get Lizzie done...
    Sent from my LG-K373 using Tapatalk
  7. Wayne67vert
    Wayne67vert
    I wrapped my '38 Chevy truck wheel with twine also. I coated it with polyurethane. It turned out great.
  8. TomT
    TomT
    Those seats are very cool! Great work on a super project ....
  9. Stogy
    Stogy
    P***enger gets to stretch the legs out...cool. Your build never gets dull...;)
    @rwrj when I saw this it made me think about your vintage project. This is actually an Argentinian
    Speedster/Hotrod/Jalopy...Just for some inspiration...thought you'd enjoy it.
    A little twist on the grill shell...looks to be a 30 (custom or just a difference in production as per region). Perhaps these fellows are renowned
    as it seems the car has been museumed.
    https://www.jalopyjournal.com/forum...genized-hotrods.1002926/page-47#post-12400833
  10. rwrj
    rwrj
    from SW Ga
    I like it. Wonder why the right side tires seem so low on air? Maybe just a trick of the light. As far as foot room, I think the main reason for the staggered seating is to keep the p***enger from getting constantly jabbed by the driver's elbow. Also, it gives a little more shoulder room. I think in the old days it was more common than it is now for people's shoulders to be wider than their hips.
    Dannerr, scrubby2009 and Stogy like this.
  11. badgascoupe
    badgascoupe
    Looking good,recently got hooked on speedsters and dig it.
  12. rwrj
    rwrj
    from SW Ga
    Nibbled away at the seats some more this morning. Finishing out the front edges. I'm going to add some more bracing underneath. Sorry about the overexposed pictures. It's a real pretty day here. Obviously, the vertical parts will get trimmed. I'm going to leave 1/2" or so proud to keep whatever cushion I end up using from slipping forward. The ends are so raggedy because they are what I trimmed from the excessive height when I made the seat backs.
  13. rusty rocket
    rusty rocket
    You have been a busy little beaver.
    DIYGUY likes this.
  14. Do you buy these strips like this or do you run them through a router or something? I may be able to use this to some extent on my 27
    Sent from my LG-K373 using The H.A.M.B. mobile app
  15. rwrj
    rwrj
    from SW Ga
    These pictures are a little dark. Had to wait for some epoxy to dry, but I couldn't resist dashing out just before dark and roughly t******* the new fronts, just so I could get an impression. I'm pretty pleased. I am planning to add one last bit of bodywork over the tank, shamelessly copied from the car in the "totally insane race car..." thread. Pretty obvious where I got the inspiration for the seats, too. My tank will be covered by that projection, though.
  16. rwrj
    rwrj
    from SW Ga
    Oh, yeah. We made the strips, but you can buy them from outfits that sell supplies and plans for strip planked canoes.
    Okie Pete and Stogy like this.
  17. Stogy
    Stogy
    :rolleyes: I think you have just mentioned some future projection......awesome
    The vulnerability of the vintage design is blatantly obvious here from a safety standpoint but it is something we ***ume with the territory.
    You are not alone thats for sure.
    One thing in your favor is that tank is no doubt near crush-proof.
  18. Round over bit in like 1/2" thick wood?
  19. rwrj
    rwrj
    from SW Ga
    They are just under 1/4", 3/16", I think. Just under 1" wide. We ran them on a table shaper, like a big, permanently mounted router. You can buy the cove and bead bits for routers, though, and lots of people run them that way.
    oliver westlund and Stogy like this.
  20. rwrj
    rwrj
    from SW Ga
    Stogy,
    No doubt about the safety concerns on that tank. It does end short of the back edge of the rear wheels, which might help a bit. Like you said, kind of part of the deal. Not much worse than a stock 32 tank, I guess?
    Stogy likes this.
  21. rwrj
    rwrj
    from SW Ga
    I pulled it around to the regular old picture spot. I'm going to need to re-bend the gearshift, but I'm pretty happy with the seating.
    I have some work left to do in the middle where the two seat backs meet. The angle is awkward, and they aren't really fastened together at all, and that bothers me. It needs to match the angles of the outside edge of each seat. The tank looks awkward mounted like that, but I think my last bit of body will fix that. As always, thank you all for looking and for your input.
  22. The seats look great! I was hoping you would add some sort of tail section. It is really coming together man! I need to get back on mine.
    Do you have a link to the "totally insane racecar thread?" I can't seem to find it in a search?
    Stogy likes this.
  23. rwrj
    rwrj
    from SW Ga
  24. Ah yes I remember it now! Thanks for the link!
  25. ozstuff
    ozstuff
    Cactus try a google search for ' richard scaldwell' I think the car is his.
    Oz
    cactus1 likes this.
  26. waxhead
    waxhead
    from West Oz
    I'm not sure how I missed this, but I like what you are doing. Please keep the updates coming.
  27. willymakeit
    willymakeit
    You have caused A ch***is to jump in price.
    Great car
  28. Roger Roadster
    Roger Roadster
    Great job, It looks like fun X 10
  29. rwrj
    rwrj
    from SW Ga
    Got a bit more done. I added this piece to the junction between the two seats.
    Then started working on the little rear projection. This will eventually have the filler cap coming up through the top. No plans, again, just winging it. The big side pieces (and the piece in the seats) are Tulip Poplar, leftover from boat planking projects. The two little planes in the last picture my father made. One convex, one concave. They let me make bead or cove faces on the big pieces and the beveled ends.
    IMAG1433.jpg IMAG1435.jpg IMAG1436.jpg IMAG1438.jpg IMAG1439.jpg IMAG1440.jpg IMAG1441.jpg
