History Hot Rod truck thread!
Discussion in 'The Hokey Ass Message Board' started by Smack021488, Feb 5, 2017.
  1. Schwanke Engines
    Schwanke Engines
    Leave the black wheels, and slam that bad boy. Lowering is the easy part. Drop axle and reverse eye spring front, coil overs and a frame notch rear.
    Sent from my XT1585 using The H.A.M.B. mobile app
  2. classiccarjack
    classiccarjack
    After lowering vehicles for a few years, I can honestly say that your truck will look cool either way. But nothing drives better than a stock height truck. If you ever need to "use it" as a truck, you will be glad you did. Some nice rims will definitely do the trick.
  3. mkebaird
    mkebaird
    ... including yours. Just drive it!
  4. Jerry Perkins
    Jerry Perkins
    I rebuilt the motor and got it together so it would run good, even the 4 speed is still strong but no synchros so I had to learn to double clutch. I get it to 65 mph and then peg the throttle and it still wants to climb so the isky 400 jr is doing its job. It's really fun to drive.
  5. classiccarjack
    classiccarjack
    Sounds like a lot of fun Jerry! Nothing is sweeter than a well running vintage engine.
  6. 1936f100
    1936f100
    from joplin mo.
    100_1314.JPG P82A0031.JPG heres my toy
    1Nimrod, quick85, biggeorge and 15 others like this.
  7. classiccarjack
    classiccarjack
  8. 26 T Ford RPU
    26 T Ford RPU
    Some more fro NZ. JW
  9. 26 T Ford RPU
    26 T Ford RPU
  10. 26 T Ford RPU
    26 T Ford RPU
  11. 26 T Ford RPU
    26 T Ford RPU
  12. 26 T Ford RPU
    26 T Ford RPU
  13. 26 T Ford RPU
    26 T Ford RPU
  14. 26 T Ford RPU
    26 T Ford RPU
  15. 26 T Ford RPU
    26 T Ford RPU
  16. 26 T Ford RPU
    26 T Ford RPU
  17. 26 T Ford RPU
    26 T Ford RPU
  18. 26 T Ford RPU
    26 T Ford RPU
  19. 26 T Ford RPU
    26 T Ford RPU
  20. 26 T Ford RPU
    26 T Ford RPU
  21. 26 T Ford RPU
    26 T Ford RPU
  22. 26 T Ford RPU
    26 T Ford RPU
  23. 26 T Ford RPU
    26 T Ford RPU
    I have lots more but their confused owners fitted really dumb wheels and rubber bands.:eek::( JW
  24. 26 T Ford RPU
    26 T Ford RPU
  25. moparjimd60
    moparjimd60
  26.
  27. 26 T Ford RPU
    26 T Ford RPU
    I guess these Mainlines belong here. JW
  28. 26 T Ford RPU
    26 T Ford RPU
  29. Here's a late model that I liked real well. Probably not what anyone wants to see and it may not count as a hot rod. LOL
    1Nimrod, Elcohaulic, quick85 and 10 others like this.
  30. 26 T Ford RPU
    26 T Ford RPU
    I raced my T RPU against this A and lost by 1 length. JW
