Projects ROADSTER, 1929 FORD
Discussion in 'The Hokey Ass Message Board' started by Frames, Jan 21, 2018.
  1. Frames
    Frames
    I had the frame rails broke by a local fabricating shop. 6" high at the rear. 5" high at the cowl. Then the taper increases down to 3.5" at the front. There is a 1" radius at the bottom to simulate a rolled pan. With the use of a chain, Port-O-Power and a torch I curved the rails to match the 29 body. I flame cut the arches over the rear end and capped them. The front kick ups, shock and headlight mounts will be hidden by the track nose. The floor is dropped 3". The 3.5" img071.jpg p1010029_0004_0071.jpg p1010032_0008_0074.jpg p1010039_0009_0081.jpg exhaust is ovalized for ground clearance. I cut a gl*** pack in half.
  2. 48stude
    48stude
  3. RacingRoger
    RacingRoger
    VERY impressive, and looking good! I'm interested in where you go from here - care to share any details on future plans?
  4. brady1929
    brady1929
    Wow is right!
  5. Stogy
    Stogy
    @Frames compliments to you and your veteran skills and experience...that is a work of art and a cool Hotrod coming together. Looking forward to the evolving experience you are presenting to us.
    Vanness likes this.
  6. K13
    K13
    @Frames Nice work but don't you already have a thread on this car?
    Blue One and HEMI32 like this.
  7. A Boner
    A Boner
    Automotive work of art! I'll be watching!
  8. k9racer
    k9racer
    the frame is great very nice work. Now the big question how do you keep the floor so clean. You must have a full time clean up person.
  9. RAT "T"
    RAT "T"
    VERY NICE WORK, WOULD YOU HAVE MORE PICS WITHOUT THE FLOOR INSTALLED?
  10. Frames
    Frames
    I did my concept drawing and blue print. Rare Frankland V-8 quickchange with triangulated linkage. Pie cut sectioned 1/4 panels. Upper and lower reveal lines now parallel. Wood buck to build the hidden cowl. The cowl foot [1" x 1" ] runs from the firewall to the 1/4 panel to make the cowl very stable. The 29 type coach revel [ 1" x 1" ] img231.jpg img232.jpg img233.jpg img234.jpg img235.jpg img236.jpg img237.jpg img090.jpg will be exposed. The lower part of the firewall bolts in. The windshield posts will drop into the coach reveal.
  11. DDDenny
    Very tidy Dennis.
    Keep those photos coming, always like seeing closeups of your work.
  12. RacingRoger
    RacingRoger
    Interesting setup with your brake and clutch master cylinders. I agree with DDDenny - seeing close-ups of your work is great!
  13. Frames
    Frames
    img238.jpg img239.jpg img240.jpg img242.jpg img241.jpg img243.jpg img244.jpg img245.jpg Front engine mounting is 1/4" magnesium. Steering wheel and column is 1960 Cadillac. Holes in the drop are for turn and bright indicator lights. I narrowed the 1946 Plymouth dash 5". Eliminated the radio to the left of the grille and the ash tray to the right. I drilled holes in the 1955 block for a late starter. I found the light weight flywheel at a swap meet. Model A tubs lean in at the top. Mine are now vertical. They end up flush with the top of the frame now. [ The top of the frame shows on an A. ] The tubs are now flush with the rolled pan also unlike a stock A. Not having the skill or equipment to completely shrink and stretch the nose I found that most of the compound curve was in the 2 upper corners that is why you see the 2 triangle pieces welded in. But the chin was the easiest part. I tried 1/4" rod. Did not look right. Built the grille with 5/16" rod. It is polished ready for the chrome shop. My rare steel converted Frankland V-8 QC with the triangulated 4 link brackets.
    kidcampbell71, Stogy and King ford like this.
  14. King ford
    King ford
    from 08302
    Nice work Dennis,is the Herb Thomas coupe going to be a restoration job?
  15. Frames
    Frames
  16. Frames
    Frames
    Painted the 46 Plymouth dash. [ Narrowed 5" ] 29 roadster 011.JPG 29 roadster 013.JPG 29 roadster 014.JPG Had the back rest covered. Polished the windshield posts that I fabricated.
    kidcampbell71 and Stogy like this.
  17. Bandit Billy
    Bandit Billy
    This is the stuff I stick around to watch. You keep posting, I'll keep watching.
    kidcampbell71 likes this.
  18. Frames
    Frames
    1951 Buick Special lens cut down. [ proportion] Custom bezel, 9 degrees so they don't point upwards. Suicide door frames done. Yankee Clipper headlights. [swap meet] 1956 Mercury wheel covers with Ford truck grease covers. Shocks behind axle for a cleaner look. The rear tire side wall did not match the front so I narrowed a 10" wheel to 9". 29 roadster 021.JPG 29 roadster 025.JPG img093.jpg img092.jpg img091.jpg
  19. alfin32
    alfin32
    from Essex, Ma.
    WOW, great profile!
    robber grin likes this.
  20. Rand Man
    Rand Man
    Man, there are so many things to like about his build. I've had similar ideas about a frame to resemble a rolled pan.
  21. Frames
    Frames
    Frankland Racing aluminum backing plates, Buick shoes. 48" axle plus a spacer for wider track. Adjustable suicide front spring mount. Can you tell the left spring schackle is a dead perch. p1010054_0013_0087.jpg p1010055_0014_0088.jpg p1010058_0020_0091.jpg p1010061_0012_0094.jpg p1010062_0021_0095.jpg
  22. A Boner
    A Boner
  23. 26hotrod
    26hotrod
    from landis n c
    Dennis! I am blown away. I am coming to see you real soon to observe this master piece............
  24. Frames
    Frames
  25. goatboy
    goatboy
    from kansas
    absolutely beautiful build that's one to watch
  26. el Roach
    el Roach
    Nice job! I especially like that track nose!
  27. Frames
    Frames
    I firmly believe if this hot rod was finished by a shop [with a dozen employees] it would be a contender for AMBR or a Great 8 pick. Hopefully without any changes.
  28. Blues4U
    Blues4U
    from So Cal
    It should be a contender anyway, absolutely beautiful build!
    Don't know how I missed this thread before, thanks for bumping it so I could find it.
  29. okiedokie
    okiedokie
    from Ok
    For sure a great 8 contender in my eyes.
